First of all, i think maybe have bad configuration, item sitemap,
items
Rollershutter RoletaGabinet “Roleta Gabinet” (rolety) { satel=“output:105,106”, autoupdate=“true” }
sitemap
sitemap dom label=“Dom” {
Frame {
Switch item=RoletaGabinet label=“Roleta Gabinet” mappings=[UP=“Góra”, DOWN=“Dół”]
For second i don’t now how to write directly to you, i’m new on this forum, i don’t see option send message.
I’m trying also
Switch AlarmConnection “Connection status” { satel=“module:connected” }
DateTime AlarmConnSince “Connected since [%1$tF %1$tR]” { satel=“module:connected_since” }
but have error
01:05:40.319 ERROR o.o.m.i.i.GenericItemProvider[:343] - Binding configuration of type ‘satel’ of item ‘AlarmConnection‘ could not be parsed correctly.
org.openhab.model.item.binding.BindingConfigParseException: Invalid binding configuration: module:connected
at org.openhab.binding.satel.internal.SatelGenericBindingProvider.createBindingConfig(SatelGenericBindingProvider.java:108)
01:05:40.328 ERROR o.o.m.i.i.GenericItemProvider[:343] - Binding configuration of type ‘satel’ of item ‘AlarmConnSince‘ could not be parsed correctly.
org.openhab.model.item.binding.BindingConfigParseException: Invalid binding configuration: module:connected_since
I think it will be better if you give me email adress or something other. Maybe we can speak in Polish
Launching the openHAB runtime in debug mode…
Listening for transport dt_socket at address: 8001
osgi> 01:07:42.836 WARN o.e.j.u.c.AbstractLifeCycle[:199] - FAILED SelectChannelConnector@0.0.0.0:8080: java.net.BindException: Address already in use
at sun.nio.ch.Net.bind0(Native Method)
at sun.nio.ch.Net.bind(Net.java:414)
at sun.nio.ch.Net.bind(Net.java:406)
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:214)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java:74)
at org.eclipse.jetty.server.nio.SelectChannelConnector.open(SelectChannelConnector.java:182)
at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:311)
at org.eclipse.jetty.server.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:260)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59)
at org.eclipse.jetty.server.Server.doStart(Server.java:273)
01:07:43.998 WARN o.e.j.u.c.AbstractLifeCycle[:199] - FAILED SslSelectChannelConnector@0.0.0.0:8443: java.net.BindException: Address already in use
at org.eclipse.jetty.server.ssl.SslSelectChannelConnector.doStart(SslSelectChannelConnector.java:626)
01:07:44.035 WARN o.e.j.u.c.AbstractLifeCycle[:199] - FAILED org.eclipse.jetty.server.Server@9692a6: MultiException[java.net.BindException: Address already in use, java.net.BindException: Address already in use]
org.eclipse.jetty.util.MultiException: Multiple exceptions
at org.eclipse.jetty.server.Server.doStart(Server.java:255)
at org.eclipse.jetty.osgi.boot.internal.serverfactory.ServerInstanceWrapper.start(ServerInstanceWrapper.java:166)
at org.eclipse.jetty.osgi.boot.internal.serverfactory.JettyServerServiceTracker.serviceChanged(JettyServerServiceTracker.java:112)
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:107)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130)
01:07:45.145 WARN o.e.j.o.b.i.s.JettyServerServiceTracker[:116] -
01:07:45.292 DEBUG o.o.c.s.i.SchedulerActivator[:36] - Scheduler has been started.
01:07:45.549 INFO o.q.impl.StdSchedulerFactory[:1175] - Using default implementation for ThreadExecutor
01:07:45.660 INFO o.q.core.SchedulerSignalerImpl[:61] - Initialized Scheduler Signaller of type: class org.quartz.core.SchedulerSignalerImpl
01:07:45.663 INFO o.quartz.core.QuartzScheduler[:243] - Quartz Scheduler v.2.1.7 created.
01:07:45.672 INFO org.quartz.simpl.RAMJobStore[:154] - RAMJobStore initialized.
01:07:45.680 INFO o.quartz.core.QuartzScheduler[:268] - Scheduler meta-data: Quartz Scheduler (v2.1.7) ‘openHAB-job-scheduler’ with instanceId ‘NON_CLUSTERED’
Scheduler class: ‘org.quartz.core.QuartzScheduler’ - running locally.
NOT STARTED.
Currently in standby mode.
Number of jobs executed: 0
Using thread pool ‘org.quartz.simpl.SimpleThreadPool’ - with 2 threads.
