Is there a central thread just for the Harmony Hub binding rather than the firmware is broke one here? Saw a new binding post above but wasn’t sure if that was officially a new version from the author or just something that some of the forum was playing with.
The jfrog server is an official server that does automatic daily builds from the latest official changes hence the snapshot tag. I am using the above JAR in my Openhab 2.4stable install with the latest standard firmware in the HH and it appears to be working fine in the half hour I tested it last night. Just uninstall the HH binding and then drop the jar into the addons folder and it should just work as I had the textual config files still installed.
Thanks. I have nothing right now. Unboxed my two harmony hubs, one for the TV and one for another room where the other equipment is. The one will just be used to turn the TV on and off since I didn’t buy a remote. Have a Harmony 900 that I’ll be keeping intact for now. Just starting to setup the hub so will be getting to OpenHAB shortly.
Is there a way to make a “nice” remote? Everytime I try and create a remote I always have some kind of icon and a lot of space, and only two columns. Like below:
It’s like a list of power icons. Plus it always has the dash where it would show the current active command which has no value for a volume up or down or button presses.
Also any way to do an on/off switch for the power of a given device? In this case it’s strictly a remote for my TV device. There is a powrtoggle value for the remote but not sure the best way to set it up so it has an on/off toggle.
NOTE: Got rid of the power icons with icon="" still can’t get those dashes to show the variable being called across all the dashes each time I click something. Want them to go away.
SUMMARY OF THIS TOPIC ======================
Harmony Hub with firmware 4.15.206 is running only with OH 2.5.0-Snapshot after 24th February 2019, or with the latest JAR-file (putting in addons folder).
Older OH-Versions (2.0, 2.1, 2.2, 2.3, 2.4) still have to use XMPP,
if Harmony Hub is on Firmware 4.15.250, you have to enable XMPP through Harmony APP manually.
Since snapshot 2.5.0.201902252032 “Harmony binding” supports WebSocket only!
There are also introduced two new channels: buttonPress and player, see here. --> new link
All OH2 releases until MilestoneBuild 2.5.0.M1 (20-Jan-2019 14:09) do not contain WebSocket support!
Since MilestoneBuild 2.5.0.M2 (9-Aug-2019 12:37) WebSocket only is available.
Overview, see table:
Firmware version***
XMPP
WebSocket
supported OH Versions
minimum Snapshot
4.15.193
yes
yes
2.0, 2.1, 2.2, 2.3, 2.4, 2.5
4.15.201
yes
yes
4.15.206
no
yes
2.5
2.5.0.201902252032
4.15.210
yes
yes
4.15.250
no/yes**
yes
2.0*,2.1*,2.2*,2.3*,2.4*,2.5
2.5.0.201902252032
4.15.264
no/yes**
yes
2.5.0.201902252032
4.15.280
no/yes**
yes
2.5.0.201902252032
*=if XMPP is enabled, **=enableable through Logitech Harmony APP.
***=all firmware versions are supported through WebSocket with a minimum snapshot version 2.5.0.201902252032, the latest JAR file or OH2 release >= 2.5.0.M2!
See also Harmony Hub Release Notes..
How to enable XMPP in Harmony APP?
Menu > Harmony Setup > Add/Edit Devices & Activities > Remote & Hub > Enable XMPP
I was running the 2.4 Harmony Hub binding and saw constant warnings in my log, so I decided to look into it a little more and found this conversation with the 2.5 snapshot. I installed it earlier tonight, and no warnings have popped up since.
@Celaeno1, thanks for summarizing at the tail end of the thread. I’ll just add that once the 2.5 binding is installed, users can disable XMPP in the Harmony app since it’s no longer required.
