I have OH 2.5 on Openhabian with a CC1101 and homegear running. Connected are Thermostates and Window contacts (max!). Every now and then, the homegear service crashes. Not regularly, but every some weeks. I can stop the service and restart it, and everything is working again. But I get to know that it crashes not before my rooms are cold.
Is there a way to detect (by openhab) if homegear does not work anymore? Maybe if no messages arrive within a certain time?
Thanks,
Ingo
OK, found it in forum. You need to put the homegear items in a group an check if this group changes within a certain amount of time (timer). If no change happens → Problem with homegear.
Great that you fixed the problem!
But please if you reference “found it in forum” please link to the topic so other people who find this topic don’t need to search again.
Also here is a little guide how you should mark your topic as “solved”
Cheers ![]()
