My rules randomly stop everyday/week and I don’t know if this is just a 2.4 issue or if a small change I made at some point in the last month is the cause. It’s kind of a paint to figure out what might be wrong.
- Platform information:
- Hardware: VM uppted to 8gb/2cpu/500Gb - upgraded ram and cpu, and kill X, giving me like 6Gb free, so there should be more than enough resource.
- OS: Openhabian. Openhab 2.4.01 (Only after upgrade)
- Java Runtime Environment: java version “1.8.0_191”
Java™ SE Runtime Environment (build 1.8.0_191-b12)
Java HotSpot™ 64-Bit Server VM (build 25.191-b12, mixed mode) - openHAB version: 2.4.01
- Issue of the topic: Lots of runes stop running - daily occurrence.
- Please post configurations (if applicable): Very complicated setup, lots of rules and external scripts using every method imaginable , probably in your nightmares. But it’s all been rock solid or “worked” exactly as programmed for years, until this last update. I simply don’t have time to go through thousands of LSP warning
in dozens of rules. I need a way to narrow down what the issue is.- It effects items that should be changed in rules.
- It seems like most of the rules just stop working, one timmer keeps on running, but it seems strange how everything has just stopped working.
- There isn’t anything obvious in the logs, just the fact the rules stop running.
My main issue is I have no clue what the problem is, I can’t try a fix or disable my light rules,. while waiting a day to a week to see if it’s fixed it. So I really need to know how to properly debug and find out why multiples rules just stop running.
Here are my threads and top. I uninstall red node after and killed x so there shouldn’t be any problem there.
"CM Configuration Updater" Id=25 in WAITING on lock=java.util.LinkedList@46fef272
at java.lang.Object.wait(Native Method)
at java.lang.Object.wait(Object.java:502)
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:79)
at java.lang.Thread.run(Thread.java:748)
"CM Event Dispatcher" Id=26 in WAITING on lock=java.util.LinkedList@141914bc
"fileinstall-/usr/share/openhab2/addons" Id=39 in TIMED_WAITING on lock=org.apache.felix.fileinstall.internal.DirectoryWatcher@262fcfd3
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:320)
"pool-1-thread-1" Id=43 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@74deba23
at sun.misc.Unsafe.park(Native Method)
at java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078)
at java.util.concurrent.LinkedBlockingDeque.pollFirst(LinkedBlockingDeque.java:522)
at java.util.concurrent.LinkedBlockingDeque.poll(LinkedBlockingDeque.java:684)
at sun.nio.fs.AbstractWatchService.poll(AbstractWatchService.java:108)
at org.apache.karaf.jaas.modules.properties.AutoEncryptionSupport.run(AutoEncryptionSupport.java:77)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
"HTTP Refresh Service" Id=267 in TIMED_WAITING
at java.lang.Thread.sleep(Native Method)
at org.openhab.core.service.AbstractActiveService$RefreshThread.pause(AbstractActiveService.java:186)
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:170)
"MQTT Rec: dellDebra" Id=269 in RUNNABLE (running in native)
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.socketRead(SocketInputStream.java:116)
