[Solved] Can no longer access any UI after upgrade
After upgrading openhab build #1149 to the latest build “openHAB 2.3.0~20171226033518-1 (Build #1151)”. I can no longer get to any UI and myopenhab.org reports that openhab is offline. Yet when I run "sudo systemctl status openhab2.service"
I get this.
openhab2.service - openHAB 2 - empowering the smart home
   Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor pre
   Active: active (running) since Tue 2017-12-26 13:20:29 EST; 1h 41min ago
     Docs: http://docs.openhab.org
           https://community.openhab.org
 Main PID: 538 (java)
   CGroup: /system.slice/openhab2.service
           ââ538 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf
Dec 26 13:20:29 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart
Any help with this would be greatly appreciated.
post some logs so others may assist you better
Also it would be good if you could run a list command from karaf console to see what modules are Active/Resolved etc.
Ok. Whats the easiest way to post the large log files. The two log files are about 20mb together. I tried to upload them as a rar file but that didn’t work. Also changed the file extensions to XML but that didn’t work either. When I try to login to the karaf console I get this response.
Ernie@Universe MINGW64 //OPENHABIANPI/openHAB-log
$ ssh openhab@192.168.1.189 -p 8101
ssh: connect to host 192.168.1.189 port 8101: Connection refused
Alright, this is the last few 100 or so lines of the openhab.log. I can already see that this was probably older than build #1149.
2017-12-23 10:43:40.199 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2017-12-23 10:43:41.408 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2017-12-23 10:43:41.432 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:sun:home every 60 seconds
2017-12-23 10:45:06.855 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.sitemap'
2017-12-23 10:45:06.917 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home.sitemap' is either empty or cannot be parsed correctly!
2017-12-23 10:45:06.932 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.sitemap'
2017-12-23 10:50:42.463 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.sitemap'
2017-12-23 10:50:42.517 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home.sitemap' is either empty or cannot be parsed correctly!
2017-12-23 10:50:42.520 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.sitemap'
2017-12-23 10:50:45.635 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2017-12-23 10:50:45.996 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2017-12-23 10:50:46.275 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2017-12-23 10:50:47.156 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2017-12-23 10:50:47.261 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:sun:home every 60 seconds
2017-12-23 10:51:45.548 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2017-12-23 10:51:45.840 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2017-12-23 10:51:46.107 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2017-12-23 10:51:46.907 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2017-12-23 10:51:46.946 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:sun:home every 60 seconds
2017-12-23 10:53:56.094 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.sitemap'
2017-12-23 10:53:56.149 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.sitemap'
2017-12-23 11:02:26.278 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2017-12-23 11:02:26.610 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2017-12-23 11:02:26.962 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2017-12-23 11:02:27.976 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2017-12-23 11:02:28.048 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:sun:home every 60 seconds
2017-12-23 12:36:19.619 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:socket:Socket-1_0-221610K0101BE3': Could not call WeMo
2017-12-23 12:56:21.898 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:socket:Socket-1_0-221610K0101BE3': Could not call WeMo
2017-12-23 12:56:22.734 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:lightswitch:Lightswitch-1_0-221703K13015B5': Could not call WeMo
2017-12-23 12:58:22.764 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:lightswitch:Lightswitch-1_0-221703K13015B5': Could not call WeMo
2017-12-23 14:13:37.164 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while reading
java.net.SocketException: Connection reset
	at java.net.SocketInputStream.read(SocketInputStream.java:210) [?:?]
	at java.net.SocketInputStream.read(SocketInputStream.java:141) [?:?]
	at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) [?:?]
	at sun.security.ssl.InputRecord.read(InputRecord.java:503) [?:?]
	at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) [?:?]
	at sun.security.ssl.SSLSocketImpl.readDataRecord(SSLSocketImpl.java:940) [?:?]
	at sun.security.ssl.AppInputStream.read(AppInputStream.java:105) [?:?]
	at sun.security.ssl.AppInputStream.read(AppInputStream.java:71) [?:?]
	at su.litvak.chromecast.api.v2.Channel.read(Channel.java:411) [239:org.openhab.binding.chromecast:2.3.0.201712221545]
	at su.litvak.chromecast.api.v2.Channel.access$200(Channel.java:50) [239:org.openhab.binding.chromecast:2.3.0.201712221545]
	at su.litvak.chromecast.api.v2.Channel$ReadThread.run(Channel.java:132) [239:org.openhab.binding.chromecast:2.3.0.201712221545]
2017-12-23 14:13:37.170 [WARN ] [su.litvak.chromecast.api.v2.Channel ] -  <--  null payload in message
2017-12-23 15:28:26.105 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:socket:Socket-1_0-221610K0101BE3': Could not call WeMo
2017-12-23 16:01:48.454 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2017-12-23 16:01:48.822 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2017-12-23 16:01:49.156 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.items'
2017-12-23 16:01:50.063 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2017-12-23 16:01:50.093 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:sun:home every 60 seconds
2017-12-23 20:53:49.887 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 3146099 failed: null
2017-12-23 20:56:26.728 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 3146848 failed: null
2017-12-23 21:11:33.614 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2017-12-23 21:11:33.662 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 203f8322-5ff7-429b-88a6-aff1f8352601, base URL = http://localhost:8080)
2017-12-23 21:11:34.786 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 203f8322-5ff7-429b-88a6-aff1f8352601, base URL = http://localhost:8080)
2017-12-23 21:15:17.718 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2017-12-23 21:15:17.755 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 203f8322-5ff7-429b-88a6-aff1f8352601, base URL = http://localhost:8080)
2017-12-23 21:15:18.935 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 203f8322-5ff7-429b-88a6-aff1f8352601, base URL = http://localhost:8080)
2017-12-23 21:16:33.905 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:socket:Socket-1_0-221610K0101BE3': Could not call WeMo
2017-12-23 22:27:53.015 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@a5c3cd' takes more than 5000ms.
