aullrich
(Alex)
October 3, 2018, 8:23pm
1
Hi
I did update from snapshot 1340 to 1379 today and I see that all my HomematicIP-Devices are offline now. Did something change here?
Device with address ‘xxxx’ not found on gateway ‘XXXX’
I already cleared the cache and tmp without success. CCU and all other Non-IP devices are working.
Does someone else see this?
@Kai Could It Be that the same happend like in
HomematicIP-Devices offline with 2.4.0 Snapshot 1330
Or is this something new?
Cheers Alex
MHerbst
(Martin Herbst)
October 3, 2018, 8:40pm
2
I have tested it with milestone M4 and in my environmen (only one HmIP device) it works.
aullrich
(Alex)
October 4, 2018, 1:53am
3
Hi, moved to M4…
All HM-IP devices still offline
Done a clean install of M4, also here all HM-IP devices offline.
Moved back to 1340, there is all fine.
Cheers Alex
MHerbst
(Martin Herbst)
October 4, 2018, 9:21am
4
Hi Alex,
I have tried it with fresh installation of 2.4 M4 on Windows 10 with minimal configuration in Paper UI (I only had to add the gateway manually) and my HmIP device works fine.
What kind of CCU are you using? You could als enable the debug output for the Homematic binding and restart OH. Maybe there is a problem in the initialization.
aullrich
(Alex)
October 4, 2018, 11:15am
5
Hi Martin,
tried it again and now it is working…
I think was something on OS side of things…
Yesterday i run a sudo apt-get update & upgrade and then changed to testing Repro and M4.
Today i changed to testing Repro and M4 and then did a sudo apt-get update & upgrade and after this finished all HM IP devices went online.
Thanks for your help…
Cheers
Alex
