Hello, I just recently joined OpenHAB, now I want to set up everything little by little. first Z-Wave, everything worked, now I wanted to set up the Zigbee (SMabit AV2010/10).
I switched Z-wave and zigbee usb through to the LXC from the OpenHAB.
Z-wave runs right away, unfortunately the Zigbee stick causes problems and does not connect.
Maybe someone has an idea what else I can test. (FW not changed, still original)
Screen shots are almost useless on the forum. Please click on the “Code” tab and paste the textual Thing config. Use code fences.
code goes here
This appears to have an Ember chipset. Did you configure it as such?
Logs?
yes Ember Chip and Config
UID: zigbee:coordinator_ember:74e606c57d
label: Ember Coordinator
thingTypeUID: zigbee:coordinator_ember
configuration:
zigbee_port: /dev/ttyUSB0
zigbee_channel: 11
zigbee_initialise: false
zigbee_concentrator: 1
zigbee_trustcentremode: TC_JOIN_SECURE
zigbee_extendedpanid: F5E11F608A2E141B
zigbee_baud: 57600
zigbee_flowcontrol: 2
zigbee_panid: 62000
zigbee_powermode: 1
zigbee_txpower: 0
zigbee_networksize: 100
zigbee_linkkey: 5A6967426565416C6C69616E63653039
zigbee_childtimeout: 86400
zigbee_networkkey: 47303B4A9C9E058135F4AC612EBC497B
zigbee_meshupdateperiod: 86400
21:28:39.486 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:74e606c57d' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
21:28:44.165 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:74e606c57d' changed from UNINITIALIZED (DISABLED) to INITIALIZING
21:28:44.167 [INFO ] [openhab.event.FirmwareStatusInfoEvent] - Firmware status of thing zigbee:coordinator_ember:74e606c57d changed to UNKNOWN.
21:28:48.169 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RouterOSInterface_TransmissionRate' changed from 3.3945127 Mbit/s to 3.444456 Mbit/s
21:28:48.170 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RouterOSInterface_ReceivingRate' changed from 0.0678832 Mbit/s to 0.1371048 Mbit/s
21:28:49.645 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:74e606c57d' changed from INITIALIZING to OFFLINE: Failed to startup ZigBee transport layer
21:28:49.646 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:74e606c57d' changed from OFFLINE: Failed to startup ZigBee transport layer to OFFLINE (COMMUNICATION_ERROR)
21:28:50.646 [INFO ] [gbee.handler.ZigBeeCoordinatorHandler] - ZigBee dongle inactivity timer. Reinitializing ZigBee
21:28:56.294 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:74e606c57d' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE: Failed to startup ZigBee transport layer
21:28:56.295 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:74e606c57d' changed from OFFLINE: Failed to startup ZigBee transport layer to OFFLINE (COMMUNICATION_ERROR)
21:28:58.395 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RouterOSInterface_TransmissionRate' changed from 3.444456 Mbit/s to 3.4678087 Mbit/s
21:28:58.396 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RouterOSInterface_ReceivingRate' changed from 0.1371048 Mbit/s to 0.0996152 Mbit/s
21:29:01.294 [INFO ] [gbee.handler.ZigBeeCoordinatorHandler] - ZigBee dongle inactivity timer. Reinitializing ZigBee
21:29:06.934 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:74e606c57d' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE: Failed to startup ZigBee transport layer
21:29:06.935 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:74e606c57d' changed from OFFLINE: Failed to startup ZigBee transport layer to OFFLINE (COMMUNICATION_ERROR)
21:29:08.568 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'MikrotikRouterOS_CPULoad' changed from 0 % to 16 %
21:29:08.568 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RouterOSInterface_TransmissionRate' changed from 3.4678087 Mbit/s to 0.0866032 Mbit/s
21:29:08.569 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RouterOSInterface_ReceivingRate' changed from 0.0996152 Mbit/s to 0.0338032 Mbit/s
21:29:11.935 [INFO ] [gbee.handler.ZigBeeCoordinatorHandler] - ZigBee dongle inactivity timer. Reinitializing ZigBee
We would need to see debug logs:
IIRC coordinator firmware (Thing → Information → Thing Properties → firmwareVersion) >= 6.7.8 is required for Zigbee 3.0 devices.