2017-12-23 22:29:08.045 [ERROR] [org.influxdb.impl.BatchProcessor    ] - Batch could not be sent. Data will be lost
java.lang.RuntimeException: {"error":"timeout"}
	at org.influxdb.impl.InfluxDBErrorHandler.handleError(InfluxDBErrorHandler.java:19) [246:org.openhab.persistence.influxdb:1.12.0.201712210210]
	at retrofit.RestAdapter$RestHandler.invoke(RestAdapter.java:242) [246:org.openhab.persistence.influxdb:1.12.0.201712210210]
	at org.influxdb.impl.$Proxy163.writePoints(Unknown Source) [246:org.openhab.persistence.influxdb:1.12.0.201712210210]
	at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:151) [246:org.openhab.persistence.influxdb:1.12.0.201712210210]
	at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:171) [246:org.openhab.persistence.influxdb:1.12.0.201712210210]
	at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:144) [246:org.openhab.persistence.influxdb:1.12.0.201712210210]
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
2017-12-23 22:29:09.325 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@a5c3cd' takes more than 5000ms.
2017-12-24 00:00:30.053 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:local
2017-12-24 00:00:30.160 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:home
2017-12-24 00:00:30.160 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:e3b86a44
2017-12-24 00:00:30.199 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2017-12-24 00:20:29.254 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@a5c3cd' takes more than 5000ms.
2017-12-24 00:20:32.578 [ERROR] [org.influxdb.impl.BatchProcessor    ] - Batch could not be sent. Data will be lost
2017-12-24 02:31:49.946 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 2: Already processed another send data request for this callback Id, ignoring.
2017-12-24 03:35:48.612 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while reading
2017-12-24 03:35:48.616 [WARN ] [su.litvak.chromecast.api.v2.Channel ] -  <--  null payload in message
2017-12-24 07:00:45.339 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:socket:Socket-1_0-221610K0101BE3': Could not call WeMo
2017-12-24 07:29:35.780 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 3403498 failed: null
2017-12-24 08:08:52.185 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:lightswitch:Lightswitch-1_0-221703K13015B5': Could not call WeMo
2017-12-24 09:20:49.399 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:socket:Socket-1_0-221610K0101BE3': Could not call WeMo
2017-12-24 09:20:54.123 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:lightswitch:Lightswitch-1_0-221703K13015B5': Could not call WeMo
2017-12-24 14:18:25.678 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 4: Already processed another send data request for this callback Id, ignoring.
2017-12-24 15:22:57.249 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:socket:Socket-1_0-221610K0101BE3': Could not call WeMo
2017-12-24 15:23:04.795 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:lightswitch:Lightswitch-1_0-221703K13015B5': Could not call WeMo
2017-12-24 16:11:07.697 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:lightswitch:Lightswitch-1_0-221703K13015B5': Could not call WeMo
2017-12-24 16:18:25.686 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 4: Already processed another send data request for this callback Id, ignoring.
2017-12-24 21:59:05.034 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:socket:Socket-1_0-221610K0101BE3': Could not call WeMo
2017-12-24 21:59:18.458 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:lightswitch:Lightswitch-1_0-221703K13015B5': Could not call WeMo
2017-12-24 21:59:19.581 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to send command 'ON' for device 'wemo:lightswitch:Lightswitch-1_0-221703K13015B5': Could not call WeMo
2017-12-25 00:00:30.075 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:local
2017-12-25 00:00:30.158 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:home
2017-12-25 00:00:30.207 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2017-12-25 00:00:30.267 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:e3b86a44
2017-12-25 00:27:23.706 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:lightswitch:Lightswitch-1_0-221703K13015B5': Could not call WeMo
2017-12-25 02:35:11.525 [ERROR] [org.influxdb.impl.BatchProcessor    ] - Batch could not be sent. Data will be lost
2017-12-25 02:35:21.810 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@a5c3cd' takes more than 5000ms.
2017-12-25 03:33:39.010 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while reading
2017-12-25 03:33:39.024 [WARN ] [su.litvak.chromecast.api.v2.Channel ] -  <--  null payload in message
2017-12-25 07:03:35.983 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:lightswitch:Lightswitch-1_0-221703K13015B5': Could not call WeMo
2017-12-25 12:57:44.672 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:lightswitch:Lightswitch-1_0-221703K13015B5': Could not call WeMo
2017-12-25 13:18:25.703 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 4: Already processed another send data request for this callback Id, ignoring.
2017-12-25 14:18:25.672 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 4: Already processed another send data request for this callback Id, ignoring.
