I started to check out HABPanel and see it popping up for configuration. I also created successfully the first board and can add widgets.
However I cannot see any items on the dropdown menu when editing my first widgets.
The documentation mentiones, that it should be possible.
Ist there something I might have missed?
Thanks in advance.
Chrome has the best developer tools IMO, what I’m asking is the output from the JS console and the result of the network calls to try to figure out what’s wrong for you.
Damn it.
All my items are defined in my home.items file in /etc/openhab2/items.
So I just recognized that those cannot be seen in Paper UI in configuration -> items.
Does this mean HABPanel cannot see / select them as well??
However, when I use HABmin I can see all my items…
It won’t work at all until you resolve your error 500 issue. Try going to /rest/items directly using your browser and check the exception message, it might give you a clue.
@ThomasH, @ysc, @MikeD
Just found it in another MAP location:
I used:
DateTime Weather_Forecast_Day_1 “[MAP(week.map):%1$tA]” …
Removing this entry solved the issue and I can select the items in HABPanel.
Thanks for all your suggestions for investigation!
I am not sure, because you obviously don’t use a transform (MAP) statement in your item - which was the root cause for me regarding the initial problem.
Do you have other items using MAP and %d ?