i hope this is right
00:12:49.420 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - ZigBeeNetworkManager shutdown: networkState=OFFLINE
00:12:49.420 [DEBUG] [database.ZigBeeNetworkDatabaseManager] - Data store: Deferred Write Time set to 0ms
00:12:49.420 [DEBUG] [database.ZigBeeNetworkDatabaseManager] - Data store: Deferred Write Time set less than Max Deferred Write Time
00:12:49.421 [DEBUG] [database.ZigBeeNetworkDatabaseManager] - Data store: Max Deferred Write Time set to 0ms
00:12:49.422 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to SHUTDOWN
00:12:49.422 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=SHUTDOWN
00:12:49.423 [DEBUG] [pp.discovery.ZigBeeDiscoveryExtension] - DISCOVERY Extension: Shutdown
00:12:49.423 [DEBUG] [database.ZigBeeNetworkDatabaseManager] - Data store: Shutdown
00:12:49.423 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Shutdown
00:12:49.423 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Ember: Link State change to false, initialised=false, networkStateUp=false
00:12:49.424 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Ember: Link State change to false ignored.
00:12:49.569 [DEBUG] [inding.zigbee.serial.ZigBeeSerialPort] - Serial port '/dev/ttyUSB0' closed.
00:12:49.569 [DEBUG] [.transaction.ZigBeeTransactionManager] - Transaction Manager: Shutdown
00:12:49.569 [DEBUG] [ee.transaction.ZigBeeTransactionQueue] - Broadcast: Queue shutdown
00:12:49.569 [DEBUG] [ee.transaction.ZigBeeTransactionQueue] - Multicast: Queue shutdown
00:12:49.570 [DEBUG] [ing.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
00:12:49.570 [DEBUG] [ing.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:'/dev/ttyUSB0' PAN:f230, EPAN:F5E11F608A2E141B, Channel:11
00:12:49.570 [DEBUG] [ing.zigbee.ember.handler.EmberHandler] - Ember end device poll timeout set to (169 * 2^9) = 86528 seconds
00:12:49.570 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
00:12:50.571 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
00:12:50.571 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
00:12:50.571 [DEBUG] [ee.transaction.ZigBeeTransactionQueue] - Default: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=1, interTransactionDelay=50, maxRetries=2]
00:12:50.571 [DEBUG] [ee.transaction.ZigBeeTransactionQueue] - Broadcast: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=2, interTransactionDelay=4000, maxRetries=0]
00:12:50.572 [DEBUG] [ee.transaction.ZigBeeTransactionQueue] - Multicast: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=3, interTransactionDelay=1200, maxRetries=0]
00:12:50.572 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - ZigBeeNetworkManager initialize: networkState=UNINITIALISED
00:12:50.572 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to INITIALISING
00:12:50.572 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Initialize with protocol ASH2.
00:12:50.572 [DEBUG] [inding.zigbee.serial.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyUSB0] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
00:12:50.572 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
00:12:50.787 [DEBUG] [inding.zigbee.serial.ZigBeeSerialPort] - Serial port [/dev/ttyUSB0] is initialized.
00:12:53.084 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Ember: Link State change to true, initialised=false, networkStateUp=false
00:12:53.084 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Ember: Link State change to true ignored.
00:12:53.096 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspVersionResponse [networkId=0, protocolVersion=4, stackType=2, stackVersion=5800]
00:12:53.097 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspVersionResponse [networkId=0, protocolVersion=4, stackType=2, stackVersion=5800]
00:12:53.114 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetStandaloneBootloaderVersionPlatMicroPhyResponse [networkId=0, bootloaderVersion=5800, nodePlat=4, nodeMicro=14, nodePhy=3]
00:12:53.136 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=0]
00:12:53.136 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=0]
00:12:53.158 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=5]
00:12:53.158 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=5]
00:12:53.180 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=8]
00:12:53.180 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=8]
00:12:53.202 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=0]
00:12:53.203 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=0]
00:12:53.224 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=0]
00:12:53.225 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=0]
00:12:53.246 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=3000]
00:12:53.246 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=3000]
00:12:53.268 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=30]
00:12:53.269 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=30]
00:12:53.290 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=0]
00:12:53.290 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=0]
00:12:53.312 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=1]
00:12:53.312 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=1]
00:12:53.334 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=6]
00:12:53.334 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=6]
00:12:53.356 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=0]
00:12:53.357 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=0]
00:12:53.378 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=32]
00:12:53.378 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=32]
00:12:53.400 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=10]
00:12:53.401 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=10]
00:12:53.424 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=15]
00:12:53.424 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=15]
00:12:53.448 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=32]
00:12:53.451 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=32]
00:12:53.469 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=16]
00:12:53.470 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=16]
00:12:53.491 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=1]
00:12:53.492 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=1]
00:12:53.514 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=0]
00:12:53.515 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=0]
