viktor
(Vitor Marques)
December 17, 2018, 12:02pm
#1
Newbie here.
Desperately trying to install miio (not mihome, which I installed via PaperUi, working fine).
Dunno what else to do,
It doesn’t show on PaperUi
Tried to add directly in repository (doesn’t get better)
Console, bundle:list does not show it, tried bundle:install
Any help would be appreciated…
lfs_alp5
(Alpoy)
December 17, 2018, 12:13pm
#2
If it’s the other miio/xiaomi binding you should check (first post): Xiaomi Robot Vacuum Binding
viktor
(Vitor Marques)
December 17, 2018, 12:23pm
#3
Thanks, solved!!
I was in that post before, but didn’t paid enough attention on reading, your are right.
On the openhab console, use:
bundle:install https://openhab.jfrog.io/openhab/online-repo-snapshot/2.4/org/openhab/binding/org.openhab.binding.miio/2.4.0-SNAPSHOT/org.openhab.binding.miio-2.4.0-SNAPSHOT.jar
Installed, Restarted, and voila, got all the items in inbox!
H102
(CM6.5 H102)
December 17, 2018, 1:10pm
#4
Please mark the topic solved by clicking the square box on the post that provided the solution and edit the title to start with [Solved]. This will help others with a similar issue find a quick solution.
