[SOLVED] Google Home Goes 'Offline' and audio sink doesn't work
I’ve found something. If I leave the callbackUrl empty (it’s optional), it is working with the VoiceRSS service. The issue only appears, when I enter the IP of my openhab-Server. Could you try to reproduce that?
I’ll try and look at it tonight and report back.
It’s working for me. Even with the playSound command. :grinning:
Is that with other bindings installed or stand-alone?
With all my bindings cunfigured. I’ve installed one by one and it was still working at the end. I’ve enteres the callbackUrl at the last step, and with this step i’ve got the issue back. I think that the callbackUrl is only necessary in some scenarios, but makes trouble in this case.
OK, I’ll try tonight. I know Armon suggested changing the callback URL in an earlier post, but that didn’t work for me.
So after some testing, it looks like that works. The time taken for a spoken response seems to be increasing, but it works.
I’ll keep testing and see if it remains stable/ responsive.
Well done @Riza_Aslan
Perfect…thanks mate! :slight_smile:
Excellent this worked for me too
This issue still exists in the Nightly. Although, I got an exception after removing the CallBack, this also resolved my no Audio output issue.
A day later and my Groups were Offline again. Now they’re back Online. Pattern still undetermined.
Sigh…
Did you solve this issue? I’m having some trouble with my sensors, they go offline and online randomly… and I don’t know why.
As an example:
2018-08-03 12:51:12.089 [hingStatusInfoChangedEvent] - 'mihome:sensor_ht:XXXXXXXXX' changed from ONLINE to OFFLINE
Answer was given in post 23 above
i dont know if its the same issue,when i use
say("test test", "voicerss:enGB")
to my google home mini it crashes and forced reboot,when i send the same command to my other chromecasts it works as expected.I am on latest snapshot openhab build.
Hi guys, I’m having the same problem with playsound to chromecast audio. I allready commented out the callback url in chromecast.cfg but when i give command: “smarthome:audio play doorbell.mp3” in openhab console, i hear the cc chirp and then silence. This is what i see in the logs:
2019-02-07 17:34:45.671 [hingStatusInfoChangedEvent] - 'chromecast:audio:myCC' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Unable to load media
2019-02-07 17:34:45.687 [hingStatusInfoChangedEvent] - 'chromecast:audio:myCC' changed from OFFLINE (COMMUNICATION_ERROR): Unable to load media to ONLINE
Any ideas?
EDIT: This is the log output with trace enabled on chromecast binding:
2019-02-07 17:47:33.683 [DEBUG] [ast.internal.ChromecastStatusUpdater] - MEDIA_STATUS null
2019-02-07 17:47:37.008 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Type: null
2019-02-07 17:47:37.013 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Type: Chromecast
2019-02-07 17:47:37.016 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Found: 192.168.1.6 8009
2019-02-07 17:47:37.019 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Type: Chromecast
2019-02-07 17:47:43.832 [DEBUG] [ast.internal.ChromecastStatusUpdater] - MEDIA_STATUS null
2019-02-07 17:47:47.800 [DEBUG] [ast.internal.ChromecastStatusUpdater] - MEDIA_STATUS MediaStatus{activeTrackIds: <null>, mediaSessionId: 2, playbackRate: 1, playerState: IDLE, currentItemId: 2, currentTime: 0.000000, customData: <null>, loadingItemId: null, items: <null>, preloadedItemId: null, supportedMediaCommands: 274447, volume: Volume{level: 1.0, muted: false, increment: 0.05, stepInterval: 0.05000000074505806, controlType: null}, media: Media{url: /audio/0e862f6b-9860-4dbc-ab2d-812874c38541, contentType: audio/mpeg, duration: null}, repeatMode: REPEAT_OFF, idleReason: null}
2019-02-07 17:47:47.814 [vent.ItemStateChangedEvent] - currentTime changed from UNDEF to 0.0
2019-02-07 17:47:47.917 [vent.ItemStateChangedEvent] - title changed from UNDEF to Notification
2019-02-07 17:47:47.922 [vent.ItemStateChangedEvent] - statustext changed from Default Media Receiver to Casting: Notification
2019-02-07 17:47:47.976 [DEBUG] [omecast.internal.ChromecastCommander] - Failed playing media: Unable to load media