00:12:53.536 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=75]
00:12:53.536 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=75]
00:12:53.558 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=5]
00:12:53.558 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=5]
00:12:53.580 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=6]
00:12:53.580 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=6]
00:12:53.581 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_END_DEVICE_POLL_TIMEOUT = 5
00:12:53.581 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_INDIRECT_TRANSMISSION_TIMEOUT = 3000
00:12:53.581 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_SECURITY_LEVEL = 5
00:12:53.582 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_MAX_HOPS = 30
00:12:53.582 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_NEIGHBOR_TABLE_SIZE = 16
00:12:53.582 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_FRAGMENT_WINDOW_SIZE = 1
00:12:53.582 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_END_DEVICE_POLL_TIMEOUT_SHIFT = 6
00:12:53.583 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_BROADCAST_TABLE_SIZE = 15
00:12:53.583 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_TX_POWER_MODE = 0
00:12:53.583 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_SUPPORTED_NETWORKS = 1
00:12:53.583 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_FRAGMENT_DELAY_MS = 0
00:12:53.584 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_SOURCE_ROUTE_TABLE_SIZE = 0
00:12:53.584 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_KEY_TABLE_SIZE = 6
00:12:53.584 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_BINDING_TABLE_SIZE = 32
00:12:53.584 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_PACKET_BUFFER_COUNT = 75
00:12:53.585 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_ADDRESS_TABLE_SIZE = 8
00:12:53.585 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_STACK_PROFILE = 0
00:12:53.585 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_APS_UNICAST_MESSAGE_COUNT = 10
00:12:53.586 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_TRUST_CENTER_ADDRESS_CACHE_SIZE = 0
00:12:53.586 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_MAX_END_DEVICE_CHILDREN = 32
00:12:53.586 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_APPLICATION_ZDO_FLAGS = 0
00:12:53.602 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=01]
00:12:53.602 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=01]
00:12:53.624 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=10]
00:12:53.624 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=10]
00:12:53.646 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=40]
00:12:53.646 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=40]
00:12:53.668 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=50]
00:12:53.668 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=50]
00:12:53.690 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=61]
00:12:53.690 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=61]
00:12:53.712 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=71]
00:12:53.712 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=71]
00:12:53.713 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_TRUST_CENTER_POLICY = EZSP_ALLOW_PRECONFIGURED_KEY_JOINS [01]
00:12:53.713 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_APP_KEY_REQUEST_POLICY = EZSP_ALLOW_APP_KEY_REQUESTS [61]
00:12:53.713 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_TC_REJOINS_USING_WELL_KNOWN_KEY_POLICY = UNKNOWN [71]
00:12:53.713 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_MESSAGE_CONTENTS_IN_CALLBACK_POLICY = EZSP_MESSAGE_TAG_ONLY_IN_CALLBACK [40]
00:12:53.714 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_TC_KEY_REQUEST_POLICY = EZSP_DENY_TC_KEY_REQUESTS [50]
00:12:53.714 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_BINDING_MODIFICATION_POLICY = EZSP_DISALLOW_BINDING_MODIFICATION [10]
00:12:53.714 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_SOURCE_ROUTE_TABLE_SIZE, value=16]
00:12:53.734 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.734 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.735 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_SECURITY_LEVEL, value=5]
00:12:53.756 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.756 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.757 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_ADDRESS_TABLE_SIZE, value=100]
00:12:53.778 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.778 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.779 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_TRUST_CENTER_ADDRESS_CACHE_SIZE, value=2]
00:12:53.800 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.800 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.801 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_STACK_PROFILE, value=2]
00:12:53.822 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.822 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.823 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_INDIRECT_TRANSMISSION_TIMEOUT, value=7680]
00:12:53.844 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.844 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.845 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_MAX_HOPS, value=8]
00:12:53.866 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.867 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.867 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_TX_POWER_MODE, value=1]
00:12:53.888 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.888 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.889 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_SUPPORTED_NETWORKS, value=1]
00:12:53.910 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.911 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.911 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_KEY_TABLE_SIZE, value=4]
00:12:53.932 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.932 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.933 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_APPLICATION_ZDO_FLAGS, value=1]
00:12:53.954 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.955 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.955 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_MAX_END_DEVICE_CHILDREN, value=16]
