Assuming you want to set bits two and four:
BIT No 7 6 5 4 3 2 1 0
BIN 0 0 0 1 0 1 0 0
HEX 0 0 0 1 0 4 0 0 = 14
DEC 128 64 32 16 8 4 2 1 = 20 (16+4)
In your config you need to enter the decimal number.
BIN 0 0 0 1 0 1 0 0
thank you very much for the explanation. At least I know now, that I understood it right
Do you have any ideas what I could try, when I still donāt get any motion report?
I donāt need luminance or temp, if I could get motion report instead.
Have you set the dip switches on the device correctly? Not that it is still in testing mode.
Otherwise it has to work with OH2 - I am running two devices successfully.
Also check parameters:
2: -1
3: 80
4: 99
5: 8
6: 20
8: 3
It doesnāt seem to matter what I changeā¦
Both dips are OFF, (if I turn them on into test mode, The LED reports works, so dips seem to be ok)
There is also an undocumented Switch called S4, I tried this one as well, but it didnāt changed anything.
When I update the values via openhabmin the value gets updated, but it has no impact.
I created a little sheet to faster try different settings
Do I have to wait ages until those vals will be updated?
The thing is, that I have one sensor which works perfectly, and all other 3 sensors (with older firmware and from Hauppauge instead from philo directly) are not reporting motion.
//is working
Number MS_Battery "Battery [%d %%]" (Status) { channel="zwave:device:5e0fd4ba:node17:sensor_battery" }
Number MS_Temperature "Temperature EG [%.1f Ā°C]" <temperature> (Status,Temperature) { channel="zwave:device:5e0fd4ba:node17:sensor_temperature" }
Number MS_Bright "Brightness [%d]" (Status) { channel="zwave:device:5e0fd4ba:node17:sensor_luminance" }
Contact MS_Door "Door [%s]" (Status, Doors) { channel="zwave:device:5e0fd4ba:node17:sensor_door" }
Switch MS_Motion "Door Motion[%s]" <motion> (Status) { channel="zwave:device:5e0fd4ba:node17:alarm_motion" }
Number MS_Alarm "Alarm [%d]" (Status) { channel="zwave:device:5e0fd4ba:node17:alarm_tamper" }
Switch MS_AAlarm "Alarm Access [%s]" <motion> (Status) { channel="zwave:device:5e0fd4ba:node17:alarm_access" }
//is not working
Number MS_T_Battery "Battery T [%d %%]" (Status) { channel="zwave:device:5e0fd4ba:node23:sensor_battery" }
Number MS_T_Temperature "Temperature EG T [%.1f Ā°C]" <temperature> (Status,Temperature) { channel="zwave:device:5e0fd4ba:node23:sensor_temperature" }
Number MS_T_Bright "Brightness T [%d]" (Status) { channel="zwave:device:5e0fd4ba:node23:sensor_luminance" }
Contact MS_T_Door "Door T [%s]" (Status, Doors) { channel="zwave:device:5e0fd4ba:node23:sensor_door" }
Switch MS_T_Motion "Door T Motion [%s]" <motion> (Status) { channel="zwave:device:5e0fd4ba:node23:alarm_motion" }
Number MS_T_Alarm "Alarm T [%d]" (Status) { channel="zwave:device:5e0fd4ba:node23:alarm_tamper" }
Switch MS_T_AAlarm "Alarm T Access [%s]" (Status) { channel="zwave:device:5e0fd4ba:node23:alarm_access" }
I restarted openhab service and also reboot the pi 3.
I also switched from latest OH2 stable to openHAB 2.2.0 Build #1058ā¦
After playing around, I found when I set motion to OFF manually, the device will receive an motion On, when motion is happeningā¦ But the motion will not update back to off state, even when I cover the whole device, so no motion could be happening.
My current workaround for this issue is a rule, which now triggers off after some time has after the on passed.
It is still weird, that the custom function doesnāt seem to have a real impact, but at least I found a workaroundā¦
Yea, it is intended that there is no Motion OFF sent by the device.
Maybe give this a read:
Great. Iām tinkering since two weeks with a D-Link version of that device and was always wondering why I canāt get the OFF command to work.
Iām using the expire binding to turn it OFF by the way. This was meant as a workaround, but now it has to be the final solution I think
I think this has been updated by the firmware ā¦ With a more updated Firmware 1.24, I get the off command. But the latest devices by Hauppauge with older Firmware 1.16 donĀ“t report it.
And unfortunately there is no way updating the Deviceā¦ I already spoke to CEO of Philo, and they donāt want to publish the Firmware to public (only to provider who could assure that the device will not break during update)ā¦
Just use the expire binding and your problem is solved:
Switch DCH-Z120 {channel="zwave:device:15ca6a108b9:node39:alarm_motion" , expire="2s,command=OFF"}
Hi there
Was this issue ever really solved?
I just recently shifted to OH2, and I am converting my OH1 setup one by one. My most reliable PIR sensor was the PST02-B, which I have yet to change battery in, and turns on my light every time. #AWESOME
Until now, that is. I cannot for the love of ā¦ get the Binary Sensor channel to work. I briefly tried the Alarm channel, but as you mention, it does not send an off command. However, the ON command returnes as expected.
From the log file, you can see that the basic entry calls out with 255 when I enter the room, and 4 minutes later with 0.
However, my item, does not get updated, and even with a rule set to Technic_Room_PIR.changed is not getting called.
Any ideas?