2019-02-07 17:47:47.982 [hingStatusInfoChangedEvent] - 'chromecast:chromecast:myCC' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Unable to load media
2019-02-07 17:47:48.006 [hingStatusInfoChangedEvent] - 'chromecast:chromecast:myCC' changed from OFFLINE (COMMUNICATION_ERROR): Unable to load media to ONLINE
2019-02-07 17:47:48.024 [vent.ItemStateChangedEvent] - statustext changed from Casting: Notification to Default Media Receiver
2019-02-07 17:47:54.179 [DEBUG] [ast.internal.ChromecastStatusUpdater] - MEDIA_STATUS MediaStatus{activeTrackIds: <null>, mediaSessionId: 2, playbackRate: 1, playerState: IDLE, currentItemId: 2, currentTime: 0.000000, customData: <null>, loadingItemId: null, items: <null>, preloadedItemId: null, supportedMediaCommands: 274447, volume: Volume{level: 1.0, muted: false, increment: 0.05, stepInterval: 0.05000000074505806, controlType: null}, media: Media{url: /audio/0e862f6b-9860-4dbc-ab2d-812874c38541, contentType: audio/mpeg, duration: null}, repeatMode: null, idleReason: ERROR}
2019-02-07 17:47:54.395 [DEBUG] [omecast.internal.ChromecastCommander] - Media player app stopped
2019-02-07 17:47:54.402 [DEBUG] [ast.internal.ChromecastEventReceiver] - Unhandled event type: java.lang.Object@4c8080
2019-02-07 17:47:54.402 [vent.ItemStateChangedEvent] - appName changed from Default Media Receiver to UNDEF
2019-02-07 17:47:54.417 [vent.ItemStateChangedEvent] - appId changed from CC1AD845 to UNDEF
2019-02-07 17:47:54.421 [vent.ItemStateChangedEvent] - statustext changed from Default Media Receiver to UNDEF
2019-02-07 17:47:54.424 [vent.ItemStateChangedEvent] - idling changed from OFF to ON
2019-02-07 17:47:55.421 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Type: Chromecast
2019-02-07 17:47:55.423 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Found: 192.168.1.6 8009
2019-02-07 17:47:55.426 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Type: Chromecast
2019-02-07 17:47:57.328 [vent.ItemStateChangedEvent] - appName changed from UNDEF to Backdrop
2019-02-07 17:47:57.358 [vent.ItemStateChangedEvent] - appId changed from UNDEF to E8C28D3C
2019-02-07 17:47:57.370 [vent.ItemStateChangedEvent] - statustext changed from UNDEF to
2019-02-07 17:47:58.931 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Type: null
2019-02-07 17:48:17.052 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Type: null
2019-02-07 17:48:17.058 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Type: Chromecast
2019-02-07 17:48:17.062 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Found: 192.168.1.6 8009
2019-02-07 17:48:17.066 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Type: Chromecast
2019-02-07 17:48:34.467 [DEBUG] [omecast.internal.ChromecastCommander] - Failed to request media status with a running app: Waiting for response timed out
2019-02-07 17:48:38.934 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Type: null
2019-02-07 17:48:56.974 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Type: null
2019-02-07 17:48:56.977 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Type: Chromecast
2019-02-07 17:48:56.981 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Found: 192.168.1.6 8009
2019-02-07 17:48:56.983 [DEBUG] [overy.ChromecastDiscoveryParticipant] - Chromecast Type: Chromecast
dont know if this helps (this time with av chromecast as default sink)
Perfect, i had the same problem, solved by leaving the callbackurl empty and setting the default audio sink
I couldn’t get it to work with nothing in the callbackurl. I had to set it to http://192.168.1.10:8080, i.e. the address of my openhab2 server.
You solved it for me!
Will this also work with the spotify binding?
So what I want to do is make a Spotify player and create a button or so to play music on my Google Home Mini without speaking to it first.
So basically my Openhab needs to “speak” to my Google Home mini to play a song via spotify.
Could anyone of you maybe share some codes how this is possible?
Maybe use orange assist to launch spotify
Thanks will have a look at this. Hope to get this to work with my knowledge.