00:12:53.976 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.977 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.977 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_APS_UNICAST_MESSAGE_COUNT, value=10]
00:12:53.998 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.998 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:53.999 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_BROADCAST_TABLE_SIZE, value=15]
00:12:54.020 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_ERROR_INVALID_VALUE]
00:12:54.021 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_ERROR_INVALID_VALUE]
00:12:54.021 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_BINDING_TABLE_SIZE, value=2]
00:12:54.042 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.043 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.043 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_NEIGHBOR_TABLE_SIZE, value=16]
00:12:54.065 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.065 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.065 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_FRAGMENT_WINDOW_SIZE, value=1]
00:12:54.089 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.089 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.090 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_FRAGMENT_DELAY_MS, value=50]
00:12:54.112 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.112 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.112 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_PACKET_BUFFER_COUNT, value=255]
00:12:54.136 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.139 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.139 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_END_DEVICE_POLL_TIMEOUT, value=169]
00:12:54.155 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.155 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.156 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueRequest [networkId=0, configId=EZSP_CONFIG_END_DEVICE_POLL_TIMEOUT_SHIFT, value=9]
00:12:54.177 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.178 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.200 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=16]
00:12:54.200 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=16]
00:12:54.222 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=5]
00:12:54.223 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=5]
00:12:54.244 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=100]
00:12:54.245 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=100]
00:12:54.266 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=2]
00:12:54.267 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=2]
00:12:54.288 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=2]
00:12:54.289 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=2]
00:12:54.310 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=7680]
00:12:54.311 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=7680]
00:12:54.332 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=8]
00:12:54.333 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=8]
00:12:54.354 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=1]
00:12:54.355 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=1]
00:12:54.377 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=1]
00:12:54.377 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=1]
00:12:54.401 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=4]
00:12:54.402 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=4]
00:12:54.423 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=1]
00:12:54.424 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=1]
00:12:54.445 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=16]
00:12:54.446 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=16]
00:12:54.467 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=10]
00:12:54.468 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=10]
00:12:54.489 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=15]
00:12:54.490 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=15]
00:12:54.511 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=2]
00:12:54.512 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=2]
00:12:54.533 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=16]
00:12:54.534 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=16]
00:12:54.555 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=1]
00:12:54.556 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=1]
00:12:54.577 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=50]
00:12:54.578 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=50]
00:12:54.599 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=255]
00:12:54.600 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=255]
00:12:54.621 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=169]
00:12:54.622 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=169]
00:12:54.643 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=9]
00:12:54.644 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetConfigurationValueResponse [networkId=0, status=EZSP_SUCCESS, value=9]
00:12:54.644 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_END_DEVICE_POLL_TIMEOUT = 169
00:12:54.644 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_INDIRECT_TRANSMISSION_TIMEOUT = 7680
00:12:54.644 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_SECURITY_LEVEL = 5
00:12:54.645 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_MAX_HOPS = 8
00:12:54.645 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_NEIGHBOR_TABLE_SIZE = 16
00:12:54.645 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_FRAGMENT_WINDOW_SIZE = 1
00:12:54.645 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_END_DEVICE_POLL_TIMEOUT_SHIFT = 9
00:12:54.645 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_BROADCAST_TABLE_SIZE = 15
00:12:54.646 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_TX_POWER_MODE = 1
00:12:54.646 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_SUPPORTED_NETWORKS = 1
00:12:54.646 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_FRAGMENT_DELAY_MS = 50
00:12:54.646 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_SOURCE_ROUTE_TABLE_SIZE = 16
00:12:54.647 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_KEY_TABLE_SIZE = 4
00:12:54.647 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_BINDING_TABLE_SIZE = 2