Using job-store ‘org.quartz.simpl.RAMJobStore’ - which does not support persistence. and is not clustered.
01:07:45.682 INFO o.q.impl.StdSchedulerFactory[:1324] - Quartz scheduler ‘openHAB-job-scheduler’ initialized from specified file: ‘./etc/quartz.properties’
01:07:45.684 INFO o.q.impl.StdSchedulerFactory[:1328] - Quartz scheduler version: 2.1.7
01:07:45.687 INFO o.quartz.core.QuartzScheduler[:534] - Scheduler openHAB-job-scheduler_$_NON_CLUSTERED started.
01:07:45.717 DEBUG o.o.c.core.ConfigDispatcher[:146] - Processing openHAB default configuration file ‘/home/pi/openhab/configurations/openhab_default.cfg’.
01:07:46.168 DEBUG o.o.c.core.ConfigDispatcher[:168] - Processing openHAB main configuration file ‘/home/pi/openhab/configurations/openhab.cfg’.
01:07:46.304 DEBUG o.o.c.internal.CoreActivator[:93] - UUID file already exists at ‘/home/pi/openhab/webapps/static/uuid’ with content ‘e2c311f6-db5e-42c0-9b75-c2830550c935’
01:07:46.310 DEBUG o.o.c.internal.CoreActivator[:115] - Created file ‘/home/pi/openhab/webapps/static/version’ with content ‘1.5.1’
01:07:46.312 INFO o.o.c.internal.CoreActivator[:61] - openHAB runtime has been started (v1.5.1).
01:07:46.452 DEBUG o.o.c.a.i.AutoUpdateActivator[:31] - AutoUpdate binding has been started.
01:07:51.593 DEBUG o.o.m.p.i.PersistenceModelActivator[:23] - Registered ‘persistence’ configuration parser
01:07:51.666 DEBUG o.o.c.t.i.TransformationActivator[:38] - Transformation Service has been started.
01:07:51.901 DEBUG o.o.i.g.internal.GCalActivator[:34] - Google Calendar IO has been started.
01:07:52.015 DEBUG o.o.i.m.i.MultimediaActivator[:34] - Multimedia I/O bundle has been started.
01:07:52.115 DEBUG o.o.i.s.i.DiscoveryServiceActivator[:27] - Discovery service has been started.
01:07:52.178 DEBUG o.o.i.t.mqtt.MqttService[:121] - Starting MQTT Service…
01:07:52.746 DEBUG o.o.m.i.i.ItemModelActivator[:24] - Registered ‘item’ configuration parser
01:07:53.281 DEBUG o.o.c.i.items.ItemRegistryImpl[:137] - Item provider ‘GenericItemProvider’ has been added.
01:07:56.886 DEBUG o.o.m.s.i.SitemapModelActivator[:23] - Registered ‘sitemap’ configuration parser
01:07:58.352 DEBUG o.o.m.r.i.RuleModelActivator[:42] - Registered ‘rules’ configuration parser
01:07:58.397 DEBUG o.o.m.r.i.engine.RuleEngine[:78] - Started rule engine
01:07:59.937 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model ‘dom.sitemap’
01:08:00.751 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model ‘rrd4j.persist’
01:08:00.875 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model ‘exec.persist’
01:08:00.907 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model ‘logging.persist’
01:08:00.946 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model ‘db4o.persist’
01:08:01.283 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model ‘dom.rules’
01:08:01.988 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model ‘dom.script’
01:08:02.253 DEBUG o.o.b.s.i.SatelActivator[:30] - Satel binding has been started.
01:08:02.394 INFO o.o.m.c.i.ModelRepositoryImpl[:79] - Loading model ‘dom.items’
01:08:02.427 INFO o.o.c.s.AbstractActiveService[:169] - Satel Refresh Service has been started
01:08:02.428 DEBUG o.o.b.s.i.protocol.SatelModule[:441] - Communication thread started
01:08:02.430 DEBUG o.o.b.s.internal.SatelBinding[:76] - Module not initialized yet, skipping refresh
01:08:02.434 INFO o.o.b.s.i.protocol.Ethm1Module[:65] - Connecting to ETHM-1 module at 192.168.10.201:7094
01:08:02.452 INFO o.o.b.s.i.protocol.Ethm1Module[:70] - ETHM-1 module connected successfuly
01:08:02.457 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 7E, payload =
01:08:02.480 DEBUG o.o.m.i.i.GenericItemProvider[:154] - Processing binding configs for items from model ‘dom.items’
01:08:02.515 ERROR o.o.m.i.i.GenericItemProvider[:343] - Binding configuration of type ‘satel’ of item ‘AlarmConnection‘ could not be parsed correctly.