at java.net.SocketInputStream.read(SocketInputStream.java:171)
at java.net.SocketInputStream.read(SocketInputStream.java:141)
at java.net.SocketInputStream.read(SocketInputStream.java:224)
at java.io.DataInputStream.readByte(DataInputStream.java:265)
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:65)
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:107)
"MQTT Snd: dellDebra" Id=270 in WAITING on lock=java.lang.Object@71c96327
at org.eclipse.paho.client.mqttv3.internal.ClientState.get(ClientState.java:743)
at org.eclipse.paho.client.mqttv3.internal.CommsSender.run(CommsSender.java:100)
"MQTT Call: dellDebra" Id=271 in WAITING on lock=java.lang.Object@204a7b3a
at org.eclipse.paho.client.mqttv3.internal.CommsCallback.run(CommsCallback.java:150)
"openHAB-job-scheduler_QuartzSchedulerThread" Id=112 in TIMED_WAITING on lock=java.lang.Object@ac2edd9
at org.quartz.core.QuartzSchedulerThread.run(QuartzSchedulerThread.java:311)
"main" Id=1 in WAITING on lock=java.util.concurrent.atomic.AtomicReference@51b7329
at org.eclipse.osgi.container.SystemModule.waitForStop(SystemModule.java:168)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle.waitForStop(EquinoxBundle.java:250)
at org.eclipse.osgi.launch.Equinox.waitForStop(Equinox.java:181)
at org.apache.karaf.main.Main.awaitShutdown(Main.java:641)
at org.apache.karaf.main.Main.main(Main.java:188)
"Framework Event Dispatcher: org.eclipse.osgi.internal.framework.EquinoxEventPublisher@1b45c0e" Id=12 in WAITING on lock=org.eclipse.osgi.framework.eventmgr.EventManager$EventThread@2cb1d36b
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.getNextEvent(EventManager.java:400)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:336)
"Start Level: Equinox Container: dd64a1de-4327-4887-8db7-a727c3527481" Id=13 in WAITING on lock=org.eclipse.osgi.framework.eventmgr.EventManager$EventThread@345f5119
"Karaf Lock Monitor Thread" Id=14 in TIMED_WAITING
at org.apache.karaf.main.Main.doMonitor(Main.java:404)
at org.apache.karaf.main.Main.access$100(Main.java:74)
at org.apache.karaf.main.Main$3.run(Main.java:377)
"Karaf Shutdown Socket Thread" Id=15 in RUNNABLE (running in native)
at java.net.PlainSocketImpl.socketAccept(Native Method)
at java.net.AbstractPlainSocketImpl.accept(AbstractPlainSocketImpl.java:409)
at java.net.ServerSocket.implAccept(ServerSocket.java:545)
at java.net.ServerSocket.accept(ServerSocket.java:513)
at org.apache.karaf.main.ShutdownSocketThread.run(ShutdownSocketThread.java:65)
"fileinstall-/var/lib/openhab2/etc" Id=29 in TIMED_WAITING on lock=org.apache.felix.fileinstall.internal.DirectoryWatcher@4c101bba
"Bundle File Closer" Id=37 in WAITING on lock=org.eclipse.osgi.framework.eventmgr.EventManager$EventThread@3f3db11c
"SCR Component Actor" Id=41 in WAITING on lock=java.util.LinkedList@48e746d0
at org.apache.felix.scr.impl.ComponentActorThread.run(ComponentActorThread.java:83)
"pool-3-thread-1" Id=47 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@38c429fb
"Thread-23" Id=60 in RUNNABLE (running in native)
at java.net.PlainDatagramSocketImpl.receive0(Native Method)
- locked java.net.PlainDatagramSocketImpl@6b805f5f
at java.net.AbstractPlainDatagramSocketImpl.receive(AbstractPlainDatagramSocketImpl.java:143)
at java.net.DatagramSocket.receive(DatagramSocket.java:812)
