ariela
(Andrea Riela)
October 22, 2019, 8:51am
1
Hi folks,
I’ve upgraded from #1657 to #1712 and I’ve the same problem as:
So,
I was running fine with build #703 and the openhab-online docker and decided to update it, bad idea.
Now my sitemaps fail to display any charts.
In the openhab.log I see
2017-02-01 15:01:41.157 [WARN ] [eclipse.jetty.servlet.ServletHandler] - Error for /chart
java.lang.Error: Probable fatal error:No fonts found.
at sun.font.SunFontManager.getDefaultPhysicalFont(SunFontManager.java:1236)[:1.8.0_112]
at sun.font.SunFontManager.initialiseDeferredFont(SunFontManager.java:1106)[:1.8.0_112]
The problem here I don’t have a docker, just a simple openhabian installation in a VM (VMware). With the latest OH (2.5.0~S1731-1 (Build #1731 )) same issue.
I’ve tried to install fontconfig via apt-get, but it didn’t solve the issue.
Any clue?
here the log: JustPaste.it - Share Text & Images the Easy Way
Any suggestion will be appreciated
Andrea
Like any snapshot tester, please file an issue on GitHub. As you know, snapshot builds are not expected to be fully functional. They are designed to find issues such as this but it needs to be reported where it can be resolved.
Celaeno1
(Alex)
October 22, 2019, 10:01am
3
ariela:
Any clue?
What is your persistence? Is it running? Is is set in PaperUI → Configuration → System → Persistence → Default Service? If there is your correct entry? You should try: remove it, save empty, fill it in again, save again.
ariela
(Andrea Riela)
October 22, 2019, 10:48am
4
it was working perfectly on #1657 , so it’s not a persistence issue.
Github issue opened: Fonts error, not able to see any chart · Issue #748 · openhab/openhabian · GitHub
Andrea
Celaeno1
(Alex)
October 22, 2019, 10:52am
5
I’ve updated from 1486 to 1731. I had a similar problem with rrd4j. I did what I mentioned one post before, and then it was running again. But maybe it’s different to your problem.
ariela
(Andrea Riela)
October 22, 2019, 4:41pm
6
the problem is the default for me is not rrd4j, but mapdb. rrd4j is used for some charts (the charts that have problems now)
maybe I can try to remove the configuration of rrd4j, restart, then stop and re-add.
mmm …
Celaeno1
(Alex)
October 22, 2019, 6:59pm
7
I would try to backup your rrd4j database and rrd4j configuration. Then uninstall rrd4j persistence. Reinstall it again. Check your config again.
ariela
(Andrea Riela)
October 23, 2019, 9:10am
8
nothing …
after quick investigation, it seems there is an issue with openJDK … maybe we need to start it in headless mode
-Djava.awt.headless=true
but I don’t remember where is the right config in openhabian
Andrea
ariela
(Andrea Riela)
October 23, 2019, 9:20am
9
wrong … it’s already configured:
ps -ef | grep openhab
openhab 2452 1 0 Oct22 ? 00:01:05 node /usr/bin/frontail --ui-highlight --ui-highlight-preset /usr/lib/node_modules/frontail/preset/openhab.json -t openhab -l 2000 -n 200 /var/log/openhab2/openhab.log /var/log/openhab2/events.log
openhab 2463 2452 0 Oct22 ? 00:00:18 tail -n 200 -F /var/log/openhab2/openhab.log /var/log/openhab2/events.log
ariela 55292 54906 0 10:35 pts/1 00:00:00 tail -f /var/log/openhab2/openhab.log
openhab 62204 1 24 11:03 ? 00:03:27 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var/log/openhab2 -Dfelix.cm.dir=/var/lib/openhab2/config -Djava.library.path=/var/lib/openhab2/tmp/lib -Djetty.host=0.0.0.0 -Djetty.http.compliance=RFC2616 -Dorg.ops4j.pax.web.listening.addresses=0.0.0.0 -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8443 -Djava.awt.headless=true -XX:+UseG1GC -Dgnu.io.rxtx.SerialPorts=/dev/ttyACM0 -Djava.endorsed.dirs=/opt/jdk/zulu8.42.0.21-ca-jdk8.0.232-linux_i686/jre/lib/endorsed:/opt/jdk/zulu8.42.0.21-ca-jdk8.0.232-linux_i686/lib/endorsed:/usr/share/openhab2/runtime/lib/endorsed -Djava.ext.dirs=/opt/jdk/zulu8.42.0.21-ca-jdk8.0.232-linux_i686/jre/lib/ext:/opt/jdk/zulu8.42.0.21-ca-jdk8.0.232-linux_i686/lib/ext:/usr/share/openhab2/runtime/lib/ext -Dkaraf.instances=/var/lib/openhab2/tmp/instances -Dkaraf.home=/usr/share/openhab2/runtime -Dkaraf.base=/var/lib/openhab2 -Dkaraf.data=/var/lib/openhab2 -Dkaraf.etc=/var/lib/openhab2/etc -Dkaraf.log=/var/log/openhab2 -Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir=/var/lib/openhab2/tmp -Djava.util.logging.config.file=/var/lib/openhab2/etc/java.util.logging.properties -Dkaraf.startLocalConsole=false -Dkaraf.startRemoteShell=true -classpath /usr/share/openhab2/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.2.6.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.jaas.boot-4.2.6.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.main-4.2.6.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.specs.activator-4.2.6.jar:/usr/share/openhab2/runtime/lib/boot/org.osgi.core-6.0.0.jar org.apache.karaf.main.Main
ariela 63938 57691 0 11:17 pts/2 00:00:00 grep --color=auto openhab
Celaeno1
(Alex)
October 23, 2019, 10:05am
10
Sorry I’m not using Openhabian and I’m not a Linux specialist, but please check this three links:
https://www.ostechnix.com/find-installed-fonts-commandline-linux/
committed 07:29PM - 14 Feb 17 UTC
For the charting feature, the system, where OH2 is running, needs to
have some … fonts installed. The package fontconfig should depend on all
needed packages on all systems (a shared library to access fonts and
some fonts (on debian libfreetype6 e.g.)).
