- Platform information:
- Hardware: raspberry pi 3b plus
- OS: debian stretch
- Java Runtime Environment: Zulu Embedded 8.25.0.76-linux-aarch32hf (build 1.8.0_152-b76)
- openHAB version: 2.3 release from https://dl.bintray.com/openhab/apt-repo2
- Issue of the topic: since updating to openhab 2.3 webcam url proxying does not work anymore. i get user/password prompt from web basicui and nothing (no image, no video, no prompt) from ios app
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
i have a similar Problem:
do you think, this is the same?
Ralph
I have the same problem, in my case cean the cache resolve.
ok - thank you for your Feedback. how can we tell this someone, who can fix it?
This thread has no activity and the problem does’nt care anybody it seems….![]()
Does this problem occur often? If so may you can have a script run once a week or whatever suits your needs to clear the cache and temp files automatically. I usually do it manually with:
sudo service openhab2 stop && sudo rm -rf /var/lib/openhab2/cache/* && sudo rm -rf /var/lib/openhab2/tmp/* && sudo reboot
You can change the reboot to service openhab2 start if you would rather not reboot.
hi there,
Clearing the Cache does not solve the Problem. i have the Problem everytime.
but only with ios app and local Connection. with ios app and Cloud-Connection everything is fine.
in the browser - everthing is fine.
regards
ralph
Did you try with clearing the tmp folder as well?
i have cleared the temp-folder and Restart Openhab…no Change…does not work
2 Camera-Pictures are working….3 not…
regards,
ralph
Any Body here, who is interested to fix this bug?
Hi Ralph,
Here’s a link that you may be interested in https://community.openhab.org/t/ipcamera-new-ip-camera-binding/42771?u=h102. It’s lengthy but full of good info. I would use OH with camera’s but seems to be a bit much for a RPI 3. Should be no hardware issue for Windows server.
Best of Luck
