Platform information:
Hardware: NUC7CJYH with 8 GB RAM and 32 GB SSD + zwave: Aeotec Z-Stick Gen5 (ZW090)
Ubuntu Server 20.04
OH 3.1 stable
I followed the steps in this thread and read the others, too, but I got errors on the log and cannot test it with the tools (SendArpRequest)
The dash buttons are stuck in INITIALIZING
These buttons worked before I migrated from RPi to the NUC.
I also changed the ethernet device from eth0 to eno1
I deleted one dash and created it again, without a change.
Log shows after activating the binding:
java.lang.NoClassDefFoundError: Could not initialize class org.pcap4j.core.NativeMappings
at org.pcap4j.core.Pcaps.findAllDevs(Pcaps.java:56) ~[?:?]
at org.openhab.binding.amazondashbutton.internal.pcap.PcapUtil.getAllNetworkInterfaces(PcapUtil.java:40) ~[?:?]
at org.openhab.binding.amazondashbutton.internal.pcap.PcapNetworkInterfaceService.determineBoundNetworkInterfaces(PcapNetworkInterfaceService.java:168) ~[?:?]
at org.openhab.binding.amazondashbutton.internal.pcap.PcapNetworkInterfaceService.lambda$0(PcapNetworkInterfaceService.java:56) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(Unknown Source) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
at java.lang.Thread.run(Unknown Source) [?:?]
and I cannot find anything manually like pcap4j, so it’s obviously not included in libpcap-dev
openhab.log shows:
at org.pcap4j.core.Pcaps.getDevByName(Pcaps.java:125) ~[?:?]
at org.openhab.binding.amazondashbutton.internal.pcap.PcapUtil.getNetworkInterfaceByName(PcapUtil.java:56) ~[?:?]
at org.openhab.binding.amazondashbutton.internal.handler.AmazonDashButtonHandler.lambda$0(AmazonDashButtonHandler.java:62) ~[?:?]
at java.util.concurrent.FutureTask.run(Unknown Source) ~[?:?]
I also removed libpcap-dev, but this did not help either.
Because no one here seems to have similar issues, I guess this is related to my “special” HW resulting in a different name for the ethernet connection (eno1 instead of eth0).
as the interface is part of the configuration it should work with your interface in case the configuration is correct/updated with regard to your new hardware.
The lib should install a shared library. I assume that it is the one that will be used.
The static library that is being installed and the .h files etc. are only used during development.
The class file that could not be initialized is located at:
7z l /var/lib/openhab/tmp/kar/openhab-addons-3.2.0.M1/org/openhab/addons/bundles/org.openhab.binding.amazondashbutton/3.2.0.M1/org.openhab.binding.amazondashbutton-3.2.0.M1.jar|grep NativeMappings.class
2019-08-17 14:14:16 ..... 7731 2864 org/pcap4j/core/NativeMappings.class
My question would be:
did you grant the capabilites as described in the docs and did you grant it to the right java binary. May be you have more instances of java binaries and the wrong one was granted to get the capabilities.
Because I am using ubuntu server (see above), are the Runtime / Server Version running independently?
Might the (additional / comflicting) Server version the cuplrit, then?
I am using the NUC for OH only - so no other server functionality (exception: server functions coming with OH and local ftp server).
EDIT:
according to this output there is no conflict:
openhabian@nukem:~$ sudo update-alternatives --config java
There is only one alternative in link group java (providing /usr/bin/java): /opt/jdk/zulu11.48.21-ca-jre11.0.11-linux_i686/bin/java
Nothing to configure.
openhabian@nukem:~$
Just an FYI - I checked this (similar) thread as well, but it’s windows and seemed to be solved by a change in the dash button jar (back on 2.5).
So it’s obviously not applicable to my case.
hmmm…
How to check?
AFAIK java -version should return somthing with 64bit like this if it’s 64bit
java version "1.6.0_18"
Java(TM) SE Runtime Environment (build 1.6.0_18-b07)
Java HotSpot(TM) 64-Bit Server VM (build 16.0-b13, mixed mode)
otherwise it’s 32bit (like in my case):
libcap shows:
openhabian@nukem:~$ dpkg -l |grep pcap
ii libpcap-dev:amd64 1.9.1-3 amd64 development library for libpcap (transitional package)
ii libpcap0.8:amd64 1.9.1-3 amd64 system interface for user-level packet capture
ii libpcap0.8-dev:amd64 1.9.1-3 amd64 development library and header files for libpcap0.8
So, there is a mismatch (unless I did something wrong).
This being said, means I need to remove libcap-dev 64bit and install 32bit - right?
I still wonder, if the dashbutton NativeMappings is able to handle the right interface because of the Unknown source:
I just found some time to look into this again.
After installing the i386 as mentioned above I don’t get this error anymore:
2021-12-23 19:26:19.199 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.UnsatisfiedLinkError: Unable to load library 'pcap':
libpcap.so: cannot open shared object file: No such file or directory
/lib/x86_64-linux-gnu/libpcap.so: wrong ELF class: ELFCLASS64
/lib/x86_64-linux-gnu/libpcap.so.1.9.1: wrong ELF class: ELFCLASS64
Which is good, I guess.
I just have these left:
2021-12-24 09:05:02.022 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
2021-12-24 09:05:02.026 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.amazondashbutton.internal.pcap.PcapNetworkInterfaceService.determineBoundNetworkInterfaces(PcapNetworkInterfaceService.java:168>
EDIT:
I got it!
There were actually two issues:
the wrong libpcap installed (libpcap-dev instead of libpcap-dev:i386
The standard interface name of my network card (eno1) was not working, so I renamed it to eth0 (see below)
To change the interface name of the network card:
sudo nano /etc/default/grub
change the following line:
GRUB_CMDLINE_LINUX=""
to
GRUB_CMDLINE_LINUX="net.ifnames=0 biosdevname=0"
and run:
sudo update-grub
followed by a reboot.
The only issue I have is that eth0 is not up after a reboot.
So the following steps are required for my case:
sudo ifconfig eth0 up
and
sudo dhclient -v eth0
EDIT II:
This can be solved with changing: sudo nano /etc/netplan/00-installer-config.yaml
(eno1 → eth0)
It turned out, that the configuration of the dash button changed.
Previously the interface name needed to be specified in regular text.
Now there is a selection available - and voilá - even with eno1 it works like a charm after setting it correctly:
