I try to setup mail communication - but it Fails to connect to the mail server.
here my mail.cfg
# The SMTP server hostname, e.g. "smtp.gmail.com"
hostname=smtp.gmail.com
# the SMTP port to use (optional, defaults to 25 (resp. 587 for TLS/SSL))
port=587
# the username and password if the SMTP server requires authentication
username=myuser@gmail.com
password=mypassword
# The email address to use for sending mails
from=myuser@gmail.com
# set to "true", if STARTTLS is enabled (not required) for the connection
# (optional, defaults to false)
#tls=true
# set to "true", if SSL negotiation should occur on connection
# do not use both tls=true and ssl=true
#ssl=true
# set to "true", if POP before SMTP (another authentication mechanism)
# should be enabled. Username and Password are taken from the above
# configuration (optional, default to false)
#popbeforesmtp=true
# Character set used to encode message body
# (optional, if not provided platform default is used)
#charset=
my sendMail rule
rule "Test Mail"
Item Reload_Variables changed
sendMail("myuser@gmail.com", "This is the email subject", "This is the email body")
after the rule is triggered - I get following event log
2018-01-11 16:47:03.569 [ERROR] [rg.openhab.action.mail.internal.Mail] - Could not send e-mail to 'myuser@gmail.com'.
org.apache.commons.mail.EmailException: javax.mail.MessagingException: Connect failed;
at org.apache.commons.mail.Email.buildMimeMessage(Email.java:1393) ~[?:?]
at org.apache.commons.mail.Email.send(Email.java:1447) ~[?:?]
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:157) ~[?:?]
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:89) ~[?:?]
at org.openhab.action.mail.internal.Mail.sendMail(Mail.java:67) ~[?:?]
Caused by: javax.mail.MessagingException: Connect failed
at com.sun.mail.pop3.POP3Store.protocolConnect(POP3Store.java:210) ~[30:javax.mail:1.4.5]
at javax.mail.Service.connect(Service.java:295) ~[30:javax.mail:1.4.5]
at javax.mail.Service.connect(Service.java:176) ~[30:javax.mail:1.4.5]
at org.apache.commons.mail.Email.buildMimeMessage(Email.java:1388) ~[?:?]
at com.sun.mail.util.SocketFetcher.createSocket(SocketFetcher.java:319) ~[30:javax.mail:1.4.5]
at com.sun.mail.util.SocketFetcher.getSocket(SocketFetcher.java:233) ~[30:javax.mail:1.4.5]
at com.sun.mail.pop3.Protocol.<init>(Protocol.java:111) ~[30:javax.mail:1.4.5]
at com.sun.mail.pop3.POP3Store.getPort(POP3Store.java:261) ~[30:javax.mail:1.4.5]
at com.sun.mail.pop3.POP3Store.protocolConnect(POP3Store.java:206) ~[30:javax.mail:1.4.5]
Using a different user - there are the same error Messages.
An der Karaf console erhalte ich folgendes log
19:30:07.890 [ERROR] [org.openhab.action.mail.internal.Mail] - Could not send e-mail to 'myuser@gmail.com'.
nested exception is:
java.net.ConnectException: Die Wartezeit fâ–’r die Verbindung ist abgelaufen (Connection timed out)
at sun.reflect.GeneratedMethodAccessor73.invoke(Unknown Source) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1085) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:141) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:215) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) ~[?:?]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:82) ~[?:?]
at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.lambda$2(RuleEngineImpl.java:343) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
... 31 more
Caused by: java.net.ConnectException: Die Wartezeit fâ–’r die Verbindung ist abgelaufen (Connection timed out)
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:?]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:?]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:?]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
at java.net.Socket.connect(Socket.java:589) ~[?:?]
at java.net.Socket.connect(Socket.java:538) ~[?:?]
... 31 more
But I can send mails with the same Information direct from python
#! /usr/bin/python
import smtplib
from email.mime.text import MIMEText
SERVER = 'smtp.gmail.com'
PORT = 587
EMAIL = 'myuser@gmail.com'
PASSWORT = 'mypassword'
EMPFAENGER = ['myuser@gmail.com' ]
SUBJECT = 'Testmail'
BODY = """
<html>
<head></head>
<body>
<style type="text/css">
.tg {border-collapse:collapse;border-spacing:0;}
.tg td{font-family:Arial, sans-serif;font-size:14px;padding:10px 5px;border-style:solid;border-width:1px;overflow:hidden;word-break:normal;}
.tg th{font-family:Arial, sans-serif;font-size:14px;font-weight:normal;padding:10px 5px;border-style:solid;border-width:1px;overflow:hidden;word-break:normal;}
.tg .tg-0ord{text-align:right}
.tg .tg-qnmb{font-weight:bold;font-size:16px;text-align:center}
</style>
<table class="tg">
<tr>
<th class="tg-qnmb" colspan="2">Testmail!!!!</th>
</tr>
</table>
</body>
</html>
session = smtplib.SMTP(SERVER, PORT)
session.set_debuglevel(1)
session.ehlo()
session.starttls()
session.ehlo
session.login(EMAIL, PASSWORT)
msg = MIMEText(BODY, 'html')
msg['Subject'] = SUBJECT
msg['From'] = EMAIL
msg['To'] = ", ".join(EMPFAENGER)
session.sendmail(EMAIL, EMPFAENGER, msg.as_string())
session.quit()
I have checked all mail related Messages - but didn’t find any similiar reason.
Thanks for your Support
