[SOLVED] How can I use http binding with a https site and openhab docker?
Hi guys,
I started using openhab docker and are now facing some problems with the http binding.
I get SSLHandshakeExceptions and I don’t know what to do. The cert of the site is valid and I already tried installing it inside the container via
docker exec openhab cp <path>httpsSite.cert /usr/local/share/ca-certificates/httpsSite.crt
docker exec openhab update-ca-certificates
but that had no effect.
Inside the docker is no keytool available and I don’t know in which keystore i had to import the cert either.
I also thought about importing it into the keystore located at userdata/etc/keystore which I can directly access on my host, but it’s password protected and I could not find the password anywhere.
The log shows the following error:
[ERROR] [org.openhab.io.net.http.HttpUtil    ] - Fatal transport error: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[ERROR] [ab.binding.http.internal.HttpBinding] - No response received from 'https://httpsSite'
I hope someone who is not a bloody beginner like me can help me.
Ok so a short update on this:
I could find out that a cert in the certification chain is missing with the help of wget.
After I added the missing cert to /usr/local/share/ca-certificates/ and called update-ca-certificates wget has no longer an error accessing the site.
Unfortunately the http binding error is still occuring.
Does anybody know which certificates the binding is using?
Finally it’s working!
My solution:
Place the missing cert and a batch script in the config directory which is mounted inside the container.
The scrip is:
installCert
#!/bin/bash
$JAVA_HOME/bin/keytool -importcert -file /openhab/conf/services/<missingCertName>.crt -keystore $JAVA_HOME/jre/lib/security/cacerts -storepass changeit -alias <certName>
and finally call it on the container creation:
docker run \
    --name openhab \
    --restart unless-stopped \
    --detach \
    openhab/openhab
docker exec openhab /openhab/conf/services/installCert
