Ontrackx
(Jack Sand)
November 13, 2018, 11:42am
1
I had a total failure of json database and neded to rebouild my openhab instance
Everything seems to be in perfect order. but the online/alexa/hueemulation does not want to cooperate
2.4.0 Snapshot #1392
Connected to the openHAB Cloud service (UUID =xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx, base URL = http://localhost:8080 )
Is somthing down or unstable?
Please help 10 hours in and still nothing helps
Dim
(Angelos)
November 13, 2018, 1:22pm
2
maybe (don’t take this for granted), you are affected by this: [Solved] Is home.myopenhab.org down? , [SOLVED] Remote Access is slow
Ontrackx
(Jack Sand)
November 13, 2018, 1:30pm
3
HAHAHA typical my luck, rebuilding OH and in the meantime serves, get crappy
I will have to wait then
Dim
(Angelos)
November 15, 2018, 5:04am
4
Your wait is over It’s working fine (better than before) now !
Hi All, sorry for the very late reply to this thread. We had a backend server misconfigured which was accepting connections from OH instances, but then registering another server as owning that connection in the DB. This was causing about 25% of proxy connections to not work. Unfortunately if you were one of the unlucky 25% , this would problem would most likely persist even if you restarted OH due to session affinity.
It took a bit to figure out as the server looked healthy and was acceptin…
Ontrackx
(Jack Sand)
November 15, 2018, 3:03pm
5
Thank you, i read it on another thread, thanks for the reply