2017-12-25 18:18:25.680 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 4: Already processed another send data request for this callback Id, ignoring.
2017-12-25 22:18:25.638 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 4: Already processed another send data request for this callback Id, ignoring.
2017-12-25 23:01:51.204 [WARN ] [ssage.ApplicationCommandMessageClass] - NODE 0: Not initialized yet, ignoring message.
2017-12-25 23:10:03.103 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:lightswitch:Lightswitch-1_0-221703K13015B5': Could not call WeMo
2017-12-26 00:00:30.058 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:local
2017-12-26 00:00:30.120 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:home
2017-12-26 00:00:30.165 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:home
2017-12-26 00:00:30.221 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:e3b86a44
2017-12-26 01:48:25.696 [WARN ] [l.serialmessage.SendDataMessageClass] - NODE 4: Already processed another send data request for this callback Id, ignoring.
2017-12-26 02:07:35.039 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while reading
2017-12-26 02:07:35.048 [WARN ] [su.litvak.chromecast.api.v2.Channel ] -  <--  null payload in message
2017-12-26 04:20:09.872 [ERROR] [ome.binding.wemo.handler.WemoHandler] - Failed to get actual state for device 'wemo:lightswitch:Lightswitch-1_0-221703K13015B5': Could not call WeMo
2017-12-26 08:13:16.393 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while reading
java.net.SocketException: Socket closed
	at java.net.SocketInputStream.socketRead0(Native Method) ~[?:?]
	at java.net.SocketInputStream.socketRead(SocketInputStream.java:116) [?:?]
	at java.net.SocketInputStream.read(SocketInputStream.java:171) [?:?]
2017-12-26 08:13:16.399 [WARN ] [su.litvak.chromecast.api.v2.Channel ] -  <--  null payload in message
2017-12-26 08:13:16.401 [WARN ] [su.litvak.chromecast.api.v2.Channel ] - Error while closing channel
2017-12-26 08:13:16.779 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2017-12-26 08:13:46.071 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2017-12-26 08:13:46.830 [INFO ] [penhab.io.transport.mqtt.MqttService] - Stopping broker connection 'broker'
2017-12-26 08:13:46.975 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2017-12-26 08:13:46.989 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 203f8322-5ff7-429b-88a6-aff1f8352601, base URL = http://localhost:8080)
2017-12-26 08:13:47.329 [INFO ] [assic.internal.servlet.WebAppServlet] - Stopped Classic UI
2017-12-26 08:13:47.406 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Stopped HABmin servlet
2017-12-26 08:13:48.489 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2017-12-26 08:13:48.519 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2017-12-26 08:13:48.533 [INFO ] [er.internal.HomeBuilderDashboardTile] - Stopped Home Builder
2017-12-26 08:13:48.557 [INFO ] [.dashboard.internal.DashboardService] - Stopped dashboard
Here are the last 100 lines of the events.log
2017-12-26 08:13:42.539 [hingStatusInfoChangedEvent] - 'network:device:192_168_1_138' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-12-26 08:13:42.554 [hingStatusInfoChangedEvent] - 'network:device:192_168_1_145' changed from ONLINE to UNINITIALIZED
2017-12-26 08:13:42.558 [hingStatusInfoChangedEvent] - 'network:device:192_168_1_145' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-12-26 08:13:42.560 [hingStatusInfoChangedEvent] - 'network:pingdevice:192_168_1_201' changed from ONLINE to UNINITIALIZED
2017-12-26 08:13:42.564 [hingStatusInfoChangedEvent] - 'network:pingdevice:192_168_1_201' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-12-26 08:13:42.568 [hingStatusInfoChangedEvent] - 'network:device:192_168_1_158' changed from ONLINE to UNINITIALIZED
2017-12-26 08:13:42.571 [hingStatusInfoChangedEvent] - 'network:device:192_168_1_158' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-12-26 08:13:42.575 [hingStatusInfoChangedEvent] - 'network:device:192_168_1_254' changed from ONLINE to UNINITIALIZED
2017-12-26 08:13:42.580 [hingStatusInfoChangedEvent] - 'network:device:192_168_1_254' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-12-26 08:13:42.613 [hingStatusInfoChangedEvent] - 'zwave:device:cf804f41:node2' changed from ONLINE to UNINITIALIZED
2017-12-26 08:13:42.799 [hingStatusInfoChangedEvent] - 'zwave:device:cf804f41:node2' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-12-26 08:13:42.815 [hingStatusInfoChangedEvent] - 'zwave:device:cf804f41:node4' changed from ONLINE to UNINITIALIZED
2017-12-26 08:13:42.908 [hingStatusInfoChangedEvent] - 'zwave:device:cf804f41:node4' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-12-26 08:13:42.911 [hingStatusInfoChangedEvent] - 'zwave:device:cf804f41:node3' changed from ONLINE to UNINITIALIZED
2017-12-26 08:13:42.987 [hingStatusInfoChangedEvent] - 'zwave:device:cf804f41:node3' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-12-26 08:13:42.990 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:cf804f41' changed from ONLINE to UNINITIALIZED
2017-12-26 08:13:46.089 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:cf804f41' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-12-26 08:13:47.579 [temChannelLinkRemovedEvent] - Link 'GoogleHome_Volume => chromecast:chromecast:302300fab00885902cc5ac68eafd4303:volume' has been removed.
