- Platform information:
- Hardware: Raspberry Pi 4 Model B
- openHAB version: 3.4.1 (openhabian image)
tried to create a “last seen” item based on state change of another item using blocky
the rule is triggered but the datetime item is not updated (see error message below)
It seems that the “now” block is not working with daytime item, i assume it is because of the square brackets
Have i done some wrong or is this a bug?
further information for debugging:
Error log:
[WARN ] [rnal.defaultscope.ScriptBusEventImpl] - State '2023-02-03T18:18:36.500876+01:00[Europe/Berlin]' cannot be parsed for item 'Xiaomi_Mijia_BT_HT_Medienzimmer_last_seen'.
the last seen item is a datetime configured this way:
blocky “code”:
complete code of the rule:
configuration: {}
triggers:
- id: "1"
configuration:
itemName: Xiaomi_Mijia_BT_HT_Medienzimmer_hum
- id: "4"
configuration:
itemName: Xiaomi_Mijia_BT_HT_Medienzimmer_tempc
conditions: []
actions:
- inputs: {}
configuration:
blockSource: <xml xmlns="https://developers.google.com/blockly/xml"><block
type="oh_event" id="qA6u)ERLw^I3,68Pk%+[" x="628" y="273"><field
name="eventType">postUpdate</field><value name="value"><shadow
type="text" id="/~p}{@Q[*DmIjWClf_s}"><field
name="TEXT">value</field></shadow><block type="oh_zdt_now"
id="PB7r@p?`WVVQzIl}NuCj"></block></value><value name="itemName"><shadow
type="oh_item" id="d%*[qdq?3OvZ}iNNub,U"><field
name="itemName">Xiaomi_Mijia_BT_HT_Medienzimmer_last_seen</field></shadow></value></block></xml>
type: application/javascript
script: >
var dtf = Java.type("java.time.format.DateTimeFormatter");
var zdt = Java.type("java.time.ZonedDateTime");
function getZonedDateTime(datetime) {
datetime = String(datetime).replace('T', ' ')
var regex_time_min = /^\d{2}:\d{2}$/;
var regex_time_sec = /^\d{2}:\d{2}:\d{2}$/;
var regex_date = /^\d{4}-\d{2}-\d{2}$/;
var regex_date_time_min = /^\d{4}-\d{2}-\d{2} \d{2}:\d{2}$/;
var regex_date_time_sec = /^\d{4}-\d{2}-\d{2} \d{2}:\d{2}:\d{2}$/;
var regex_date_time_sec_tz = /^\d{4}-\d{2}-\d{2}[T ]\d{2}:\d{2}:\d{2}[+-]\d{2}:\d{2}$/;
var regex_date_time_ms = /^\d{4}-\d{2}-\d{2}[T ]\d{2}:\d{2}:\d{2}\.\d{3}$/;
var regex_date_time_us = /^\d{4}-\d{2}-\d{2}[T ]\d{2}:\d{2}:\d{2}\.\d{6}$/;
var regex_date_time_ms_tz = /^\d{4}-\d{2}-\d{2}[T ]\d{2}:\d{2}:\d{2}\.\d{3}[+-]\d{2}:\d{2}$/;
var regex_date_time_us_tz = /^\d{4}-\d{2}-\d{2}[T ]\d{2}:\d{2}:\d{2}\.\d{6}[+-]\d{2}:\d{2}$/;
var regex_oh = /^\d{4}-\d{2}-\d{2}[T ]\d{2}:\d{2}:\d{2}\.\d{3}[+-]\d{4}$/;
var now = zdt.now();
var now_year = now.getYear();
var now_month = now.getMonthValue();
var now_day = now.getDayOfMonth();
var today = '' + now_year;
today += '-' + ('0' + now_month).slice(-2);
today += '-' + ('0' + now_day).slice(-2)+' ';
switch (true) {
case regex_time_min.test(datetime): return zdt.parse(today + datetime + ':00+00:00', dtf.ofPattern('yyyy-MM-dd HH:mm:ssz'));
case regex_time_sec.test(datetime): return zdt.parse(today + datetime + '+00:00', dtf.ofPattern('yyyy-MM-dd HH:mm:ssz'));
case regex_date.test(datetime): return zdt.parse(datetime + ' 00:00:00+00:00', dtf.ofPattern('yyyy-MM-dd HH:mm:ssz'));
case regex_date_time_min.test(datetime): return zdt.parse(datetime + ':00+00:00', dtf.ofPattern('yyyy-MM-dd HH:mm:ssz'));
case regex_date_time_sec.test(datetime): return zdt.parse(datetime + '+00:00', dtf.ofPattern('yyyy-MM-dd HH:mm:ssz'));
case regex_date_time_sec_tz.test(datetime): return zdt.parse(datetime, dtf.ofPattern('yyyy-MM-dd HH:mm:ssz'));
case regex_date_time_ms.test(datetime): return zdt.parse(datetime + ' +00:00', dtf.ofPattern('yyyy-MM-dd HH:mm:ss.SSS z'));
case regex_date_time_us.test(datetime): return zdt.parse(datetime + ' +00:00', dtf.ofPattern('yyyy-MM-dd HH:mm:ss.SSSSSS z'));
case regex_date_time_ms_tz.test(datetime): return zdt.parse(datetime, dtf.ofPattern('yyyy-MM-dd HH:mm:ss.SSSSz'));
case regex_date_time_us_tz.test(datetime): return zdt.parse(datetime, dtf.ofPattern('yyyy-MM-dd HH:mm:ss.SSSSSSSz'));
case regex_oh.test(datetime): return zdt.parse(datetime.slice(0,26) + ':' + datetime.slice(26,28), dtf.ofPattern('yyyy-MM-dd HH:mm:ss.SSSSz'));
default: return zdt.parse(datetime);
function createZonedDateTime(year, month, day, hour, minute, second, nano, offsetString, timezoneString) {
stringToParse = '' + year;
stringToParse += '-' + ('0' + month).slice(-2);
stringToParse += '-' + ('0' + day).slice(-2);
stringToParse += 'T' + ('0' + hour).slice(-2);
stringToParse += ':' + ('0' + minute).slice(-2);
stringToParse += ':' + ('0' + second).slice(-2);
stringToParse += '.' + nano + offsetString + '[' + timezoneString + ']';
return zdt.parse(stringToParse, dtf.ISO_ZONED_DATE_TIME);
events.postUpdate('Xiaomi_Mijia_BT_HT_Medienzimmer_last_seen', (zdt.now()));
type: script.ScriptAction
