Thanks I am going threw it, I will edit this post with my findings.
First
2019-12-20 00:42:09.656 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - transformation throws exception [transformation=org.eclipse.smarthome.transform.map.internal.MapTransformationService@1c1227b, value=NIGHT]
org.eclipse.smarthome.core.transform.TransformationException: An error occurred while opening file.
Caused by: java.io.FileNotFoundException: /etc/openhab2/transform/astro.map (No such file or directory)
File /etc/openhab2/transform/astro.map seems missing.
This error is spamming quite a lot.
PS: Looks like you are ahead of my time ![]()
I think this is a point where you restarted openHAB, right?
2019-12-20 12:04:55.911 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2019-12-20 12:05:02.671 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2019-12-20 12:05:02.708 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = , base URL = http://localhost:8080)
2019-12-20 12:05:02.948 [INFO ] [assic.internal.servlet.WebAppServlet] - Stopped Classic UI
2019-12-20 12:05:02.976 [INFO ] [b.core.service.AbstractActiveService] - Expire Refresh Service has been shut down
2019-12-20 12:05:03.013 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Stopped HABmin servlet
2019-12-20 12:05:04.086 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2019-12-20 12:05:04.134 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2019-12-20 12:05:04.215 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2019-12-20 12:05:50.192 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-12-20 12:05:50.303 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Asia/Kolkata'.
2019-12-20 12:05:50.317 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '17.4154514,78.5848738'.
2019-12-20 12:05:50.324 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_IN'.
2019-12-20 12:05:54.318 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = , base URL = http://localhost:8080)
2019-12-20 12:06:00.409 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'basic.items'
2019-12-20 12:06:00.715 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.items'
2019-12-20 12:06:04.741 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-12-20 12:06:05.402 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
2019-12-20 12:06:05.944 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'basic.things', using it anyway:
Provide a thing type ID and a thing ID in this format:
<thingTypeId> <thingId>
Your basic.things file has erros.
019-12-20 12:06:05.957 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'basic.things'
2019-12-20 12:06:06.229 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.things'
2019-12-20 12:06:07.369 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:sun:local
2019-12-20 12:06:07.519 [INFO ] [thome.binding.astro.internal.job.Job] - Scheduled Astro event-jobs for thing astro:moon:local
2019-12-20 12:06:07.541 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled Positional job astro:moon:local every 300 seconds
2019-12-20 12:06:07.647 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key astro:sun:local in ManagedThingProvider, because it does not exists.
2019-12-20 12:06:07.651 [WARN ] [mon.registry.AbstractManagedProvider] - Could not update element with key astro:moon:local in ManagedThingProvider, because it does not exists.
2019-12-20 12:06:08.493 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.31.53:8080
2019-12-20 12:06:08.498 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.31.53:8443
2019-12-20 12:06:09.851 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-12-20 12:06:09.986 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2019-12-20 12:06:10.343 [WARN ] [ore.common.registry.AbstractRegistry] - Cannot add "BridgeImpl" with key "mqtt:systemBroker:embedded-mqtt-broker". It exists already from provider "ManagedThingProvider"! Failed to add a second with the same UID from provider "GenericThingProvider"!
2019-12-20 12:06:11.352 [WARN ] [r.internal.EmbeddedBrokerServiceImpl] - Embedded broker offline - Reason unknown
2019-12-20 12:06:11.504 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '127.0.0.1' with clientid embedded-mqtt-broker and file store '/var/lib/openhab2/mqtt/127.0.0.1'
2019-12-20 12:06:11.599 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'expire' of item 'Livingroom_TV_Power' could not be parsed correctly.
org.eclipse.smarthome.model.item.BindingConfigParseException: The string '0' does not represent a valid state for item Livingroom_TV_Power
Web Server started.
This seems off, do you use an external mqtt broker and an embedded one? ![]()
Wrong state, you should investigate this.
TL;DR
You openHAB is starting and stopping quite a lot. (¿Bootloop?)
I would advice looking into the errors.
Did you try clearing the cache?