00:12:54.647 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_PACKET_BUFFER_COUNT = 255
00:12:54.647 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_ADDRESS_TABLE_SIZE = 100
00:12:54.647 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_STACK_PROFILE = 2
00:12:54.648 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_APS_UNICAST_MESSAGE_COUNT = 10
00:12:54.648 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_TRUST_CENTER_ADDRESS_CACHE_SIZE = 2
00:12:54.648 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_MAX_END_DEVICE_CHILDREN = 16
00:12:54.648 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Configuration state EZSP_CONFIG_APPLICATION_ZDO_FLAGS = 1
00:12:54.665 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.666 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.687 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.688 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.709 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.710 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.731 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.732 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.753 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.754 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.775 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.776 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
00:12:54.797 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=01]
00:12:54.798 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=01]
00:12:54.819 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=12]
00:12:54.820 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=12]
00:12:54.841 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=40]
00:12:54.842 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=40]
00:12:54.863 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=51]
00:12:54.864 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=51]
00:12:54.885 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=60]
00:12:54.886 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=60]
00:12:54.907 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=00]
00:12:54.908 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspGetPolicyResponse [networkId=0, status=EZSP_SUCCESS, decisionId=00]
00:12:54.908 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_TRUST_CENTER_POLICY = EZSP_ALLOW_PRECONFIGURED_KEY_JOINS [01]
00:12:54.908 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_APP_KEY_REQUEST_POLICY = EZSP_DENY_APP_KEY_REQUESTS [60]
00:12:54.908 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_TC_REJOINS_USING_WELL_KNOWN_KEY_POLICY = EZSP_ALLOW_JOINS [00]
00:12:54.909 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_MESSAGE_CONTENTS_IN_CALLBACK_POLICY = EZSP_MESSAGE_TAG_ONLY_IN_CALLBACK [40]
00:12:54.909 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_TC_KEY_REQUEST_POLICY = EZSP_ALLOW_TC_KEY_REQUESTS_AND_SEND_CURRENT_KEY [51]
00:12:54.909 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Policy state EZSP_BINDING_MODIFICATION_POLICY = EZSP_CHECK_BINDING_MODIFICATIONS_ARE_VALID_ENDPOINT_CLUSTERS [12]
00:12:54.929 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetNetworkParametersResponse [networkId=0, status=EMBER_NOT_JOINED, nodeType=UNKNOWN, parameters=EmberNetworkParameters [extendedPanId=0000000000000000, panId=FFFF, radioTxPower=-1, radioChannel=0, joinMethod=EMBER_USE_MAC_ASSOCIATION, nwkManagerId=FFFF, nwkUpdateId=0, channels=00000000]]
00:12:54.930 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Ember initial network parameters are EmberNetworkParameters [extendedPanId=0000000000000000, panId=FFFF, radioTxPower=-1, radioChannel=0, joinMethod=EMBER_USE_MAC_ASSOCIATION, nwkManagerId=FFFF, nwkUpdateId=0, channels=00000000]
00:12:54.951 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetEui64Response [networkId=0, eui64=000D6F000DC56006]
00:12:54.952 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - Ember local IEEE Address is 000D6F000DC56006
00:12:54.973 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspGetNetworkParametersResponse [networkId=0, status=EMBER_NOT_JOINED, nodeType=UNKNOWN, parameters=EmberNetworkParameters [extendedPanId=0000000000000000, panId=FFFF, radioTxPower=-1, radioChannel=0, joinMethod=EMBER_USE_MAC_ASSOCIATION, nwkManagerId=FFFF, nwkUpdateId=0, channels=00000000]]
00:12:54.974 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: initialize done
00:12:54.975 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400.0
00:12:54.975 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0500
00:12:54.975 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher starting for endpoint 1 with profile ID 0104 (ZIGBEE_HOME_AUTOMATION)
00:12:54.976 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0500
00:12:54.976 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported server cluster 0019
00:12:54.976 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding server cluster 0019
00:12:54.977 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0001
00:12:54.977 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0001
00:12:54.977 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0006
00:12:54.978 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0006
00:12:54.978 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0008
00:12:54.978 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0008
00:12:54.978 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 000F
00:12:54.979 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 000F
00:12:54.979 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0101
00:12:54.979 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0101
00:12:54.979 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0102
00:12:54.979 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0102
00:12:54.980 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0201
00:12:54.980 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0201
00:12:54.980 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0202
00:12:54.980 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0202
00:12:54.981 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0300
00:12:54.981 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0300
00:12:54.981 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0400
00:12:54.981 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0400
00:12:54.982 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0402