- locked java.net.DatagramPacket@5ac2c292
- locked java.net.DatagramSocket@74790f9f
at org.openhab.binding.milight.internal.protocol.MilightDiscover.run(MilightDiscover.java:205)
"Dir Watcher" Id=62 in WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@69699c5d
at java.util.concurrent.locks.LockSupport.park(LockSupport.java:175)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2039)
at java.util.concurrent.LinkedBlockingDeque.takeFirst(LinkedBlockingDeque.java:492)
at java.util.concurrent.LinkedBlockingDeque.take(LinkedBlockingDeque.java:680)
at sun.nio.fs.AbstractWatchService.take(AbstractWatchService.java:118)
at org.eclipse.smarthome.core.service.WatchQueueReader.run(WatchQueueReader.java:210)
"qtp1561008917-72" Id=72 in RUNNABLE (running in native)
at sun.nio.ch.EPollArrayWrapper.epollWait(Native Method)
at sun.nio.ch.EPollArrayWrapper.poll(EPollArrayWrapper.java:269)
at sun.nio.ch.EPollSelectorImpl.doSelect(EPollSelectorImpl.java:93)
at sun.nio.ch.SelectorImpl.lockAndDoSelect(SelectorImpl.java:86)
- locked sun.nio.ch.Util$3@19562341
- locked java.util.Collections$UnmodifiableSet@1943750a
- locked sun.nio.ch.EPollSelectorImpl@5d6d93de
at sun.nio.ch.SelectorImpl.select(SelectorImpl.java:97)
at sun.nio.ch.SelectorImpl.select(SelectorImpl.java:101)
at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.select(ManagedSelector.java:396)
at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.produce(ManagedSelector.java:333)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produceTask(EatWhatYouKill.java:357)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:181)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:132)
at org.eclipse.jetty.io.ManagedSelector$$Lambda$158/1203234312.run(Unknown Source)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680)
"qtp1561008917-73-acceptor-0@5460aa4d-0.0.0.0:8443@44c3df5a{SSL,[ssl, http/1.1]}{0.0.0.0:8443}" Id=73 in RUNNABLE (running in native)
at sun.nio.ch.ServerSocketChannelImpl.accept0(Native Method)
at sun.nio.ch.ServerSocketChannelImpl.accept(ServerSocketChannelImpl.java:422)
at sun.nio.ch.ServerSocketChannelImpl.accept(ServerSocketChannelImpl.java:250)
- locked java.lang.Object@4397e2
at org.eclipse.jetty.server.ServerConnector.accept(ServerConnector.java:369)
at org.eclipse.jetty.server.AbstractConnector$Acceptor.run(AbstractConnector.java:639)
"qtp1561008917-77-acceptor-0@5340419e-default@2097ec48{HTTP/1.1,[http/1.1]}{0.0.0.0:8080}" Id=77 in RUNNABLE (running in native)
- locked java.lang.Object@7c8cb003
"Thread-30" Id=80 in RUNNABLE (running in native)
- locked java.net.PlainDatagramSocketImpl@35097566
- locked java.net.DatagramPacket@3d6ae0a8
- locked java.net.DatagramSocket@6561b3e8
"Thread-33" Id=88 in RUNNABLE (running in native)
- locked java.net.PlainDatagramSocketImpl@1c72b67a
- locked java.net.DatagramPacket@7fd62c2
- locked java.net.DatagramSocket@6381956e
"ESH-OSGiEventManager" Id=92 in TIMED_WAITING on lock=java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject@1432fae
at java.util.concurrent.LinkedBlockingQueue.poll(LinkedBlockingQueue.java:467)
at org.eclipse.smarthome.core.internal.events.ThreadedEventHandler.lambda$0(ThreadedEventHandler.java:61)
at org.eclipse.smarthome.core.internal.events.ThreadedEventHandler$$Lambda$211/1621258594.run(Unknown Source)