at org.openhab.binding.satel.internal.SatelGenericBindingProvider.processBindingConfiguration(SatelGenericBindingProvider.java:57)
at org.openhab.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:341)
at org.openhab.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:317)
at org.openhab.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:171)
at org.openhab.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:379)
at org.openhab.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:158)
at org.openhab.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:84)
at org.openhab.model.core.internal.folder.FolderObserver.checkFolder(FolderObserver.java:142)
at org.openhab.model.core.internal.folder.FolderObserver.run(FolderObserver.java:99)
01:08:02.525 ERROR o.o.m.i.i.GenericItemProvider[:343] - Binding configuration of type ‘satel’ of item ‘AlarmConnSince‘ could not be parsed correctly.
01:08:02.528 DEBUG o.o.m.i.i.GenericItemProvider[:133] - Read items from model ‘dom.items’
01:08:02.705 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 7E, payload = 03 31 31 33 32 30 31 35 30 33 31 34 00 00
01:08:02.710 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: IntegraVersionEvent: type = 3, version = 1.13 2015-03-14, language = 0, settingsInFlash = false
01:08:02.712 INFO o.o.b.s.i.protocol.SatelModule[:195] - Connection to Integra 128 initialized. Version: 1.13 2015-03-14.
01:08:12.435 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 7F, payload =
01:08:13.203 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 7F, payload = FF FF FF FF FF
01:08:13.211 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: NewStatesEvent: changed = [00,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
01:08:13.214 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 17, payload =
01:08:13.455 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 17, payload = 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01:08:13.458 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: IntegraStateEvent: object = OUTPUT, state = OUTPUT, active = [3,4]
01:08:22.435 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 7F, payload =
01:08:22.453 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 7F, payload = FF FF 7F FF FF
01:08:22.463 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: NewStatesEvent: changed = [00,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
01:08:32.435 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 7F, payload =
01:08:32.453 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 7F, payload = FF FF 7F FF FF
01:08:32.459 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: NewStatesEvent: changed = [00,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
01:08:42.436 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 7F, payload =
01:08:42.453 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 7F, payload = FF FF 7F FF FF
01:08:42.465 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: NewStatesEvent: changed = [00,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
01:08:52.437 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 7F, payload =
01:08:52.453 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 7F, payload = FF FF 7F FF FF
01:08:52.461 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: NewStatesEvent: changed = [00,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
01:09:02.438 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 7F, payload =
01:09:02.453 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 7F, payload = FF FF 7F FF FF
01:09:02.462 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: NewStatesEvent: changed = [00,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
01:09:12.437 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 7F, payload =
01:09:12.453 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 7F, payload = FF FF 7F FF FF
01:09:12.462 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: NewStatesEvent: changed = [00,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
01:09:22.438 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 7F, payload =
01:09:22.452 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 7F, payload = FF FF 7F FF FF
01:09:22.464 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: NewStatesEvent: changed = [00,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
01:09:32.438 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 7F, payload =
01:09:32.451 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 7F, payload = FF FF 7F FF FF
01:09:32.457 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: NewStatesEvent: changed = [00,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
01:09:42.438 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 7F, payload =
01:09:42.451 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 7F, payload = FF FF 7F FF FF
01:09:42.457 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: NewStatesEvent: changed = [00,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
01:09:52.439 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 7F, payload =
01:09:52.450 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 7F, payload = FF FF 7F FF FF
01:09:52.457 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: NewStatesEvent: changed = [00,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
01:10:02.439 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 7F, payload =
01:10:02.451 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 7F, payload = FF FF 7F FF FF
01:10:02.459 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: NewStatesEvent: changed = [00,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
01:10:12.439 DEBUG o.o.b.s.i.protocol.SatelModule[:353] - Sending message: Message: command = 7F, payload =
01:10:12.450 DEBUG o.o.b.s.i.protocol.SatelModule[:364] - Got response: Message: command = 7F, payload = FF FF 7F FF FF
01:10:12.456 DEBUG o.o.b.s.i.e.EventDispatcher[:56] - Distributing event: NewStatesEvent: changed = [00,01,02,03,04,05,06,07,08,09,0A,0B,0C,0D,0E,0F,10,11,12,13,14,15,16,18,19,1A,1B,1C,1D,1E,1F,20,21,22,23,24,25,26,27]
