So,
I was running fine with build #703 and the openhab-online docker and decided to update it, bad idea.
Now my sitemaps fail to display any charts.
In the openhab.log I see
2017-02-01 15:01:41.157 [WARN ] [eclipse.jetty.servlet.ServletHandler] - Error for /chart
java.lang.Error: Probable fatal error:No fonts found.
at sun.font.SunFontManager.getDefaultPhysicalFont(SunFontManager.java:1236)[:1.8.0_112]
at sun.font.SunFontManager.initialiseDeferredFont(SunFontManager.java:1106)[:1.8.0_112]
at sun.font.CompositeFont.doDeferredInitialisation(CompositeFont.java:263)[:1.8.0_112]
at sun.font.CompositeFont.getSlotFont(CompositeFont.java:352)[:1.8.0_112]
at sun.font.CompositeStrike.getStrikeForSlot(CompositeStrike.java:78)[:1.8.0_112]
at sun.font.CompositeStrike.getFontMetrics(CompositeStrike.java:93)[:1.8.0_112]
at sun.font.Font2D.getFontMetrics(Font2D.java:415)[:1.8.0_112]
at java.awt.Font.defaultLineMetrics(Font.java:2176)[:1.8.0_112]
at java.awt.Font.getLineMetrics(Font.java:2283)[:1.8.0_112]
at java.awt.font.TextLayout.fastInit(TextLayout.java:598)[:1.8.0_112]
at java.awt.font.TextLayout.<init>(TextLayout.java:393)[:1.8.0_112]
I just installed OH2 snapshot 2.1.0 docker AMD64, and also experience the same error.
22:10:33.948 [WARN ] [eclipse.jetty.servlet.ServletHandler] - Error for /chart
at java.awt.font.TextLayout.(TextLayout.java:393)[:1.8.0_112]
at com.xeiam.xchart.internal.chartpart.Axis.getSizeHint(Axis.java:138)[136:org.eclipse.smarthome.ui:0.9.0.201701192225]
at com.xeiam.xchart.internal.chartpart.Axis.paint(Axis.java:169)[136:org.eclipse.smarthome.ui:0.9.0.201701192225]
at com.xeiam.xchart.internal.chartpart.AxisPair.paint(AxisPair.java:130)[136:org.eclipse.smarthome.ui:0.9.0.201701192225]
at com.xeiam.xchart.internal.chartpart.ChartPainter.paint(ChartPainter.java:94)[136:org.eclipse.smarthome.ui:0.9.0.201701192225]
at com.xeiam.xchart.Chart.paint(Chart.java:105)[136:org.eclipse.smarthome.ui:0.9.0.201701192225]
at org.eclipse.smarthome.ui.internal.chart.DefaultChartProvider.createChart(DefaultChartProvider.java:225)[136:org.eclipse.smarthome.ui:0.9.0.201701192225]
at org.eclipse.smarthome.ui.internal.chart.ChartServlet.doGet(ChartServlet.java:190)[136:org.eclipse.smarthome.ui:0.9.0.201701192225]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)[19:javax.servlet-api:3.1.0]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)[19:javax.servlet-api:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:812)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)[79:org.eclipse.jetty.security:9.2.19.v20160908]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:287)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)[81:org.eclipse.jetty.servlet:9.2.19.v20160908]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)[172:org.ops4j.pax.web.pax-web-jetty:4.3.0]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.Server.handle(Server.java:499)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)[80:org.eclipse.jetty.server:9.2.19.v20160908]
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:544)[72:org.eclipse.jetty.io:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)[83:org.eclipse.jetty.util:9.2.19.v20160908]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_112]
When I upgraded to snapshot 2.1.0 using docker (saved my conf and userdata folders), I get the chart error.
When I do a clean install of snapshot 2.1.0 using docker, I don’t get the “KARAF_ETC is not valid” message, just a correct and clean install where I can login in karaf console.
2017-02-02 08:26:43.641 [WARN ] [eclipse.jetty.servlet.ServletHandler] - Error for /chart
<cut>
Hi! The docker documentation was updated today on Dockerhub and Github. The behaviour in working with docker mounted volumes has been changed to stay closer to the docker defaults. In the past the configuration files where copied to the docker mounted directory at the first start and owned by user id 1000. There where different problems with that approach. See the closed bugs on Github for details.
We have implemented a more cleaner approach based on the docker best practices. The openhab user in the docker container starts now with uid 9001 by default. This means, that you need existing config files and set the right permission on your hosts data folder e.g.
chown 9001.9001 /opt/openhab -R
If you do not have configuration files yet, you can copy them from the docker image to the host before starting the container. Please refer to the documenataion for details.