"Karaf ssh console user openhab" Id=592287 in RUNNABLE
at sun.misc.Unsafe.unpark(Native Method)
at java.util.concurrent.locks.LockSupport.unpark(LockSupport.java:141)
at java.util.concurrent.SynchronousQueue$TransferStack$SNode.tryMatch(SynchronousQueue.java:265)
at java.util.concurrent.SynchronousQueue$TransferStack.transfer(SynchronousQueue.java:383)
at java.util.concurrent.SynchronousQueue.offer(SynchronousQueue.java:913)
at java.util.concurrent.ThreadPoolExecutor.execute(ThreadPoolExecutor.java:1371)
at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:112)
at org.apache.felix.gogo.runtime.CommandSessionImpl$JobImpl.start(CommandSessionImpl.java:795)
- locked org.apache.felix.gogo.runtime.CommandSessionImpl$JobImpl@13862838
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:300)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:169)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:149)
at org.apache.felix.gogo.runtime.CommandSessionImpl.execute(CommandSessionImpl.java:179)
at org.apache.karaf.shell.impl.console.ConsoleSessionImpl.doExecute(ConsoleSessionImpl.java:462)
at org.apache.karaf.shell.impl.console.ConsoleSessionImpl.run(ConsoleSessionImpl.java:402)
openhab+ 14764 0.0 0.0 38628 3608 pts/1 R+ 22:59 0:00 ps aux --sort -rss
root 8670 0.0 0.0 375684 3600 ? Ssl 2018 0:03 /usr/lib/udisks2/udisksd --no-debug
root 1471 0.0 0.0 320180 3568 ? S 2018 0:08 /usr/sbin/smbd
lightdm 28461 0.0 0.0 44992 3416 ? Ss 2018 0:00 /usr/bin/dbus-daemon --session --address=systemd: --nofo
lightdm 28463 0.0 0.0 44992 3404 ? S 2018 0:00 /usr/bin/dbus-daemon --config-file=/usr/share/defaults/a
homegear 1461 0.2 0.0 1465924 3400 ? SLsl 2018 96:38 /usr/bin/homegear -u homegear -g homegear -p /var/run/ho
openhab+ 8681 0.0 0.0 368752 3248 ? Sl 2018 0:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.17 /org/gtk/gvfs/
openhab+ 8578 0.0 0.0 390812 3108 ? Ssl 2018 0:23 xfsettingsd --display :0.0 --sm-client-id 2e348dda8-1236
message+ 637 0.0 0.0 45872 2932 ? Ss 2018 0:32 /usr/bin/dbus-daemon --system --address=systemd: --nofor
openhab+ 8713 0.0 0.0 21352 2560 pts/2 Ss+ 2018 0:00 /bin/bash
root 1434 0.0 0.0 320196 2552 ? Ss 2018 0:03 /usr/sbin/smbd
root 678 0.0 0.0 119712 2516 ? Ssl 2018 0:30 /usr/sbin/findserver -mqtt localhost:1883 -mqttadmin fin
root 1436 0.0 0.0 310020 2488 ? S 2018 0:02 /usr/sbin/smbd
openhab+ 8574 0.0 0.0 189272 2376 ? S 2018 0:00 Thunar --sm-client-id 29c48a3a9-2aab-4b63-a6a3-6c92f93a3
root 635 0.0 0.0 250116 2344 ? Ssl 2018 0:17 /usr/sbin/rsyslogd -n
root 8585 0.0 0.0 310344 2300 ? Ssl 2018 0:00 /usr/lib/upower/upowerd
mosquit+ 674 0.0 0.0 42288 2276 ? S 2018 11:30 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
root 828 0.0 0.0 20484 2124 ? S 2018 0:00 /sbin/dhclient -d -q -sf /usr/lib/NetworkManager/nm-dhcp
root 829 0.0 0.0 20480 2060 ? S 2018 0:00 /sbin/dhclient -d -q -sf /usr/lib/NetworkManager/nm-dhcp
openhab+ 2224 0.0 0.0 56676 2012 ? S 2018 0:02 /usr/lib/x86_64-linux-gnu/xfce4/xfconf/xfconfd
avahi 657 0.0 0.0 47140 1892 ? Ss 2018 1:21 avahi-daemon: running [debra.local]
root 390 0.0 0.0 46172 1884 ? Ss 2018 0:01 /lib/systemd/systemd-udevd
openhab+ 2221 0.0 0.0 220216 1860 ? Sl 2018 0:00 /usr/lib/at-spi2-core/at-spi2-registryd --use-gnome-sess
root 357 0.0 0.0 134060 1852 ? Ss 2018 20:42 /usr/bin/vmtoolsd