00:12:54.982 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0402
00:12:54.982 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0403
00:12:54.982 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0403
00:12:54.983 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0405
00:12:54.983 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0405
00:12:54.983 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0406
00:12:54.983 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0406
00:12:54.984 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0500
00:12:54.984 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0500
00:12:54.984 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0502
00:12:54.984 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0502
00:12:54.985 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0702
00:12:54.985 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0702
00:12:54.985 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0B04
00:12:54.985 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0B04
00:12:54.986 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported server cluster 0005
00:12:54.986 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding server cluster 0005
00:12:54.987 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported server cluster 0006
00:12:54.987 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding server cluster 0006
00:12:54.987 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported server cluster 0008
00:12:54.987 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding server cluster 0008
00:12:54.987 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported server cluster 0402
00:12:54.988 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding server cluster 0402
00:12:54.988 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0000
00:12:54.988 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0000
00:12:54.989 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported client cluster 0019
00:12:54.989 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding client cluster 0019
00:12:54.989 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Adding supported server cluster 0000
00:12:54.989 [DEBUG] [ystems.zigbee.internal.ClusterMatcher] - ClusterMatcher adding server cluster 0000
00:12:54.990 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise: Previous device configuration was: channel=CHANNEL_00, PanID=65535, EPanId=0000000000000000
00:12:54.990 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_trustcentremode=TC_JOIN_SECURE
00:12:54.997 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetConcentratorResponse [networkId=0, status=EZSP_SUCCESS]
00:12:55.000 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - EzspSetConcentratorResponse [networkId=0, status=EZSP_SUCCESS]
00:12:55.019 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
00:12:55.020 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspSetPolicyResponse [networkId=0, status=EZSP_SUCCESS]
00:12:55.020 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - ZigBeeNetworkManager startup: reinitialize=false, networkState=INITIALISING
00:12:55.020 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Startup - reinitialize=false
00:12:55.020 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Adding Endpoint: ProfileID=0104, DeviceID=0050
00:12:55.020 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Adding Endpoint: Input Clusters 0000
00:12:55.021 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Adding Endpoint: Output Clusters 0000
00:12:55.041 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspAddEndpointResponse [networkId=0, status=EZSP_SUCCESS]
00:12:55.042 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspAddEndpointResponse [networkId=0, status=EZSP_SUCCESS]
00:12:55.063 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - RX EZSP: EzspNetworkInitResponse [networkId=0, status=EMBER_NOT_JOINED]
00:12:55.064 [DEBUG] [tsystems.zigbee.dongle.ember.EmberNcp] - EzspNetworkInitResponse [networkId=0, status=EMBER_NOT_JOINED]
00:12:55.064 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP dongle initialize failed to join network
00:12:55.064 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to OFFLINE
00:12:55.064 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=OFFLINE
00:12:55.065 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:74e606c57d' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE: Failed to startup ZigBee transport layer
00:12:55.065 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:74e606c57d' changed from OFFLINE: Failed to startup ZigBee transport layer to OFFLINE (COMMUNICATION_ERROR)
- firmwareVersion
5.8.0.0
- zigbee_macaddress
000D6F000DC56006
[SOLVED] Fail to start Zigbee transport layer - summary: noisy environment, use an extension cable …
use an extension cable - no change
I suggest waiting for @chris first, but he may be under NDA on this stick.
Otherwise, there seems to be a possibility to update the firmware of the stick (scroll down to the bottom …):
I’m not sure what your hourly rate is, but it may be more economical (but not as enlightening) to buy another stick.
Sorry, I’m out.
From the log it just looks like the device is not initialised as it’s not joined to a network. You should just have to set the configuration (network PANID, channel, etc) and initialise the device.
ok configuration.
but what else can I set?
or else, where can I get the network PANID, channel, etc? I only have this Zigbee USB stick, without which I can’t learn any devices, or am I wrong about it?
Have you initialised the stick? There is a config option called something like “Reset controller” or “Initialise controller” - have you set this to enabled? If not, the device will not be initialised, and it will not create a network, and this is what I see in the log - no network.
That’s my problem, I can’t get it involved.
and i don’t know why
can “Reinitialize Controller”
(Resets the coordinator, reinitialises the network, and sets the configuration to the configured values)
but that changes just as little.
if I disable it and then turn it back on, INITIALIZING
and then Offline “COMMUNICATION_ERROR”
on the USB stick
Please provide a debug log showing the initialisation - ie selecting to initialise the controller, then clicking save. The above log doesn’t seem to show that this has been selected.