2017-12-26 08:13:47.582 [temChannelLinkRemovedEvent] - Link 'LR_FoyerLight => zwave:device:cf804f41:node4:switch_dimmer' has been removed.
2017-12-26 08:13:47.585 [temChannelLinkRemovedEvent] - Link 'FrontDoorLight => zwave:device:cf804f41:node3:switch_binary' has been removed.
2017-12-26 08:13:47.589 [temChannelLinkRemovedEvent] - Link 'OutSideGarageLight => zwave:device:cf804f41:node2:switch_binary' has been removed.
2017-12-26 08:13:47.604 [temChannelLinkRemovedEvent] - Link 'ChandlierLight => wemo:lightswitch:Lightswitch-1_0-221703K13015B5:state' has been removed.
2017-12-26 08:13:47.609 [temChannelLinkRemovedEvent] - Link 'LR_FoyerDimmer => zwave:device:cf804f41:node4:switch_dimmer' has been removed.
2017-12-26 08:13:47.612 [temChannelLinkRemovedEvent] - Link 'Light1_Toggle => hue:0100:00178868036d:1:brightness' has been removed.
2017-12-26 08:13:47.614 [temChannelLinkRemovedEvent] - Link 'Light1_Dimmer => hue:0100:00178868036d:1:brightness' has been removed.
2017-12-26 08:13:47.616 [temChannelLinkRemovedEvent] - Link 'Light2_Toggle => hue:0100:00178868036d:2:brightness' has been removed.
2017-12-26 08:13:47.618 [temChannelLinkRemovedEvent] - Link 'Light2_Dimmer => hue:0100:00178868036d:2:brightness' has been removed.
2017-12-26 08:13:47.621 [temChannelLinkRemovedEvent] - Link 'Light3_Toggle => hue:0100:00178868036d:3:brightness' has been removed.
2017-12-26 08:13:47.623 [temChannelLinkRemovedEvent] - Link 'Light3_Dimmer => hue:0100:00178868036d:3:brightness' has been removed.
2017-12-26 08:13:47.625 [temChannelLinkRemovedEvent] - Link 'Light4_Toggle => hue:0100:00178868036d:4:brightness' has been removed.
2017-12-26 08:13:47.628 [temChannelLinkRemovedEvent] - Link 'Light4_Dimmer => hue:0100:00178868036d:4:brightness' has been removed.
2017-12-26 08:13:47.635 [temChannelLinkRemovedEvent] - Link 'Light5_Toggle => hue:0100:00178868036d:5:brightness' has been removed.
2017-12-26 08:13:47.636 [temChannelLinkRemovedEvent] - Link 'Light5_Dimmer => hue:0100:00178868036d:5:brightness' has been removed.
2017-12-26 08:13:47.639 [temChannelLinkRemovedEvent] - Link 'Light6_Toggle => hue:0100:00178868036d:6:brightness' has been removed.
2017-12-26 08:13:47.641 [temChannelLinkRemovedEvent] - Link 'Light6_Dimmer => hue:0100:00178868036d:6:brightness' has been removed.
2017-12-26 08:13:47.644 [temChannelLinkRemovedEvent] - Link 'SunsetTime => astro:sun:home:set#start' has been removed.
2017-12-26 08:13:47.646 [temChannelLinkRemovedEvent] - Link 'SunriseTime => astro:sun:home:rise#start' has been removed.
2017-12-26 08:13:47.649 [temChannelLinkRemovedEvent] - Link 'SunElevation => astro:sun:home:position#elevation' has been removed.
2017-12-26 08:13:47.651 [temChannelLinkRemovedEvent] - Link 'Date => ntp:ntp:local:dateTime' has been removed.
2017-12-26 08:13:47.654 [temChannelLinkRemovedEvent] - Link 'Time => ntp:ntp:local:dateTime' has been removed.
2017-12-26 08:13:47.656 [temChannelLinkRemovedEvent] - Link 'Conditions => weatherunderground:weather:CDG:current#conditions' has been removed.
2017-12-26 08:13:47.658 [temChannelLinkRemovedEvent] - Link 'Icon => weatherunderground:weather:CDG:current#icon' has been removed.
2017-12-26 08:13:47.661 [temChannelLinkRemovedEvent] - Link 'ObservationTime => weatherunderground:weather:CDG:current#observationTime' has been removed.
2017-12-26 08:13:47.663 [temChannelLinkRemovedEvent] - Link 'ObservationLocation => weatherunderground:weather:CDG:current#location' has been removed.
2017-12-26 08:13:47.666 [temChannelLinkRemovedEvent] - Link 'Station => weatherunderground:weather:CDG:current#stationId' has been removed.
2017-12-26 08:13:47.669 [temChannelLinkRemovedEvent] - Link 'Temperature => weatherunderground:weather:CDG:current#temperature' has been removed.
2017-12-26 08:13:47.672 [temChannelLinkRemovedEvent] - Link 'FeelTemp => weatherunderground:weather:CDG:current#feelingTemperature' has been removed.
