have not been able to get the Davis add on running. Have shipped around this, using Weatherunderground. They still provide API access for private weather stations which report data to them. My Davis station reports every minute to Weatherunderground. Thus, data is pretty up to date.
Thanks for the reply. I have my PWS connected with weather underground and its sending data just fine.
I installed the WU binding and I saw it needed an API key, so I went to WU and created one and entered it into the the Weatherunderground Bridge thing. It say offline - connunication error. Any hints? I didn’t know if this was related to them shutting down their API earlier this year but in reading your message, it sounds like yours is still working.
So just as an update: I got the Weather Company binding to work. My Davis Vantage Pro 2 is set up in the following way:
Connected to Weatherlink with WeatherlinkIP
Weatherlink data uploading to Weather Underground
Weather Underground (now weather company) API used for Openhab to grab the data using the binding in the above link (not the one listed in PaperUI. Note this binding and the Weather Underground API will only work for people who have PWS that give data to Weather Underground.
never got this working. In the meantime I use my Weatherunderground API in openHAB to access the Davis station data. Report my Davis station data every minute to Weatherunderground. Thus, this is quite actual.
Hi frieso, may I ask about the configuration you used for this working setup? I tried to get something out of the Vantage Pro 2 with serial adapter and USB-to-serial without success. Did you use the .jar file, how did you install? Has anyone an idea how to implement the serial port?
Hi @TheJM yes I’m using the Davis Vantage Pro since around 4 years with the davis org.openhab.binding.davis-1.14.0-20190505.030809-29.jar Binding, running on OH 2.5
Got it working! The only issue i am having now is that the units are in metric and i want it to be in imperial. Is there a way to configure this in the binding? Or do i have to create a bunch of dummy items and use rules to convert them?
What is the path to the addons folder? I don’t see an addons folder in any of my samba shares.
Apparently there used to be a samba share named openHAB-share with a folder openhab2-addons.
Thanks Rich.
Why I asked is that I had the Davis Binding working then I reinstalled openHAB from scratch and now it isn’t working.
I’m not sure what I did last time to get it working. I copied the org.openhab.binding.davis-1.14.0-SNAPSHOT.jar to that folder. Looking back through my backup of the old installation I found a copy of the jar file in openHAB-share/openhab2-addons but I couldn’t find that folder. I have since found /srv/openhab2-addons and it contained the jar file so I copied it to that folder on the new installation and restarted but no luck.
Ever since installing the Davis Binding on the old and new I have been getting the following error.
Even on the old installation with it working.
I’ve now removed all copies of the jar file from my installation as well as the cfg and items files for Davis but the error is still showing in the log.
Any suggestions.