lightdm 28448 0.0 0.0 169108 1640 ? S 2018 0:00 (sd-pam)
openhab+ 1170 0.0 0.0 45452 1472 ? Ss 2018 0:04 /usr/bin/dbus-daemon --session --address=systemd: --nofo
root 723 0.0 0.0 69952 1352 ? Ss 2018 0:00 /usr/sbin/sshd -D
root 625 0.0 0.0 36212 1308 ? Ss 2018 1:26 /usr/sbin/inetd
root 385 0.0 0.0 107200 1232 ? Ss 2018 0:00 /sbin/lvmetad -f
www-data 767 0.0 0.0 430516 1220 ? Sl 2018 6:24 /usr/sbin/apache2 -k start
Debian-+ 1446 0.0 0.0 58212 1112 ? Ss 2018 0:00 /usr/sbin/exim4 -bd -q30m
openhab+ 2104 0.0 0.0 45120 972 ? S 2018 0:00 /usr/bin/dbus-daemon --config-file=/usr/share/defaults/a
root 631 0.0 0.0 29664 964 ? Ss 2018 0:12 /usr/sbin/cron -f
www-data 766 0.0 0.0 561540 804 ? Sl 2018 6:25 /usr/sbin/apache2 -k start
openhab 17489 0.0 0.0 5880 800 ? S 2018 0:18 tail -n 200 -F /var/log/openhab2/openhab.log /var/log/op
root 9028 0.0 0.0 44992 788 ? Ss 2018 0:00 /usr/bin/dbus-daemon --fork --print-pid 5 --print-addres
root 1437 0.0 0.0 310036 760 ? S 2018 0:02 /usr/sbin/smbd
root 630 0.0 0.0 422460 660 ? Ssl 2018 0:00 /usr/sbin/ModemManager
openhab+ 11604 0.0 0.0 11092 336 ? Ss Jan11 0:00 ssh-agent -s
openhab+ 15904 0.0 0.0 11092 336 ? Ss 18:46 0:00 ssh-agent -s
openhab+ 927 0.0 0.0 11092 332 ? Ss 2018 0:00 ssh-agent -s
openhab+ 3712 0.0 0.0 11092 332 ? Ss Jan01 0:00 ssh-agent -s
openhab+ 4813 0.0 0.0 11092 332 ? Ss 22:15 0:00 ssh-agent -s
openhab+ 16653 0.0 0.0 11092 332 ? Ss 2018 0:00 ssh-agent -s
openhab+ 17708 0.0 0.0 11092 332 ? Ss 2018 0:00 ssh-agent -s
openhab+ 18647 0.0 0.0 11092 332 ? Ss 2018 0:00 ssh-agent -s
openhab+ 20029 0.0 0.0 11092 332 ? Ss Jan12 0:00 ssh-agent -s
openhab+ 21523 0.0 0.0 11092 332 ? Ss 2018 0:00 ssh-agent -s
openhab+ 22117 0.0 0.0 11092 332 ? Ss Jan12 0:00 ssh-agent -s
openhab+ 23877 0.0 0.0 11092 332 ? Ss 21:21 0:00 ssh-agent -s
openhab+ 2931 0.0 0.0 11092 328 ? Ss 2018 0:00 ssh-agent -s
openhab+ 6168 0.0 0.0 11092 328 ? Ss Jan11 0:00 ssh-agent -s
openhab+ 30675 0.0 0.0 11092 328 ? Ss Jan02 0:00 ssh-agent -s
openhab+ 8645 0.0 0.0 290472 292 ? S<l 2018 0:00 /usr/bin/pulseaudio --start --log-target=syslog
root 1049 0.0 0.0 245684 284 ? Sl 2018 0:00 lightdm --session-child 14 17
nobody 675 0.0 0.0 128664 208 ? Ssl 2018 1:20 /usr/sbin/telldusd
openhab+ 1453 0.0 0.0 11092 112 ? Ss 2018 0:07 /usr/bin/ssh-agent x-session-manager
openhab+ 1088 0.0 0.0 86964 104 ? S 2018 0:00 (sd-pam)
root 765 0.0 0.0 75628 72 ? Ss 2018 1:05 /usr/sbin/apache2 -k start
systemd+ 620 0.0 0.0 129348 68 ? Ssl 2018 0:02 /lib/systemd/systemd-timesyncd
avahi 661 0.0 0.0 47016 24 ? S 2018 0:00 avahi-daemon: chroot helper
openhab+ 1125 0.0 0.0 4288 8 ? Ss 2018 0:00 /bin/sh /etc/xdg/xfce4/xinitrc -- /etc/X11/xinit/xserver
root 627 0.0 0.0 153492 4 ? Ss 2018 0:00 /usr/bin/VGAuthService
root 722 0.0 0.0 36572 4 ? S 2018 0:00 /usr/sbin/xrdp-sesman
openhab+ 1986 0.0 0.0 348696 4 ? Ssl 2018 0:00 /usr/lib/at-spi2-core/at-spi-bus-launcher
openhab+ 8569 0.0 0.0 213124 4 ? Sl 2018 0:00 gnome-keyring-daemon --start
openhab+ 8601 0.0 0.0 284392 4 ? Ssl 2018 0:00 /usr/lib/gvfs/gvfsd
openhab+ 8640 0.0 0.0 187292 4 ? Sl 2018 0:00 /usr/lib/dconf/dconf-service
root 9027 0.0 0.0 48132 4 pts/2 S 2018 0:00 dbus-launch --autolaunch 56150b9afef84668a01c4560eac8fd0
root 2 0.0 0.0 0 0 ? S 2018 0:00 [kthreadd]
Ps aux --srt rss