openHAB Debug
openhab/things/zigbee:coordinator_ember:74e606c57d/statuschanged
[{"status":"UNINITIALIZED","statusDetail":"DISABLED"},{"status":"UNINITIALIZED","statusDetail":"NONE"}]
ThingStatusInfoEvent
[{"status":"UNINITIALIZED","statusDetail":"NONE"},{"status":"OFFLINE","statusDetail":"COMMUNICATION_ERROR"}]
[{"status":"OFFLINE","statusDetail":"COMMUNICATION_ERROR"},{"status":"OFFLINE","statusDetail":"NONE","description":"Failed to open communications port"}]
[{"status":"OFFLINE","statusDetail":"NONE","description":"Failed to open communications port"},{"status":"OFFLINE","statusDetail":"COMMUNICATION_ERROR"}]
[{"status":"OFFLINE","statusDetail":"NONE","description":"Failed to open communications port"},{"status":"INITIALIZING","statusDetail":"NONE"}]
openhab/things/zigbee:coordinator_ember:74e606c57d/firmware/status
{"thingUID":{"segments":["zigbee","coordinator_ember","74e606c57d"],"uid":"zigbee:coordinator_ember:74e606c57d"},"firmwareStatus":"UNKNOWN"}
[{"status":"INITIALIZING","statusDetail":"NONE"},{"status":"UNINITIALIZED","statusDetail":"DISABLED"}]
log:display org.openhab.binding.zigbee
21:13:25.735 [DEBUG] [gbee.discovery.ZigBeeDiscoveryService] - bundle org.openhab.binding.zigbee:3.3.0 (259)[org.openhab.binding.zigbee.discovery.ZigBeeDiscoveryService(298)] : dm ZigBeeCoordinatorHandler tracking 29 MultipleDynamic added {org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler}={service.id=572, service.bundleid=264, service.scope=singleton} (enter)
21:13:25.735 [DEBUG] [gbee.discovery.ZigBeeDiscoveryService] - bundle org.openhab.binding.zigbee:3.3.0 (259)[org.openhab.binding.zigbee.discovery.ZigBeeDiscoveryService(298)] : dm ZigBeeCoordinatorHandler tracking 29 MultipleDynamic already active, binding {org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler}={service.id=572, service.bundleid=264, service.scope=singleton}
21:13:25.735 [DEBUG] [gbee.discovery.ZigBeeDiscoveryService] - bundle org.openhab.binding.zigbee:3.3.0 (259)[org.openhab.binding.zigbee.discovery.ZigBeeDiscoveryService(298)] : invoking bind: addZigBeeCoordinatorHandler: parameters [org.openhab.binding.zigbee.ember.handler.EmberHandler]
21:13:25.735 [DEBUG] [gbee.discovery.ZigBeeDiscoveryService] - bundle org.openhab.binding.zigbee:3.3.0 (259)[org.openhab.binding.zigbee.discovery.ZigBeeDiscoveryService(298)] : invoked bind: addZigBeeCoordinatorHandler
21:13:25.735 [DEBUG] [gbee.discovery.ZigBeeDiscoveryService] - bundle org.openhab.binding.zigbee:3.3.0 (259)[org.openhab.binding.zigbee.discovery.ZigBeeDiscoveryService(298)] : dm ZigBeeCoordinatorHandler tracking 29 MultipleDynamic added {org.openhab.binding.zigbee.handler.ZigBeeCoordinatorHandler}={service.id=572, service.bundleid=264, service.scope=singleton} (exit)
21:13:25.740 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_ember:74e606c57d].
21:13:25.746 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Channel 11
21:13:25.746 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - PANID 6900
21:13:25.746 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - EPANID F5E11F608A2E141B
21:13:25.746 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Network Key 47303B4A9C9E058135F4AC612EBC497B
21:13:25.746 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Link Key 5A6967426565416C6C69616E63653039
21:13:25.746 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_initialise found, initializeNetwork=false
21:13:25.746 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Network Key String 47303B4A9C9E058135F4AC612EBC497B
21:13:25.746 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Network key final array 47303B4A9C9E058135F4AC612EBC497B
21:13:25.746 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Link Key String 5A6967426565416C6C69616E63653039
21:13:25.746 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Link key final array 5A6967426565416C6C69616E63653039
21:13:25.746 [DEBUG] [ing.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
21:13:25.746 [DEBUG] [ing.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:'/dev/ttyUSB0' PAN:1af4, EPAN:F5E11F608A2E141B, Channel:11
21:13:25.746 [DEBUG] [ing.zigbee.ember.handler.EmberHandler] - Ember end device poll timeout set to (169 * 2^9) = 86528 seconds
21:13:25.746 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
21:13:26.747 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
21:13:26.747 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
21:13:26.748 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
21:13:26.748 [DEBUG] [inding.zigbee.serial.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyUSB0] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
21:13:26.748 [DEBUG] [inding.zigbee.serial.ZigBeeSerialPort] - No communication ports found, cannot connect to [/dev/ttyUSB0]
21:13:26.748 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=OFFLINE
21:13:27.749 [INFO ] [gbee.handler.ZigBeeCoordinatorHandler] - ZigBee dongle inactivity timer. Reinitializing ZigBee
21:13:27.753 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=SHUTDOWN
21:13:27.754 [DEBUG] [ing.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
21:13:27.754 [DEBUG] [ing.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:'/dev/ttyUSB0' PAN:1af4, EPAN:F5E11F608A2E141B, Channel:11
21:13:27.754 [DEBUG] [ing.zigbee.ember.handler.EmberHandler] - Ember end device poll timeout set to (169 * 2^9) = 86528 seconds
21:13:27.754 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
21:13:28.758 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
21:13:28.758 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
21:13:28.758 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
21:13:28.758 [DEBUG] [inding.zigbee.serial.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyUSB0] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
21:13:28.759 [DEBUG] [inding.zigbee.serial.ZigBeeSerialPort] - No communication ports found, cannot connect to [/dev/ttyUSB0]
21:13:28.759 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=OFFLINE
21:13:33.768 [INFO ] [gbee.handler.ZigBeeCoordinatorHandler] - ZigBee dongle inactivity timer. Reinitializing ZigBee
21:13:33.774 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=SHUTDOWN
21:13:33.780 [DEBUG] [ing.zigbee.ember.handler.EmberHandler] - Initializing ZigBee Ember serial bridge handler.
