I’m using a Sonoff 4CH PRO (flashed with Tasmota rel 9.3.1) to automate my roof windows within OH3 (rel 3.1.0).
Everything seems to function properly, but I have a bunch of warnings in the logs each time MQTT messages arrive:
16:55:04.951 [WARN ] [tt.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.Shutter1.Position' in '{"ShutterPosition":"Done"}'
16:55:23.484 [WARN ] [tt.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.Shutter1.Position' in '{"POWER2":"OFF"}'
16:55:23.505 [WARN ] [tt.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.Shutter1.Position' in '{"POWER1":"ON"}'
16:55:23.515 [WARN ] [tt.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.Shutter1.Position' in '{"ShutterPosition1":0}'
16:55:27.345 [WARN ] [tt.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.Shutter1.Position' in '{"POWER1":"OFF"}'
16:55:37.097 [WARN ] [tt.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.Shutter1.Position' in '{"POWER2":"ON"}'
16:55:37.119 [WARN ] [tt.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.Shutter1.Position' in '{"POWER1":"ON"}'
16:55:37.130 [WARN ] [tt.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.Shutter1.Position' in '{"ShutterPosition1":100}'
16:55:44.140 [WARN ] [tt.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.Shutter1.Position' in '{"POWER1":"OFF"}'
16:55:44.159 [WARN ] [tt.generic.ChannelStateTransformation] - Executing the JSONPATH-transformation failed: Invalid path '$.Shutter1.Position' in '{"POWER2":"OFF"}'
My configuration is the following
Things:
Thing topic sonoffPs19 "Sonoff Power Switch 19" @ "MQTT-Tasmota" {
Channels:
Type rollershutter : finestra "Lucernaio camera Matr" [
stateTopic="switch19/stat/RESULT",
commandTopic="switch19/cmnd/shutterposition1",
transformationPattern="JSONPATH:$.Shutter1.Position",
stop="STOP",
retained=false
Items:
Rollershutter switch19_Finestra "Lucernaio Camera Matr %d %%" <rollershutter> { channel="mqtt:topic:rgmqtt:sonoffPs19:finestra"}
I know the reason for the warnings is that the JSONPATH transformation receives to transform also messages that are not compliant with the searched path.
My question is if there is another way of defining the thing that donesn’t produce warnings.