2017-12-26 08:13:47.674 [temChannelLinkRemovedEvent] - Link 'Humidity => weatherunderground:weather:CDG:current#relativeHumidity' has been removed.
2017-12-26 08:13:47.675 [temChannelLinkRemovedEvent] - Link 'Pressure => weatherunderground:weather:CDG:current#pressure' has been removed.
2017-12-26 08:13:47.678 [temChannelLinkRemovedEvent] - Link 'RainD => weatherunderground:weather:CDG:current#precipitationDay' has been removed.
2017-12-26 08:13:47.679 [temChannelLinkRemovedEvent] - Link 'RainH => weatherunderground:weather:CDG:current#precipitationHour' has been removed.
2017-12-26 08:13:47.681 [temChannelLinkRemovedEvent] - Link 'WindDirection => weatherunderground:weather:CDG:current#windDirection' has been removed.
2017-12-26 08:13:47.683 [temChannelLinkRemovedEvent] - Link 'WindDirection2 => weatherunderground:weather:CDG:current#windDirectionDegrees' has been removed.
2017-12-26 08:13:47.686 [temChannelLinkRemovedEvent] - Link 'WindSpeed => weatherunderground:weather:CDG:current#windSpeed' has been removed.
2017-12-26 08:13:47.688 [temChannelLinkRemovedEvent] - Link 'WindGust => weatherunderground:weather:CDG:current#windGust' has been removed.
2017-12-26 08:13:47.690 [temChannelLinkRemovedEvent] - Link 'DewPoint => weatherunderground:weather:CDG:current#dewPoint' has been removed.
2017-12-26 08:13:47.692 [temChannelLinkRemovedEvent] - Link 'HeatIndex => weatherunderground:weather:CDG:current#heatIndex' has been removed.
2017-12-26 08:13:47.695 [temChannelLinkRemovedEvent] - Link 'WindChill => weatherunderground:weather:CDG:current#windChill' has been removed.
2017-12-26 08:13:47.697 [temChannelLinkRemovedEvent] - Link 'Visibility => weatherunderground:weather:CDG:current#visibility' has been removed.
2017-12-26 08:13:47.699 [temChannelLinkRemovedEvent] - Link 'SolarRadiation => weatherunderground:weather:CDG:current#solarRadiation' has been removed.
2017-12-26 08:13:47.702 [temChannelLinkRemovedEvent] - Link 'UV => weatherunderground:weather:CDG:current#UVIndex' has been removed.
2017-12-26 08:13:47.704 [temChannelLinkRemovedEvent] - Link 'ForecastTime => weatherunderground:weather:CDG:forecastToday#forecastTime' has been removed.
2017-12-26 08:13:47.706 [temChannelLinkRemovedEvent] - Link 'ForecastTime1 => weatherunderground:weather:CDG:forecastTomorrow#forecastTime' has been removed.
2017-12-26 08:13:47.709 [temChannelLinkRemovedEvent] - Link 'ForecastTime2 => weatherunderground:weather:CDG:forecastDay2#forecastTime' has been removed.
2017-12-26 08:13:47.711 [temChannelLinkRemovedEvent] - Link 'ForecastCondition => weatherunderground:weather:CDG:forecastToday#conditions' has been removed.
2017-12-26 08:13:47.713 [temChannelLinkRemovedEvent] - Link 'ForecastCondition1 => weatherunderground:weather:CDG:forecastTomorrow#conditions' has been removed.
2017-12-26 08:13:47.715 [temChannelLinkRemovedEvent] - Link 'ForecastCondition2 => weatherunderground:weather:CDG:forecastDay2#conditions' has been removed.
2017-12-26 08:13:47.718 [temChannelLinkRemovedEvent] - Link 'ForecastIcon => weatherunderground:weather:CDG:forecastToday#icon' has been removed.
2017-12-26 08:13:47.720 [temChannelLinkRemovedEvent] - Link 'ForecastTempMin => weatherunderground:weather:CDG:forecastToday#minTemperature' has been removed.
2017-12-26 08:13:47.723 [temChannelLinkRemovedEvent] - Link 'ForecastTempMax => weatherunderground:weather:CDG:forecastToday#maxTemperature' has been removed.
2017-12-26 08:13:47.725 [temChannelLinkRemovedEvent] - Link 'ForecastTempMin1 => weatherunderground:weather:CDG:forecastTomorrow#minTemperature' has been removed.
2017-12-26 08:13:47.727 [temChannelLinkRemovedEvent] - Link 'ForecastTempMax1 => weatherunderground:weather:CDG:forecastTomorrow#maxTemperature' has been removed.
2017-12-26 08:13:47.729 [temChannelLinkRemovedEvent] - Link 'ForecastTempMin2 => weatherunderground:weather:CDG:forecastDay2#minTemperature' has been removed.
2017-12-26 08:13:47.732 [temChannelLinkRemovedEvent] - Link 'ForecastTempMax2 => weatherunderground:weather:CDG:forecastDay2#maxTemperature' has been removed.
2017-12-26 08:13:47.735 [temChannelLinkRemovedEvent] - Link 'ForecastHumidity => weatherunderground:weather:CDG:forecastToday#relativeHumidity' has been removed.
2017-12-26 08:13:47.738 [temChannelLinkRemovedEvent] - Link 'ForecastProbaPrecip => weatherunderground:weather:CDG:forecastToday#probaPrecipitation' has been removed.