Switch Technic_Room_PIR "Technic Room PIR [MAP(motion.map):%s]" <pir> (All_PIRs) { channel="zwave:device:15f5e96a49b:node11:sensor_binary" }
2017-11-01 20:35:12.729 [ZWaveBatteryCommandClass ] - NODE 11: Battery report value = 100
2017-11-01 20:35:12.730 [ZWaveThingHandler ] - NODE 11: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-11-01 20:35:12.730 [ZWaveThingHandler ] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = BATTERY, value = 100
2017-11-01 20:35:12.731 [ZWaveThingHandler ] - NODE 11: Updating channel state zwave:device:15f5e96a49b:node11:battery-level to 100 [DecimalType]
2017-11-01 20:35:12.774 [icationCommandMessageClass] - NODE 11: Application Command Request (ALIVE:DETAILS)
2017-11-01 20:35:12.774 [icationCommandMessageClass] - NODE 11: Incoming command class ALARM
2017-11-01 20:35:12.775 [ZWaveAlarmCommandClass ] - NODE 11: Received ALARM command V4
2017-11-01 20:35:12.775 [ZWaveAlarmCommandClass ] - NODE 11: Process NOTIFICATION_REPORT V4
2017-11-01 20:35:12.775 [ZWaveAlarmCommandClass ] - NODE 11: NOTIFICATION report - 0 = 0, event=8, status=255
2017-11-01 20:35:12.776 [ZWaveAlarmCommandClass ] - NODE 11: Alarm Type = BURGLAR (0)
2017-11-01 20:35:12.777 [ZWaveThingHandler ] - NODE 11: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2017-11-01 20:35:12.777 [ZWaveThingHandler ] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2017-11-01 20:35:12.778 [ZWaveThingHandler ] - NODE 11: Updating channel state zwave:device:15f5e96a49b:node11:alarm_burglar to ON [OnOffType]
2017-11-01 20:35:12.813 [icationCommandMessageClass] - NODE 11: Application Command Request (ALIVE:DETAILS)
2017-11-01 20:35:12.813 [icationCommandMessageClass] - NODE 11: Incoming command class BASIC
2017-11-01 20:35:12.814 [ZWaveBasicCommandClass ] - NODE 11: Received Basic Request
2017-11-01 20:35:12.814 [ZWaveBasicCommandClass ] - NODE 11: Basic Set sent to the controller will be processed as Basic Report
2017-11-01 20:35:12.814 [ZWaveBasicCommandClass ] - NODE 11: Basic report, value = 0xFF
2017-11-01 20:35:12.815 [ZWaveThingHandler ] - NODE 11: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-11-01 20:35:12.815 [ZWaveThingHandler ] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
2017-11-01 20:35:12.868 [icationCommandMessageClass] - NODE 11: Application Command Request (ALIVE:DETAILS)
2017-11-01 20:35:12.869 [icationCommandMessageClass] - NODE 11: Incoming command class SENSOR_MULTILEVEL
2017-11-01 20:35:12.869 [ltiLevelSensorCommandClass] - NODE 11: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V5
2017-11-01 20:35:12.870 [ltiLevelSensorCommandClass] - NODE 11: Sensor Multi Level REPORT received
2017-11-01 20:35:12.870 [ltiLevelSensorCommandClass] - NODE 11: Sensor Type = Temperature(1), Scale = 0
2017-11-01 20:35:12.871 [ltiLevelSensorCommandClass] - NODE 11: Sensor Value = 21.5
2017-11-01 20:35:12.871 [ZWaveThingHandler ] - NODE 11: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2017-11-01 20:35:12.872 [ZWaveThingHandler ] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 21.5
2017-11-01 20:35:12.872 [eMultiLevelSensorConverter] - NODE 11: Sensor is reporting scale 0, requiring conversion to 0. Value is now 21.5.
2017-11-01 20:35:12.873 [ZWaveThingHandler ] - NODE 11: Updating channel state zwave:device:15f5e96a49b:node11:sensor_temperature to 21.5 [DecimalType]
2017-11-01 20:39:02.893 [icationCommandMessageClass] - NODE 11: Application Command Request (ALIVE:DETAILS)
2017-11-01 20:39:02.894 [icationCommandMessageClass] - NODE 11: Incoming command class BASIC
2017-11-01 20:39:02.895 [ZWaveBasicCommandClass ] - NODE 11: Received Basic Request
2017-11-01 20:39:02.895 [ZWaveBasicCommandClass ] - NODE 11: Basic Set sent to the controller will be processed as Basic Report
2017-11-01 20:39:02.896 [ZWaveBasicCommandClass ] - NODE 11: Basic report, value = 0x00
2017-11-01 20:39:02.898 [ZWaveThingHandler ] - NODE 11: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2017-11-01 20:39:02.899 [ZWaveThingHandler ] - NODE 11: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
Best regards
Morten Attermann Holst
Morten,
Most of my problems resolved when I started from scratch aned used habmin instead of paperui to do the config. What have you used?
I used habmin, but my device was running fine under 1.x, so all zwave configuration was done in the old system. I am wondering why the Basic report does not get theā¦
[OnOffType]
ā¦ type below the 255 value, as the ALARM does.
/Morten
In OH2 for MOTION I used the type = switch and it worked. In the OH1 I had the type set as contact, but it did not work in OH2. Not sure about the burglar alarm.
Can you post your item configuration, and the zwave cofiguration of your device.
Thanks.
/Morten
I use
Number movement { channel="zwave:device:859eefb9:node15:alarm_motion", expire="5s,state=0" }
successfully.
That could be the end for me as well.
I was, however, hoping to use the basic values, which are actually getting send, but probably not detected correct by openHAB.
I will keep your configuration in mind.
Thank you.
/Morten
With expire binding it is workingā¦
I now can read motion and contacts.
