Continuing the discussion from IpCamera: New IP Camera Binding:
Hello, I’m using a foscam FI9800P, but i can’t seem to get an image in openhab. Camera works fine in foscam app so i know this is not the problem. I get the following warning in the log:
2019-02-25 14:41:47.131 [WARN ] [ing.ipcamera.handler.IpCameraHandler] - SOAP error when trying to connect with ONVIF. This may indicate your camera does not fully support ONVIF, check for an updated firmware for your camera. Will try and connect with HTTP. Camera at IP:192.168.1.56, fault was com.sun.xml.internal.messaging.saaj.SOAPExceptionImpl: com.sun.xml.internal.messaging.saaj.SOAPExceptionImpl: Message send failed
. How can i find or set the portnumbers for ONVIF and HTTP? i scaned for open ports on fing app and used “accessbuilder”-port(888) for ONVIF and “https”-port(443) for port settings. Or am i missing something else? Cam FW is latest.
Thing file:
Thing ipcamera:FOSCAM:001 [ IPADDRESS="192.168.1.56", PASSWORD="xxxx", USERNAME="yyyy", ONVIF_PORT=888, PORT=443, POLL_CAMERA_MS=2000]
items file:
Image OpritCam { channel="ipcamera:FOSCAM:001:image" }
Switch OpritCamUpdateImage "Get new picture" { channel="ipcamera:FOSCAM:001:updateImageNow" }
Number OpritCamDirection "Camera Direction"
Dimmer OpritCamPan "Pan [%d] left/right" { channel="ipcamera:FOSCAM:001:pan" }
Dimmer OpritCamTilt "Tilt [%d] up/down" { channel="ipcamera:FOSCAM:001:tilt" }
Dimmer OpritCamZoom "Zoom [%d] in/out" { channel="ipcamera:FOSCAM:001:zoom" }
Switch OpritCamEnableMotion "MotionAlarm on/off" { channel="ipcamera:FOSCAM:001:enableMotionAlarm" }
Switch OpritCamMotionAlarm "Motion detected" { channel="ipcamera:FOSCAM:001:motionAlarm" }
Switch OpritCamEnableAudioAlarm "AudioAlarm on/off" { channel="ipcamera:FOSCAM:001:enableAudioAlarm" }
Switch OpritCamAudioAlarm "Audio detected" { channel="ipcamera:FOSCAM:001:audioAlarm" }
Dimmer OpritCamAudioThreshold "Audio Threshold [%d]" { channel="ipcamera:FOSCAM:001:thresholdAudioAlarm" }
Dimmer OpritCamLED "IR LED [%d]" { channel="ipcamera:FOSCAM:001:enableLED" }
Switch OpritCamAutoLED "Auto IR LED" { channel="ipcamera:FOSCAM:001:autoLED" }
String OpritCamTextOverlay "Text to overlay" { channel="ipcamera:FOSCAM:001:textOverlay" }
String OpritCamAPIAccess "Access the API" { channel="ipcamera:FOSCAM:001:apiAccess" }
String OpritCamVideoUrl "url" { channel="ipcamera:FOSCAM:001:videourl"}
Sitemap:
Text label="BabyMonitor" icon="camera"{
Text item=OpritCamVideoUrl label="string=[%s]"
Image url="http://google.com/leaveLinkAsThis" item=OpritCamImage refresh=2000
Switch item=OpritCamDirection icon=movecontrol label="Camera Direction" mappings=[0="Room", 1="Cot", 2="Door"]
Switch item=OpritCamUpdateImage
Default item=OpritCamMotionAlarm icon=siren
Default item=OpritCamAudioAlarm icon=siren
Text label="Advanced Controls" icon="settings"{
Switch item=OpritCamEnableMotion
Default item=OpritCamEnableAudioAlarm
Default item=OpritCamAudioThreshold icon=recorder
Slider item=OpritCamLED
Default item=OpritCamAutoLED
Slider item=OpritCamPan icon=movecontrol
Slider item=OpritCamTilt icon=movecontrol
Slider item=OpritCamZoom icon=zoom
note: when i search for cam in fing app, it turns up with different MAC adress then mentioned on camera, this started after last FW update. Can someone give me a nudge in the right direction?
EDIT: OK differnt mac adress is from the wifi module, when i plug in the ethernet cable the original MAC shows again. But before i could get the ipcam thing online but not anymore. I didnt change any settings.
2019-02-25 16:32:57.906 [DEBUG] [ing.ipcamera.handler.IpCameraHandler] - About to connect to the IP Camera using the ONVIF PORT at IP:192.168.1.15:888
2019-02-25 16:32:57.911 [DEBUG] [ing.ipcamera.handler.IpCameraHandler] - Can not connect with ONVIF to the camera at 192.168.1.15, check the ONVIF_PORT is correct. Fault was java.net.ConnectException: Host not available.
can someone tell me how i can check the ONVIF port number? I allready found in the documentation it defaults to 888 and allso set it like this but cant get the thing online anymore
EDIT2:
I found in the forum it isnt nessecairy to define onvif port and http port if you have not changed them, the binding knows wich default ports to use. I did notice that when i scaned for open ports before using fing app i had about 5 open ports on the cam (including port 888 => onvif), now when i do a scan i only find http and kerberos port.