2017-12-26 08:13:47.741 [temChannelLinkRemovedEvent] - Link 'ForecastRain => weatherunderground:weather:CDG:forecastToday#precipitationDay' has been removed.
2017-12-26 08:13:47.743 [temChannelLinkRemovedEvent] - Link 'ForecastSnow => weatherunderground:weather:CDG:forecastToday#snow' has been removed.
2017-12-26 08:13:47.745 [temChannelLinkRemovedEvent] - Link 'ForecastMaxWindDirection => weatherunderground:weather:CDG:forecastToday#maxWindDirection' has been removed.
2017-12-26 08:13:47.748 [temChannelLinkRemovedEvent] - Link 'ForecastMaxWindDirection2 => weatherunderground:weather:CDG:forecastToday#maxWindDirectionDegrees' has been removed.
2017-12-26 08:13:47.750 [temChannelLinkRemovedEvent] - Link 'ForecastMaxWindSpeed => weatherunderground:weather:CDG:forecastToday#maxWindSpeed' has been removed.
2017-12-26 08:13:47.752 [temChannelLinkRemovedEvent] - Link 'ForecastAvgWindDirection => weatherunderground:weather:CDG:forecastToday#averageWindDirection' has been removed.
2017-12-26 08:13:47.755 [temChannelLinkRemovedEvent] - Link 'ForecastAvgWindDirection2 => weatherunderground:weather:CDG:forecastToday#averageWindDirectionDegrees' has been removed.
2017-12-26 08:13:47.758 [temChannelLinkRemovedEvent] - Link 'ForecastAvgWindSpeed => weatherunderground:weather:CDG:forecastToday#averageWindSpeed' has been removed.
2017-12-26 08:13:47.760 [.event.RuleStatusInfoEvent] - c680ad91-2f92-49a8-8c65-ccda9e112079 updated: UNINITIALIZED (HANDLER_MISSING_ERROR): Missing handlers: core.ItemStateCondition, core.ItemCommandAction
2017-12-26 08:13:47.763 [.event.RuleStatusInfoEvent] - 593a95d6-fc34-46c4-a4f0-d07345c26f7f updated: UNINITIALIZED (HANDLER_MISSING_ERROR): Missing handlers: core.ItemStateChangeTrigger, core.ItemStateCondition, core.ItemCommandAction
2017-12-26 08:13:47.941 [temChannelLinkRemovedEvent] - Link 'ForecastTempMin => weatherunderground:weather:86501f00:forecastToday#minTemperature' has been removed.
2017-12-26 08:13:47.943 [temChannelLinkRemovedEvent] - Link 'SunriseTime => astro:sun:e3b86a44:rise#start' has been removed.
2017-12-26 08:13:47.945 [temChannelLinkRemovedEvent] - Link 'GoogleHome_Online => network:pingdevice:192_168_1_201:online' has been removed.
2017-12-26 08:13:47.948 [temChannelLinkRemovedEvent] - Link 'Conditions => weatherunderground:weather:86501f00:current#conditions' has been removed.
2017-12-26 08:13:47.950 [temChannelLinkRemovedEvent] - Link 'ForecastTempMax => weatherunderground:weather:86501f00:forecastToday#maxTemperature' has been removed.
2017-12-26 08:13:47.952 [temChannelLinkRemovedEvent] - Link 'Light4_Dimmer => hue:0100:1:4:brightness' has been removed.
2017-12-26 08:13:47.955 [temChannelLinkRemovedEvent] - Link 'AstroSunData_Set_StartTime => astro:sun:e3b86a44:set#start' has been removed.
2017-12-26 08:13:47.957 [temChannelLinkRemovedEvent] - Link 'LR_FoyerOutLet1 => wemo:socket:Socket-1_0-221610K0101BE3:state' has been removed.
2017-12-26 08:13:47.959 [temChannelLinkRemovedEvent] - Link 'Humidity => weatherunderground:weather:86501f00:current#relativeHumidity' has been removed.
2017-12-26 08:13:47.961 [temChannelLinkRemovedEvent] - Link 'Pressure => weatherunderground:weather:86501f00:current#pressure' has been removed.
2017-12-26 08:13:47.964 [temChannelLinkRemovedEvent] - Link 'Light4_Toggle => hue:0100:1:4:brightness' has been removed.
2017-12-26 08:13:47.966 [temChannelLinkRemovedEvent] - Link 'SamsungTV => samsungtv:tv:0c845880_00d2_1000_abb6_f47b5e74f2e1:power' has been removed.
2017-12-26 08:13:47.969 [temChannelLinkRemovedEvent] - Link 'LocalTime_Date => ntp:ntp:local:dateTime' has been removed.
2017-12-26 08:13:48.146 [ome.event.RuleRemovedEvent] - Rule '593a95d6-fc34-46c4-a4f0-d07345c26f7f' has been removed.
2017-12-26 08:13:48.149 [ome.event.RuleRemovedEvent] - Rule 'c680ad91-2f92-49a8-8c65-ccda9e112079' has been removed.
try this:
Som use DropBox linking for large files.
