[SOLVED] Dispatching event to subscriber '...' takes more than 5000ms
the problem is the message “Dispatching event to subscriber ‘…’ takes more than 5000ms” (see log file below)
the system becomes very slow and is almost no longer usable/configurable. (very very slow)
what could this be and how can the origin of the problem be evaluated?
2019-02-18 18:11:48.518 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@10b5e5e' takes more than 5000ms.
2019-02-18 18:13:06.440 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@14870b7' takes more than 5000ms.
2019-02-18 18:13:18.089 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@1ae5ec1' takes more than 5000ms.
2019-02-18 18:13:23.585 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@10b5e5e' takes more than 5000ms.
2019-02-18 18:13:29.095 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@10b5e5e' takes more than 5000ms.
2019-02-18 18:14:02.815 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@10b5e5e' takes more than 5000ms.
2019-02-18 18:14:24.946 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@10b5e5e' takes more than 5000ms.
2019-02-18 18:14:42.211 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@14870b7' takes more than 5000ms.
2019-02-18 18:14:52.441 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.CommunicationManager@e6d905' takes more than 5000ms.
2019-02-18 18:15:37.925 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.rest.sse.internal.listeners.SseEventSubscriber@9d29b' takes more than 5000ms.
2019-02-18 18:15:55.057 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.internal.CommunicationManager@e6d905' takes more than 5000ms.
2019-02-18 18:16:05.901 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.config.discovery.internal.AutomaticInboxProcessor@183f757' takes more than 5000ms.
2019-02-18 18:16:11.925 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.config.discovery.internal.AutomaticInboxProcessor@183f757' takes more than 5000ms.
2019-02-18 18:16:34.313 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@1ae5ec1' takes more than 5000ms.
2019-02-18 18:16:39.892 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@10b5e5e' takes more than 5000ms.
2019-02-18 18:16:56.469 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@1ae5ec1' takes more than 5000ms.
2019-02-18 18:17:18.220 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@10b5e5e' takes more than 5000ms.
2019-02-18 18:17:40.324 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.config.discovery.internal.AutomaticInboxProcessor@183f757' takes more than 5000ms.
2019-02-18 18:18:29.707 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@1ae5ec1' takes more than 5000ms.
2019-02-18 18:18:57.688 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@1ae5ec1' takes more than 5000ms.
Openhab Version 2.4.0
Hardware: Raspberry Pi 3
thanks a lot for a good tip on how i can analyze and fix the problem.
I could be wrong but I have a vague memory that this came up already and was fixed in OH 2.5 M1. I could be wrong but it’s worth a try.
Cause and effect may be the other way around; system grinding to a halt is cause of delayed events processing?
See many other threads about thread pool, memory usage etc.
thanks for the replies.
i have no idea how to find the problem. does anyone have a tip?
Well, since it might already be fixed, I’d try upgrading to 2.5 M1 as a start. If there is a bug you’d have to do this anyway.
Thanks, how can i change from Release Version to Actual milestone? Where are these steps describded?
How did you install?
I had installed openhabian … Later Updated to Version 2.3 and 2.4
OK. In openhabian-config, go to “40. openHAB related” and switch to the “openHAB testing” which I think is the milestone builds.
Then I think you may need to run “02. Upgrade System”.
i have change now to the milestone and have upgrade the system.
but now, openhab doesn’t start.
2019-03-02 14:02:34.002 [ERROR] [org.openhab.binding.velux           ] - FrameworkEvent ERROR - org.openhab.binding.velux
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.velux [74]
  Unresolved requirement: Import-Package: org.apache.commons.httpclient
	at org.eclipse.osgi.container.Module.start(Module.java:444) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) ~[?:?]
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2019-03-02 14:02:36.632 [WARN ] [org.apache.felix.fileinstall        ] - Error while starting bundle: file:/usr/share/openhab2/addons/org.openhab.binding.velux-1.14.0-SNAPSHOT.jar
	at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [10:org.apache.felix.fileinstall:3.6.4]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [10:org.apache.felix.fileinstall:3.6.4]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [10:org.apache.felix.fileinstall:3.6.4]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [10:org.apache.felix.fileinstall:3.6.4]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [10:org.apache.felix.fileinstall:3.6.4]
	at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [10:org.apache.felix.fileinstall:3.6.4]
how can i analyse this problem? what can i do?
First thing to try is Clear the Cache
I have found a same issue about update to version 2.3 …
openhab hadn’t started anymore.
with the following commands it had worked again, and also worked for me when updating to Milestone
sudo chown -R openhab:openhab /var/lib/openhab2
sudo chown -R openhab:openhab /etc/openhab2
sudo systemctl enable openhab2
problem is fixed … thanks
Hi there, I’m running OH 2.4 in Docker and have the same problem. Unfortunately, I can’t access the docker exec command while the container runs to implement that solution as the whole systems becomes unusual.
Does any one have an idea how to pass that command in the docker-compose.yaml or another way? Maybe docker-compose build command?
Thanks you for your help.
Additional info
  • Raspi 3
  • new to everything about Unix
EDIT: I managed to use docker exec but no dice:
OCI runtime exec failed: exec failed: container_linux.go:344: starting container        process caused "exec: \"sudo\": executable file not found in $PATH": unknown
EDIT2: Nevermind, somehow it’s working now…
Replying here because it is the first google hit for the message and might help someone to fix this:
For me this messaged was caused by a breaking down SD card (<3MB/s remaining write and read speed). Replaced the card, message is gone, system way more responsive again.
