Show Current Sun Position and Shadow of House (Generate SVG)
It sure worked better with the complete code :smiley:
Thanks for the tip :+1: :smiley:
I can now execute the script, and get the following result:
openhabian@openHABianPi:~$ python /etc/openhab2/scripts/shaddow.py
248.001879033
7.46388516439
No parameters specified
Done in 0.668642044067 seconds
But no SVG is being generated. I created a empty svg in folder html. But the script doesn’t update it.
Any Ideas on this matter?
thanks
Chris
It looks like you forgot the “update” parameter.
Try this:
python /etc/openhab2/scripts/shaddow.py update
Greetings,
Frederic
Wow, now i feel stupid! :blush:
Adding the update parameter solved my problems :slight_smile:
thanks Frederic :+1:
And thanks to Vincent for this great script! Great work :+1:
Hi Vincent,
I finally got your solution up and running, with some help by you and some others here in this topic :slight_smile:
I just have one question though. I see that the script is running and updating the svg, but returns the wrong azimut values. I have edited the script with my LONG_LAT coordinates of course.
This is my log output for the script:
2018-03-26 19:38:26.681 [INFO ] [lipse.smarthome.model.script.Shaddow] - Updating Shaddow SVG
2018-03-26 19:38:26.686 [INFO ] [lipse.smarthome.model.script.Shaddow] - 299.595063593
-13.7071667235
Done in 0.952764987946 seconds
and this is the output from the AstoSunData:
2018-03-26 19:38:24.228 [vent.ItemStateChangedEvent] - Sun_Azimuth changed from 271.81 to 272.89
2018-03-26 19:38:24.233 [vent.ItemStateChangedEvent] - AstroSunData_Position_Azimuth changed from 271.81 to 272.89
Any idea what could be wrong?
This is what I’ve changed in your python script:
FILENAME = '/etc/openhab2/html/shaddow.svg'
LATITUDE = XX.5525
LONGITUDE = XX.9779
ALTITUDE = 17.0000
# Shape of the house in a 100 by 100 units square
SHAPE = [{'x': 75.00, 'y': 22.00}, \
		{'x': 81.00, 'y': 60.00}, \
		{'x': 24.00, 'y': 73.00}, \
		{'x': 18.00, 'y': 34.00}]
self.l = Location(('HOME', 'XXXXX', LATITUDE, LONGITUDE, 'Europe/Oslo', ALTITUDE))
Looks like you could be an hour off. Try changing the ‘Europe/Oslo’ bit.
Thanks for your reply :slight_smile:
I tried to change the timezone, but without any change in the results. I checked the astral library, and it seems to support Oslo as a City.
Are these two parameters optional and not taken into consideration of the geo data?
Odd, I’ll need to dig into it.
Yes they are
Did you reboot your system since the daylight saving time change?
Yes, and did a reboot right now. Same results still :frowning:
Let’s test, print the time variable ts to check you have the right time in the script
I know you have the right time in openHAB but maybe the javascript returns something else…
Change shaddow.py as follow:
class shaddow(object):
	Shaddow Object
	def __init__(self):
		self.debug = False
		self.oh = openhab()
		self.astr = Astral()
		self.l = Location(('HOME', 'WATFORD', LATITUDE, LONGITUDE, 'Europe/London', ALTITUDE))
		self.sun = self.l.sun()
		ts = time.time()
                print(ts)
		self.azimuth = float(self.astr.solar_azimuth(datetime.fromtimestamp(ts), LATITUDE, LONGITUDE))
Hi Vincent,
Just updated the script with the “print (ts)”, and here’s the log output:
1522389308.06
120.558989318
21.6981129979
Done in 0.64107298851 seconds
Ok, now compare the 1522389308 with the actual time
This number is a unix timestamp, you can paste it in
Do it again with a “fresh” value
I see :slight_smile: I learn new stuff everytime i visit this forum. It’s great!! :slight_smile:
So, I pasted a fresh value in the link provided.
My value= 1522407311.87
Converted = 03/30/2018 @ 10:55am (UTC)
Local time when executed= 12:55am
So It seems I’m 2 hours behind in the astral setup.
Chris
Cool, 2 hours…
Now change the script as follow a little bit further down in the code:
		self.sunrise_azimuth = float(self.astr.solar_azimuth(self.sun['sunrise'], LATITUDE, LONGITUDE))
		self.sunset_azimuth = float(self.astr.solar_azimuth(self.sun['sunset'], LATITUDE, LONGITUDE))
		utc_offset = (datetime.fromtimestamp(ts) - datetime.utcfromtimestamp(ts)).total_seconds()/3600
		print(utc_offset)
		for h in xrange(0,24,HOURS):
			t = datetime.combine(date.today(), datetime.min.time()) + timedelta(hours=-utc_offset+h-24)
add the print(utc_offset) to check it. It should be 2 in your case but I suspect, it’s only 1
Here are my results after adding the “print(utc_offset)”
python /etc/openhab2/scripts/shaddow4.py update
1522421206.59
263.313925336
9.08693431761
2.0
Done in 0.615770101547 seconds
Very odd
I am starting to suspect there is a bug in astral
Let me sleep on it
okay. Thanks for your time and help.
Looking forward to hear from you, and possibly a clever solution :slight_smile:
Hi Vincent. Not to push or anything, but I’m just curious if you’ve though some more on my little astral issue? :slight_smile:
Sorry, easter week-end and all.
I was wondering, perhaps wrongly, but just to make sure…
From your post #84, there is 30d difference betwwen what astral gives you and what OH astro binding gives.
30 degrees is 2 hours of sun movement, give or take.
So either astral is wrong or OH is wrong…
So I have checked in suncalc.org for the 26/03/2018 at 19:38 and it appears that astral is wrong… Mmmmmh… By 2 hours… Mmmmmmmmmmhhhhh…
So let’s try to cheat astral
change that…
		self.debug = False
		self.oh = openhab()
		ts = time.time() - (2 * 86400)
		print(self.azimuth)
		self.elevation = float(self.astr.solar_elevation(datetime.fromtimestamp(ts), LATITUDE, LONGITUDE))
		print(self.elevation)
We basically take 2 hours off the time we inject into astral
What happens?