I normally sign in to Karaf console by issuing
$ ssh -p 8101 openhab@localhost
, but I guess 192.168.1.189 is the local host?
Alas, I don´t have any clever suggestions.
Ok, I went ahead and followed your suggestion but
no luck.
Sorry it did work, Thanks
Ok got in. Here is the list of bundles.
openhab> list
START LEVEL 100 , List Threshold: 50
 ID â State    â Lvl â Version                â Name
âââââ¼âââââââââââ¼ââââââ¼âââââââââââââââââââââââââ¼âââââââââââââââââââââââââââââââââ
 15 â Active   â  80 â 5.3.1.201602281253     â OSGi JAX-RS Connector
 16 â Active   â  80 â 2.4.5                  â Jackson-annotations
 17 â Active   â  80 â 2.4.5                  â Jackson-core
 18 â Active   â  80 â 2.4.5                  â jackson-databind
 19 â Active   â  80 â 2.4.5                  â Jackson-dataformat-XML
 20 â Active   â  80 â 2.4.5                  â Jackson-dataformat-YAML
 21 â Active   â  80 â 2.4.5                  â Jackson-module-JAXB-annotations
 22 â Active   â  80 â 2.7.0                  â Gson
 23 â Active   â  80 â 18.0.0                 â Guava: Google Core Libraries fo
 24 â Active   â  80 â 3.0.0.v201312141243    â Google Guice (No AOP)
 25 â Active   â  80 â 3.12.0.OH              â nrjavaserial
 26 â Active   â  80 â 1.5.8                  â swagger-annotations
 27 â Active   â  80 â 3.19.0.GA              â Javassist
 29 â Active   â  80 â 3.5.2                  â JmDNS
 32 â Active   â  80 â 1.1.0.Final            â Bean Validation API
 34 â Active   â  80 â 2.0.1                  â javax.ws.rs-api
 35 â Active   â  80 â 3.2.0.v201101311130    â ANTLR Runtime
 38 â Active   â  80 â 3.2.1                  â Commons Collections
 39 â Active   â  80 â 1.1                    â Commons Exec
 40 â Active   â  80 â 2.2.0                  â Commons IO
 41 â Active   â  80 â 2.6                    â Commons Lang
 51 â Active   â  80 â 4.1.3                  â Apache Karaf :: OSGi Services :
 70 â Active   â  80 â 2.11.0.v20150805-0538  â EMF Common
 71 â Active   â  80 â 2.11.1.v20150805-0538  â EMF Ecore
 72 â Active   â  80 â 2.11.1.v20150805-0538  â EMF XML/XMI Persistence
 73 â Active   â  80 â 3.8.0.v20160509-1230   â Common Eclipse Runtime
 74 â Active   â  80 â 3.6.100.v20160223-2218 â Extension Registry Support
101 â Active   â  80 â 0.2.1.v20170706-0855   â org.eclipse.lsp4j
102 â Active   â  80 â 0.2.1.v20170706-0855   â org.eclipse.lsp4j.jsonrpc
103 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Config Core
104 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Configuration
105 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Configuration
106 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Config Dispat
107 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Config Serial
108 â Active   â  75 â 0.10.0.201712141004    â Eclipse SmartHome Config XML
109 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Core
110 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Core Audio
111 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome AutoUpdate Bi
112 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Core Binding
113 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Core ID
114 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Core Persiste
115 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Scheduler Ser
116 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Core Thing
117 â Active   â  75 â 0.10.0.201712141004    â Eclipse SmartHome Core Thing XML
118 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Transformatio
119 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Core Voice
120 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Console
121 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Console for O
122 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome JavaSound I/O
123 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Monitor
124 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Net I/O Bundle
125 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome REST Interfac
126 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Core REST API
127 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome REST mDNS Ann
128 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome REST Interfac
129 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Sitemap REST
130 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome SSE REST API
131 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Voice REST API
132 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Bonjour/MDS S
133 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Web Audio Sup
134 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Model Core
135 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Item Model
136 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Item Model IDE
137 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Item Model Ru
138 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Language Serv
139 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Persistence M
140 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Persistence M
141 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Persistence R
142 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Rule Model
143 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Rule Model IDE
144 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Rule Runtime
145 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Script
146 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Script Model
147 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Script Runtime
148 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Sitemap Model
149 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Sitemap Model
150 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Sitemap Runti
151 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Thing Model
152 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Thing Model I
