hello to all I am trying or working with graphs but they are not visualized in the sitemap.
I have performed the following steps: -Install persistance rrd4j -create openhab / conf / persistance / rrd4j.persist
(I have searched the routes I’ve seen in several post but they are not in my configuration)
The content should look like this:
Strategies {
// for rrd charts, we need a cron strategy
everyMinute: “0 * * * *?”
default = everyChange
Items {
*: strategy = everyUpdate, everyMinute
The * is for persist ALL my item
-I have activated the persist in Paper UI
-I put the sitemaps line:
Chart item=Temperature period=h refresh=300
But don´t work, i read a lot of post and tutorals and nothing.
Your rrd4j.persist file should be located in the persistence folder
The persistence folder should be located in the same folder as your sitemaps and items and rules folder
Change the temperature value and you should see a change on the chart
Also your refresh rate for the chart is far too small (300ms) change it to 60000 (One minute)
ok I will try your example, but how can I change the temperature manually? since it gets it from the weather underground addon.
And, even if the value does not change, should not a continuous line appear on the graph?