21:13:33.780 [DEBUG] [ing.zigbee.ember.handler.EmberHandler] - ZigBee Ember Coordinator opening Port:'/dev/ttyUSB0' PAN:1af4, EPAN:F5E11F608A2E141B, Channel:11
21:13:33.780 [DEBUG] [ing.zigbee.ember.handler.EmberHandler] - Ember end device poll timeout set to (169 * 2^9) = 86528 seconds
21:13:33.780 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
21:13:34.780 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
21:13:34.785 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
21:13:34.786 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
21:13:34.786 [DEBUG] [inding.zigbee.serial.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyUSB0] at 57600 baud, flow control FLOWCONTROL_OUT_XONOFF.
21:13:34.786 [DEBUG] [inding.zigbee.serial.ZigBeeSerialPort] - No communication ports found, cannot connect to [/dev/ttyUSB0]
21:13:34.787 [DEBUG] [gbee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=OFFLINE
log:display com.zsmartsystems.zigbee
21:13:34.785 [DEBUG] [ee.transaction.ZigBeeTransactionQueue] - Default: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=1, interTransactionDelay=50, maxRetries=2]
21:13:34.785 [DEBUG] [ee.transaction.ZigBeeTransactionQueue] - Broadcast: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=2, interTransactionDelay=4000, maxRetries=0]
21:13:34.786 [DEBUG] [ee.transaction.ZigBeeTransactionQueue] - Multicast: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=3, interTransactionDelay=1200, maxRetries=0]
21:13:34.786 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - ZigBeeNetworkManager initialize: networkState=UNINITIALISED
21:13:34.786 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to INITIALISING
21:13:34.786 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Initialize with protocol ASH2.
21:13:34.786 [ERROR] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Unable to open serial port
21:13:34.786 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to OFFLINE
21:13:39.605 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - ZigBeeNetworkManager shutdown: networkState=OFFLINE
21:13:39.606 [DEBUG] [database.ZigBeeNetworkDatabaseManager] - Data store: Deferred Write Time set to 0ms
21:13:39.606 [DEBUG] [database.ZigBeeNetworkDatabaseManager] - Data store: Deferred Write Time set less than Max Deferred Write Time
21:13:39.606 [DEBUG] [database.ZigBeeNetworkDatabaseManager] - Data store: Max Deferred Write Time set to 0ms
21:13:39.610 [DEBUG] [rtsystems.zigbee.ZigBeeNetworkManager] - Network state is updated to SHUTDOWN
21:13:39.610 [DEBUG] [database.ZigBeeNetworkDatabaseManager] - Data store: Shutdown
21:13:39.610 [DEBUG] [.zigbee.dongle.ember.ZigBeeDongleEzsp] - EZSP Dongle: Shutdown
21:13:39.615 [DEBUG] [.transaction.ZigBeeTransactionManager] - Transaction Manager: Shutdown
21:13:39.615 [DEBUG] [ee.transaction.ZigBeeTransactionQueue] - Broadcast: Queue shutdown
21:13:39.615 [DEBUG] [ee.transaction.ZigBeeTransactionQueue] - Multicast: Queue shutdown
While I don’t think this is the problem you had earlier, at least in this log the serial port is not defined or unavailable, or has a permission issue (or something - it’s unable to be opened in any case).