153 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Thing Model R
154 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Json Storage
155 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome UI
156 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome UI Icons
157 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Classic IconS
158 â Active   â  80 â 2.12.0.v20170518-0757  â Xtend Runtime Library
159 â Active   â  80 â 2.12.0.v20170518-0757  â Xtend Macro Interfaces
160 â Active   â  80 â 2.12.0.v20170518-0959  â Xtext
161 â Active   â  80 â 2.12.0.v20170519-0752  â Xtext Common Types
162 â Active   â  80 â 2.12.0.v20171017-1700  â Xtext IDE Core
163 â Active   â  80 â 2.12.0.v20170518-0959  â Xtext Utility
164 â Active   â  80 â 2.12.0.v20170519-0752  â Xbase Model
165 â Active   â  80 â 2.12.0.v20170519-0752  â Xbase Generic IDE Services
166 â Active   â  80 â 2.12.0.v20170518-0757  â Xbase Runtime Library
181 â Active   â  80 â 2.3.0                  â JUPnP Library
182 â Active   â  80 â 1.9.6                  â MIME streaming extension
183 â Active   â  80 â 5.0.2                  â Require-Bundle Fix :: org.objec
185 â Active   â  90 â 2.3.0.201712260145     â openHAB Core
186 â Active   â  80 â 2.3.0.201712260145     â openHAB Karaf Integration
188 â Resolved â  80 â 2.3.0.201712260145     â openHAB Sound Support, Hosts: 1
189 â Active   â  80 â 2.3.0.201712260145     â openHAB Dashboard UI
194 â Active   â  80 â 3.1.4                  â Stax2 API
195 â Active   â  80 â 1.6.0                  â Commons Codec
196 â Active   â  80 â 3.2.0                  â Commons Net
197 â Active   â  80 â 4.2.3                  â Apache HttpClient OSGi bundle
198 â Active   â  80 â 4.2.3                  â Apache HttpCore OSGi bundle
199 â Active   â  80 â 3.1.0.7                â Apache ServiceMix :: Bundles ::
200 â Active   â  80 â 2.3.0.201712260145     â openHAB 1.x Compatibility Layer
201 â Active   â  80 â 1.1.1.201605111122     â Swagger Provider
202 â Active   â  80 â 2.3.1                  â Gson
203 â Active   â  80 â 2.1.0                  â json-path
204 â Active   â  80 â 1.5.8                  â swagger-core
205 â Active   â  80 â 1.5.8                  â swagger-jaxrs
206 â Active   â  80 â 1.5.8                  â swagger-models
207 â Active   â  80 â 2.2                    â json-smart
208 â Active   â  80 â 3.4.0                  â Apache Commons Lang
209 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Automation API
210 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Automation co
211 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Automation Co
212 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Automation Mo
213 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Automation Me
214 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Automation Mo
215 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Automation Sc
216 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Automation Sc
217 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Automation Mo
218 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Automation GS
219 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Automation Pr
220 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Automation RE
221 â Active   â  80 â 0.10.0.201712141004    â Astro Binding
222 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome hue Binding
223 â Active   â  80 â 0.10.0.201712141004    â ntp Binding
224 â Active   â  80 â 0.10.0.201712141004    â WeatherUnderground Binding
225 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Wemo Binding
226 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Configuration
227 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome UPnP Transpor
228 â Active   â  75 â 0.10.0.201712141004    â Eclipse SmartHome Exec Transfor
229 â Active   â  75 â 0.10.0.201712141004    â Eclipse SmartHome JavaScript Tr
230 â Active   â  75 â 0.10.0.201712141004    â Eclipse SmartHome JSonPath Tran
231 â Active   â  75 â 0.10.0.201712141004    â Eclipse SmartHome Map Transform
232 â Active   â  75 â 0.10.0.201712141004    â Eclipse SmartHome RegEx Transfo
233 â Active   â  75 â 0.10.0.201712141004    â Eclipse SmartHome Scale Transfo
234 â Active   â  75 â 0.10.0.201712141004    â Eclipse SmartHome XPath Transfo
235 â Active   â  75 â 0.10.0.201712141004    â Eclipse SmartHome Xslt Transfor
236 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Basic UI, Fra
237 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome WebApp UI, Fr
238 â Active   â  80 â 0.10.0.201712141004    â Eclipse SmartHome Paper UI, Fra
239 â Active   â  80 â 2.3.0.201712260145     â Chromecast Binding
240 â Active   â  80 â 1.12.0.201712260210    â openHAB MQTT Binding
241 â Active   â  80 â 2.3.0.201712260145     â Network Binding
242 â Active   â  80 â 2.3.0.201712260145     â ZWave Binding
243 â Active   â  80 â 2.3.0.201712260145     â openHAB Cloud Connector Bundle
244 â Active   â  80 â 2.3.0.201712260145     â openHAB REST Documentation
245 â Active   â  80 â 1.12.0.201712260210    â openHAB MQTT Transport Bundle
246 â Active   â  80 â 1.12.0.201712260210    â openHAB InfluxDB Persistence bu
247 â Active   â  80 â 1.12.0.201712260210    â openHAB MapDB Persistence Bundle
248 â Resolved â  75 â 2.3.0.201712260145     â openHAB Basic UI Fragment, Host
249 â Resolved â  75 â 2.3.0.201712260145     â openHAB Classic UI Fragment, Ho
250 â Active   â  80 â 2.3.0.201712260145     â HABmin User Interface
251 â Active   â  80 â 2.3.0.201712260145     â HABPanel User Interface
252 â Active   â  80 â 2.3.0.201712260145     â HomeBuilder User Interface
253 â Resolved â  75 â 2.3.0.201712260145     â openHAB Paper UI Theme Fragment
254 â Active   â  80 â 0.9.10.v20160429-1435  â reflections (wrap)
255 â Active   â  80 â 1.5.8.v20160511-1038   â swagger-jersey2-jaxrs (wrap)
openhab>
Ok, I rebooted the Pi and OpenHab is online. Couldn’t do it without all the great suggestions. Thanks for all the help guys.
