I know i´m a bit late on this challenge, but time is not on my side these days. So I desperate need some help getting a rule ready for tomorrow.
What I want to do:
When a motion sensor (at our frontdoor) trigger, playsound on a Google Home Mini (the best I could do atm), and starts flashing the light in our doorway.
When I press a button, mute the sound, (cant figure how to stop playing the sound on the Google Home Mini), and set the light to x%, until I press the key again - Then back to start, and get ready for the next poor souls (children) ![]()
I hope I got the idea covered.
Items available:
Dimmer GoogleHoMini1Vol "Google Home Mini1 Volume [%s]" <soundvolume> {channel="chromecast:chromecast:255f3cf49521e13fa5f92fc38ae7ac51:volume"}
Switch GoogleHoMini1Mute "Google Home Mini1 Mute [%d]" <soundvolume> {channel="chromecast:chromecast:255f3cf49521e13fa5f92fc38ae7ac51:mute"}
Dimmer lys_indgang "Udvendiglys Indgangsparti lysstyrke [%s %%]" <light> {ihc="3916893"}
Switch Node13_BinarySensor "Neo Coolcam PIR Binary Sensor [%s]" <cum_motion> (gMotion) {channel="zwave:device:512:node13:sensor_binary"}
Switch bryggers_OEH "Bryggers switch upper right" <WallSwitch> (gV) {ihc=">[ON:47706:100]", autoupdate="false"}
Switch bryggers_NH "Bryggers switch lower right" <WallSwitch> (gV) {ihc=">[ON:49498:100]", autoupdate="false"}
What I have sofar, is this rule:
rule "Play stream to Google Home Mini"
// Item ZWaveNode5ZW100MultiSensor6_MotionAlarm changed from OFF to ON or // Test motionsensor at office
Item Node13_BinarySensor changed from OFF to ON // Motionsensor at frontdoor
Item lydknap changed from OFF to ON // Test button to manually activate the rule
playSound("chromecast:chromecast:255f3cf49521e13fa5f92fc38ae7ac51","Halloween1.mp3")
logInfo("RULE.SWITCH_ON_STREAM", "Sending sound to Google Home Mini" )
Sound play fine, but I´m missing the part with the flashing light.. A small note on this. The light are LED spotlight connected to a dimmer. I suspect they cant flash (blink) in a very high frequency due to the dimmer, my guess is a time above one second. But that i´ll have to figure out on a try.
I´m also missing the mute and activate buttons ofocuse.
Can someone help? @rlkoshak perhaps ![]()
