OH 2.4 on RasPI using Openhabian.
Hm - I hope that is the best title here.
So basically I want to get an E-Mail when the status of an item representing a device being online/offline.
The items for that are defined as follows:
//Online status of switches / plugs
Switch Plug_Garden_TerraceLeft_Ping "Steckdose Terrasse links [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
Switch Illumination_GroundFloor_LivingRoom_Ping "Licht Wohnzimmer [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
Switch Valve_Garden_Left_Ping "Ventil Johannisbeeren [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
Switch Illumination_Garden_Blind_Ping "Licht Markise [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
Switch Pump_Basement_Circulation_Ping "Zirkulationspumpe [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
Switch Door_GroundFloor_Terrace_Ping "Terrassentüre [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
Switch Illumination_GroundFloor_Office_Ping "Licht Arbeitszimmer [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
Switch Illumination_Kitchen_GroundFloor_Ping "Licht Küche [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
Switch Illumination_KitchenBoard_GroundFloor_Ping "Licht Küchenzeile [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
Switch Thermostat_Dining_GroundFloor_Ping "Thermostat Esszimmer [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
//Online status of smoke detectors
Switch SmokeDetector_GroundFloor_LivingRoom_Ping "Rauchmelder Wohnzimmer [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
Switch SmokeDetector_GroundFloor_Entrance_Ping "Rauchmelder Flur (EG) [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
Switch SmokeDetector_2ndFloor_SleepingRoom_Ping "Rauchmelder Schlafzimmer (DG) [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
Switch SmokeDetector_2ndFloor_Entrance_Ping "Rauchmelder Vorzimmer (DG) [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
Switch SmokeDetector_2ndFloor_KidsRoom_Ping "Rauchmelder Kinderzimmer (DG) [MAP(network.map):%s]" <zwaveonline> (gDeviceOnlineState)
Along with the group gDeviceOnlineState:
Group:Switch:OR(OFF,ON) gDeviceOnlineState "Geräte offline [%d]" <network> (gRestoreOnStartup)
My current rule is, to send an E-Mail when this group gets updated:
rule "Device online state changed"
Member of gDeviceOnlineState changed
val StringBuilder ReportString = new StringBuilder
val OnlineDevices = gDeviceOnlineState.members.filter[ i | i.state==ON]
val OfflineDevices = gDeviceOnlineState.members.filter[ i | i.state==OFF]
if(OnlineDevices !== null && OfflineDevices !== null)
ReportString.append("The state of the item " + triggeringItem.name + " has changed to " + triggeringItem.state + "\n\r")
ReportString.append("The following devices are online:\n\r")
OnlineDevices.forEach[i|
ReportString.append(i.name + "\n")
ReportString.append("\n\r\n\rThe following devices are offline:\n\r")
OfflineDevices.forEach[i|
sendMail("some e-mail adress", "openhab device connectivity changed", ReportString.toString)
logInfo("device state", ReportString.toString)
So I am enumerating Online and Offline devices in different lists and create a string that then is sent via E-Mail.
This string looks like:
The state of the item Sonoff4CH_Garden_RaisedBed_Ping has changed to OFF
MoistureRaisedBed_SensorState
Sensor_Gateway_Garden_Ping
Denon_Reciever_Ping
So everything is working, but my problem appears e.g. when Openhab boots and the devices change their states one after the other. My Inbox then looks like:
So after this long explanation i’d like to know if theres an elegant way to handle this?
I think of two possibilities:
- Ignore this rule during startup (how can I achieve this)?
- Have an algorithm that only sends an E-Mail when either a minimum amount of updates to that group has been fired or if the last E-Mail was more than x minutes ago.
Any suggestions are appreciated - sometimes i’m going to make things more complicated than needed