I tested this on a amd64 Ubuntu host, however, it should work on armhf
and arm64 platforms, too.
Fixes #73
Signed-off-by: Florian Schmidt <florian.schmidt.welzow@t-online.de>
https://www.howtoinstall.co/en/ubuntu/xenial/fontconfig
ariela
(Andrea Riela)
October 24, 2019, 9:38am
11
the solution is in:
opened 05:20PM - 10 Feb 17 UTC
closed 01:55PM - 13 Feb 17 UTC
Using Zulu JDK / OpenJDK, using the chart servlet results in
java.lang.Nul… lPointerException
at sun.awt.FontConfiguration.getVersion(FontConfiguration.java:1264)[:1.8.0_112]
at sun.awt.FontConfiguration.readFontConfigFile(FontConfiguration.java:219)[:1.8.0_112]
at sun.awt.FontConfiguration.init(FontConfiguration.java:107)[:1.8.0_112]
at sun.awt.X11FontManager.createFontConfiguration(X11FontManager.java:774)[:1.8.0_112]
at sun.font.SunFontManager$2.run(SunFontManager.java:431)[:1.8.0_112]
at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_112]
at sun.font.SunFontManager.<init>(SunFontManager.java:376)[:1.8.0_112]
at sun.awt.FcFontManager.<init>(FcFontManager.java:35)[:1.8.0_112]
at sun.awt.X11FontManager.<init>(X11FontManager.java:57)[:1.8.0_112]
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)[:1.8.0_112]
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)[:1.8.0_112]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)[:1.8.0_112]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)[:1.8.0_112]
at java.lang.Class.newInstance(Class.java:442)[:1.8.0_112]
at sun.font.FontManagerFactory$1.run(FontManagerFactory.java:83)[:1.8.0_112]
at sun.font.FontManagerFactory.getInstance(FontManagerFactory.java:74)[:1.8.0_112]
at java.awt.Font.getFont2D(Font.java:491)[:1.8.0_112]
at java.awt.Font.defaultLineMetrics(Font.java:2176)[:1.8.0_112]
at java.awt.Font.getLineMetrics(Font.java:2283)[:1.8.0_112]
at java.awt.font.TextLayout.fastInit(TextLayout.java:598)[:1.8.0_112]
at java.awt.font.TextLayout.<init>(TextLayout.java:393)[:1.8.0_112]
at com.xeiam.xchart.internal.chartpart.Axis.getSizeHint(Axis.java:138)[136:org.eclipse.smarthome.ui:0.9.0.b4]
at com.xeiam.xchart.internal.chartpart.Axis.paint(Axis.java:169)[136:org.eclipse.smarthome.ui:0.9.0.b4]
at com.xeiam.xchart.internal.chartpart.AxisPair.paint(AxisPair.java:130)[136:org.eclipse.smarthome.ui:0.9.0.b4]
at com.xeiam.xchart.internal.chartpart.ChartPainter.paint(ChartPainter.java:94)[136:org.eclipse.smarthome.ui:0.9.0.b4]
at com.xeiam.xchart.Chart.paint(Chart.java:105)[136:org.eclipse.smarthome.ui:0.9.0.b4]
at org.eclipse.smarthome.ui.internal.chart.DefaultChartProvider.createChart(DefaultChartProvider.java:225)[136:org.eclipse.smarthome.ui:0.9.0.b4]
at org.eclipse.smarthome.ui.internal.chart.ChartServlet.doGet(ChartServlet.java:190)[136:org.eclipse.smarthome.ui:0.9.0.b4]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)[19:javax.servlet-api:3.1.0]
There are [similar reports](https://github.com/docker-library/openjdk/issues/73) on the web.
I already tried
apt-get install libfontconfig1 fontconfig ttf-dejavu
but without effect :-(
sudo apt-get install fontconfig:i386
did the trick for me (even on amd64 vm).
Andrea
Celaeno1
(Alex)
October 24, 2019, 12:54pm
12
I was not so far away with: sudo apt-get install fontconfig (in links above…)
ariela
(Andrea Riela)
October 24, 2019, 12:59pm
13
yep right the problem is the “generic” command will install the version correct for your platform (in my case amd64) … but openhab works with 32 bit version, so you need the i386
ahahaha … crazy
