Thing 1 = iFan03 w/ Tasmota firmware and MQTT connection.
Thing 2 = Z-Wave S2 Zooz switch
Each has a channel linked to a simple switch item for the light controlled by the iFan, and they are set to use the follow profile.
If I toggle the light in openHAB, it works as expected. The light turns on, the panel is updated and the Zooz switch flips to on. If I toggle the light with Zooz switch, nothing but the Zooz changes and if I toggle the light via the webui for the iFan,same thing, nothing but the iFan changes.
If I set the iFan light channel to default, but leave the Zooz on follow. Toggling in Openhab works, toggling the WebUI works, but toggling the Zooz changes nothing but itâself.
If the iFan link is set to follow, and Zooz is set to default. The it all works as expected from the Zooz, the WebUI on the iFan changes nothing but itâself and toggling it from openHab causes it to react to the button click, changes the iFan and the Zooz, but then immediately toggles again by itâself, puts a red halo around the button and no matter how many times you click it, itâll execute the action, then immediately toggle it a second time afterwards.
If both are set to the default profile then very odd things happen that are hard to explain, things like ifan turning itself back on after you click the button in openHAB, but suffice it to say it does not work as expected.
I suspect this is probably an easy fix, but no amount of googling seems to be helping me on this one, or searching the forum. So any advice or help would be greatly appreciated.
