Hi all,
since last night I cannot see any item anymore.
Paper UI and the App doesn’t show any values.
sudo reboot does not help.
Im running OH 2.3 on Raspberry (Openhabian).
Any help appreciated!
Here is the part of the log-file after reboot.
2018-12-18 14:51:37.309 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2018-12-18 14:51:48.177 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2018-12-18 14:51:48.208 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = XXXXXXXXXXXXXXXXXXXXX, base URL = http://localhost:8080)
2018-12-18 14:51:48.363 [INFO ] [assic.internal.servlet.WebAppServlet] - Stopped Classic UI
2018-12-18 14:51:48.449 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Stopped HABmin servlet
2018-12-18 14:51:51.714 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-12-18 14:51:51.728 [INFO ] [ttp.internal.SecureHttpClientFactory] - jetty shared http client stopped
2018-12-18 14:51:51.742 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-12-18 14:51:51.773 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2018-12-18 14:52:27.394 [ERROR] [org.apache.felix.scr ] - Circular reference detected trying to get service {org.eclipse.smarthome.io.net.http.TrustManagerProvider}={service.id=116, service.bundleid=190, service.scope=bundle, component.name=org.openhab.binding.icloud.internal.to_be_moved.TrustManagerProviderImpl, component.id=13}
stack of references: ServiceReference: {org.eclipse.smarthome.io.net.http.TrustManagerProvider}={service.id=116, service.bundleid=190, service.scope=bundle, component.name=org.openhab.binding.icloud.internal.to_be_moved.TrustManagerProviderImpl, component.id=13}
ServiceReference: {org.eclipse.smarthome.io.net.http.HttpClientFactory}={service.id=127, service.bundleid=116, service.scope=bundle, component.name=org.eclipse.smarthome.io.net.http.internal.SecureHttpClientFactory, component.id=26}java.lang.Exception: stack trace
at org.apache.felix.scr.impl.ComponentRegistry.enterCreate(ComponentRegistry.java:510) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.BundleComponentActivator.enterCreate(BundleComponentActivator.java:809) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:817) [39:org.apache.felix.scr:2.0.12]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [?:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:72) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.inject.BindMethod.getServiceObject(BindMethod.java:651) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2201) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.prebind(DependencyManager.java:925) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1520) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1006) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:859) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:823) [39:org.apache.felix.scr:2.0.12]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:887) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:874) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:941) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:741) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:390) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:265) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:254) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:227) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.utils.extender.AbstractExtender.addingBundle(AbstractExtender.java:187) [39:org.apache.felix.scr:2.0.12]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.doStart(Module.java:548) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:449) [?:?]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468) [?:?]
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:103) [?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529) [?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328) [?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368) [?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:446) [?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) [?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) [?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) [?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.initDependencyManagers(AbstractComponentManager.java:976) [39:org.apache.felix.scr:2.0.12]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1003) [39:org.apache.felix.scr:2.0.12]
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183) [?:?]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:318) [?:?]
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261) [?:?]
at com.eclipsesource.jaxrs.publisher.internal.Activator.openAllServiceTracker(Activator.java:91) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at com.eclipsesource.jaxrs.publisher.internal.Activator.start(Activator.java:55) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309) [?:?]
at org.eclipse.osgi.container.Module.doStart(Module.java:581) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2018-12-18 14:52:27.461 [WARN ] [org.openhab.binding.icloud ] - FrameworkEvent WARNING - org.openhab.binding.icloud
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) [?:?]
2018-12-18 14:52:28.949 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to ‘Europe/Berlin’.
2018-12-18 14:52:28.956 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to ‘de_DE’.
2018-12-18 14:52:29.338 [INFO ] [ttp.internal.SecureHttpClientFactory] - creating httpClient for endpoint null
2018-12-18 14:52:29.526 [INFO ] [ttp.internal.SecureHttpClientFactory] - jetty shared http client created
2018-12-18 14:52:31.659 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = XXXXXXXXXXXXXXXXXXXXX, base URL = http://localhost:8080)
2018-12-18 14:53:12.286 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.66.28:8080
2018-12-18 14:53:12.289 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.66.28:8443
2018-12-18 14:53:12.380 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-12-18 14:53:12.905 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-12-18 14:53:13.011 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-12-18 14:53:13.042 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘wohnung.items’
2018-12-18 14:53:13.589 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘apple.items’
2018-12-18 14:53:13.825 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘astro.items’
2018-12-18 14:53:13.899 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘personen.items’
2018-12-18 14:53:14.469 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘openweathermap.items’
2018-12-18 14:53:15.603 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘auswahl.items’
2018-12-18 14:53:16.817 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-12-18 14:53:17.362 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘hirscheck.sitemap’
2018-12-18 14:53:17.594 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘rrd4j.persist’
2018-12-18 14:53:21.138 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘hausanschluss_fenster.rules’
2018-12-18 14:53:22.760 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘urlaub_licht.rules’
2018-12-18 14:53:23.412 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2018-12-18 14:53:24.610 [INFO ] [ng.fritzbox.internal.FritzboxBinding] - Fritzbox conditional deActivate: false
2018-12-18 14:53:24.612 [INFO ] [b.core.service.AbstractActiveService] - FritzBox refresh Service has been started
2018-12-18 14:53:24.666 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘heiz_fenster_timer.rules’
2018-12-18 14:53:25.464 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘licht_hauseingang.rules’
2018-12-18 14:53:26.330 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘lowbat.rules’
2018-12-18 14:53:27.045 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘bad_eg_fenster_timer.rules’
2018-12-18 14:53:27.666 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘schlaf_tuer_timer.rules’
2018-12-18 14:53:28.285 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘bad_og_fenster_timer.rules’
2018-12-18 14:53:28.858 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘iPhone_home.rules’
2018-12-18 14:53:29.508 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘iPad_home.rules’
2018-12-18 14:53:29.750 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘urlaub_fenster.rules’
2018-12-18 14:53:30.079 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘schlafen_heizung.rules’
2018-12-18 14:53:30.318 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘bad_heizung.rules’
2018-12-18 14:53:30.904 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘schlaf_fenster_timer.rules’
2018-12-18 14:53:32.282 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-12-18 14:53:34.268 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-ui-home’: Error restarting bundles:
Unable to acquire the state change lock for the module: osgi.identity; type=“osgi.bundle”; version:Version=“0.10.0.oh230”; osgi.identity=“org.eclipse.smarthome.model.rule.runtime”; singleton:=“true” [id=136] STARTED [STARTED]