Can I suggest you have ONE place for the docker documentation (docs.openhab.org seems the most relevant) covering install and then on docker hub and github simply provide a link back to docs.openhab.org - otherwise you are going to have to maintain up to 3 separate copies…
Hi. I am with you. But i think the main documentation should be maintained, where the opennhab-docker project is developed. So referencing from docs.openhab.org to openhab-docker makes more sense. I dont want to check out two git repositories and create 2 pull requests for each change i make
2.5.0-SNAPSHOT Build #1719
Intel(R) Celeron(R) CPU J1900 @ 1.99GHz
openhabian istallation - not docker
EDIT: worked fine a few snapshots befor
2019-10-12 17:40:40.662 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /chart
at sun.font.SunFontManager.getDefaultPhysicalFont(SunFontManager.java:1236) ~[?:?]
at sun.font.SunFontManager.initialiseDeferredFont(SunFontManager.java:1106) ~[?:?]
at sun.font.CompositeFont.doDeferredInitialisation(CompositeFont.java:287) ~[?:?]
at sun.font.CompositeFont.getSlotFont(CompositeFont.java:376) ~[?:?]
at sun.font.CompositeStrike.getStrikeForSlot(CompositeStrike.java:82) ~[?:?]
at sun.font.CompositeStrike.getFontMetrics(CompositeStrike.java:97) ~[?:?]
at sun.font.Font2D.getFontMetrics(Font2D.java:415) ~[?:?]
at java.awt.Font.defaultLineMetrics(Font.java:2176) ~[?:?]
at java.awt.Font.getLineMetrics(Font.java:2283) ~[?:?]
at java.awt.font.TextLayout.fastInit(TextLayout.java:598) ~[?:?]
at java.awt.font.TextLayout.(TextLayout.java:393) ~[?:?]
at org.knowm.xchart.internal.chartpart.AxisTickCalculator.willLabelsFitInTickSpaceHint(AxisTickCalculator.java:148) ~[?:?]
at org.knowm.xchart.internal.chartpart.AxisTickDateCalculator.calculate(AxisTickDateCalculator.java:214) ~[?:?]
at org.knowm.xchart.internal.chartpart.AxisTickDateCalculator.(AxisTickDateCalculator.java:115) ~[?:?]
at org.knowm.xchart.internal.chartpart.Axis.getAxisTickCalculator(Axis.java:363) ~[?:?]
at org.knowm.xchart.internal.chartpart.Axis.getXAxisHeightHint(Axis.java:286) ~[?:?]
at org.knowm.xchart.internal.chartpart.Axis.paint(Axis.java:180) ~[?:?]
at org.knowm.xchart.internal.chartpart.AxisPair.paint(AxisPair.java:147) ~[?:?]
at org.knowm.xchart.internal.chartpart.ChartPainter.paint(ChartPainter.java:114) ~[?:?]
at org.knowm.xchart.Chart.paint(Chart.java:102) ~[?:?]
at org.eclipse.smarthome.ui.internal.chart.defaultchartprovider.DefaultChartProvider.createChart(DefaultChartProvider.java:277) ~[?:?]
at org.eclipse.smarthome.ui.internal.chart.ChartServlet.doGet(ChartServlet.java:332) ~[?:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[31:javax.servlet-api:3.1.0]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[31:javax.servlet-api:3.1.0]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:873) ~[90:org.eclipse.jetty.servlet:9.4.18.v20190429]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:542) ~[90:org.eclipse.jetty.servlet:9.4.18.v20190429]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[194:org.ops4j.pax.web.pax-web-jetty:7.2.10]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) ~[89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[87:org.eclipse.jetty.security:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) ~[89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1700) ~[89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) ~[89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1345) ~[89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) ~[194:org.ops4j.pax.web.pax-web-jetty:7.2.10]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) ~[89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:480) ~[90:org.eclipse.jetty.servlet:9.4.18.v20190429]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1667) ~[89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) ~[89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1247) ~[89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) ~[89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[194:org.ops4j.pax.web.pax-web-jetty:7.2.10]
at org.eclipse.jetty.server.Server.handle(Server.java:505) ~[89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:370) [89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:267) [89:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305) [80:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [80:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [80:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [92:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [92:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [92:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [92:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [92:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:698) [92:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:804) [92:org.eclipse.jetty.util:9.4.18.v20190429]
