@krishkal 1) As to the big file, some use some kind of service. I have not done that to date, so cannot advise. I did see in this post a 10MB file using a google drive of some sort. 2) As to the need, it would be to determine if it is really stuck or just moving one message at a time. In my limited experience it seems all battery devices eventually are configured, but it can be quite an adventure. 3) As to the Amazon review, I don’t think that is an issue since you have the product codes the reviewer changed to. I also do not think it would cause the problem you are seeing anyway
- After some overnight reflection re: wakeup. Try the one button press but hold for a bit (if you haven’t tried this already). Try for 0.5 sec, 1 sec, etc up to 3 seconds (about 30 seconds apart) and see if that works to get the log going. The amazon review implies this function does work. The three presses might be sending a (NIF) that gums up the works (although I have not seen that in the logs). My other wake-up suggestion is to pull the battery, wait 30 seconds and reinstall. One of my devices will wake that way.
Bob
