This is a very simple thermostat list item widget (great to use as the default list Item widget for a thermostat). It supports a single setpoint, current temperature and a mode. The slider sets the setpoint. The value in the upper right shows the current temperature. The “Mode” button lets you set the mode.
Requirements:
The Items must meet the following criteria.
Item | Criteria |
Setpoint | Must be a Number:Temperature Item with properly formatted State Description metadata |
Current Temp | Must be a Number Item with properly formatted State Description metadata |
Mode | Must be a String Item with options defined. The options are often provided by the Channel. If not, you will have to supply your own in the State Description metadata. This widget assumes “HEAT”, “COOL” and “OFF” will be the modes. The options will dictate what is shown when clicking on the button. |
Behavior:
The behavior is pretty simple. Moving the slider changes the setpoint. The color of the widget is based on the mode: HEAT = orange, COOL = blue, OFF = gray.
If “°C” is chosen as the units the slider min is set to 10, max set to 27, and steps set to 0.5. If “°F” is chosen as the units the slider min is set to 40, max set to 80, and steps set to 1.
Screenshots
Changelog
Version 0.1
- initial release
Resources
uid: rlk_simple_thermostat_list
tags:
- list
props:
parameters:
- default: Thermostat
description: Set the title for this thermostat
label: Title
required: false
type: TEXT
- context: item
description: Item representing the setpoint
label: Setpoint Item
required: true
type: TEXT
- context: item
description: The current temperature
label: Current Temperature
required: true
type: TEXT
- context: item
description: HVAC Mode
label: Current thermostat mode
required: true
type: TEXT
- default: °F
description: Set the temperature units
label: Units
required: false
type: TEXT
options:
- label: °C
value: °C
- label: °F
value: °F
parameterGroups: []
timestamp: Oct 4, 2022, 3:17:30 PM
component: f7-card
style:
noShadow: true
class:
- padding: 0px
boarder-radius: var(--f7-card-expandable-board-radius)
height: 100px
width: calc(100%)
margin-left: 5px
margin-right: 5px
slots:
content:
- component: f7-block
style:
position: absolute
top: -5px
left: 15px
flex-direction: row
display: flex
slots:
default:
- component: f7-icon
f7: "=(items[props.mode].state == 'HEAT') ? 'thermometer_sun' : (items[props.mode].state == 'COOL') ? 'thermometer_snowflake' : 'thermometer'"
color: "=(items[props.mode].state == 'HEAT') ? 'orange' : (items[props.mode].state == 'COOL') ? 'blue' : 'gray'"
style:
margin-right: 10px
- component: Label
text: "=(items[props.mode].state == 'OFF') ? 'Thermostat is off' : 'Thermostat is set to ' + items[props.mode].displayState + ' to ' + items[props.setpoint].state"
style:
font-size: 14px
font-weight: 700
margin-top: 0px
style:
position: absolute
width: 100%
slots:
default:
- component: f7-chip
text: =items[props.currentTemp].state
style:
--f7-chip-bg-color: rgba(255, 255, 255, 0)
position: absolute
top: 8px
right: 18px
font-size: 14px
- component: oh-slider
item: Thermostat_TargetSetpoint
min: "=(props.units == '°F') ? 50 : 10"
max: "=(props.units == '°F') ? 80 : 27"
step: "=(props.units == '°F') ? 1 : 0.5"
label: true
unit: =props.units
releaseOnly: true
style:
position: absolute
top: 35px
width: 90%
- component: oh-button
text: Mode
fill: true
action: options
actionItem: Thermostat_ThermostatMode
style:
position: absolute
top: 60px
width: 90%
