[SOLVED] Homematic QuantityType in M6 build problem
Hello all,
the new features of M6 build are looking very nice, so I tried to install this version.
But I got some troubles with Homematic devices and QuanityTypes of NumberItems. If you use the same code of rules and items, this will not work anymore after the upgrade from M5 to M6.
Data are coming down from Homematic device, but I am not able to send data back, like temperature setvalues.
Just had a look to the explanation of QuantityTypes in documentation, but for now I wasn´t able to get my code running again.
Easy example:
Linked Number Item of setvalue temperature to homematic setvalue channel is not working. Tried both versions, Number and Number:Temperature.
[WARN ] [ematic.handler.HomematicThingHandler] - Can't convert type QuantityType with value '20.0 °C' to FLOAT value with DecimalTypeConverter for 'NEQ0935527:2#SET_TEMPERATURE', please check the item type and the commands in your scripts
My wife was getting angry, because complete heating controllers are running with openhab….and it was getting cold inside…..so I just had to recover M5 build to get it running quickly.
But I want to give it a try, maybe someone can point me to the solution.
Thanks in advance
Sebastian
Agreed, received same message over here.using Homematic IP devices on CCU 2.
In addition I got some other but similar message like:
2018-11-21 19:26:07.013 [WARN ] [ematic.handler.HomematicThingHandler] - Can't convert type QuantityType with value '19.0 °C' to FLOAT value with DecimalTypeConverter for '000397098A4C01:1#SET_POINT_TEMPERATURE', please check the item type and the commands in your scripts 2018-11-21 19:26:07.030 [WARN ] [ematic.handler.HomematicThingHandler] - Can't convert type QuantityType with value '1' to INTEGER value with DecimalTypeConverter for '000393C98D11A0:1#CONTROL_MODE', please check the item type and the commands in your scripts
Is the error caused by rule coding or does it also accur when you simply change a item’s value? If it is caused by a rule please post the relevant code from you rule.
The quantity type was introduced in M6. Maybe it was not completly tested. If it happens if you simply set a item’s value via a front-end I would suggest to create an isue in the Smarthome github. repo.
one of the rules: (others are similar)
Code was ok and running before updating to 2.4 M6
var Timer startedTimer = null // Timer
val String filename = "heizung-modus.rules"
// Deklaration für den Timer
var Timer myTimer = null
// vordefinierte Temperaturen
val Number tempHigher = 23.0
val Number tempComfort = 21.0
val Number tempMid = 19.0
val Number tempLower = 17.0
val Number tempChill = 18.0
val Number tempAway = 18.0
val Number tempAwayLonger = 15.0
val Number tempOff = 4.5
// Heizmodi für die ganze Wohnung:
//  0 = Automatik: Betriebsmodus wie in der CCU2 hinterlegt für die normale Arbeitswoche
//  1 = Arbeit: Konstante Beheizung mit Zeitprogramm
//	2 = Keiner zuhause
//  3 = Urlaub / jemand zuhause
//	4 = Aus (Sommerbetrieb)
rule "System started"
	System started
	createTimer(now.plusSeconds(180)) [ |
		logInfo(filename, "Whg Heizung gestartet")
		if (Whg_Heating_Mode.state == NULL) Whg_Heating_Mode.postUpdate("1")
		gHeatPreset.members.filter[item | item.state == NULL].forEach[item | item.postUpdate(tempMid) ]
// Die folgende Regel arbeit mit der Regel "System Started" aus systems.rules zusammen, dort wird der Timer gesetzt
rule "Setzen des Heiz Modus" // Läuft erst nach Beendigung der Init. der Heizungsstellglieder und basiert auf der Außen- Temp.
   Item SystemStarting received command OFF
  	if (Season_Name.state.toString.contains ("SUMMER")) { //Sommerbetrieb und
  		if (Temperature.state > 12) {// Aupentemp. größer 12 Grad
  		Whg_Heating_Mode.postUpdate("4") // --> Heizung aus
  	else if //Wenn Frühling oder Herbst und wärmer als 12 Grad
  	(Season_Name.state.toString.contains ("SPRING")|| Season_Name.state.toString.contains ("AUTUMN") && Temperature.state > 15)
  	Whg_Heating_Mode.postUpdate("4") //Sommerbetrieb, Heizung aus
  	else Whg_Heating_Mode.postUpdate("1") // --> Heizung an
rule "Heizmodus umschalten und Stellglieder setzen"
	Item Whg_Heating_Mode received update or
	Item Whg_Heating_UpdateHeater received command ON
	Whg_Heating_UpdateHeater.postUpdate(OFF)
	switch Whg_Heating_Mode.state {
		case "0" : {
			logInfo(filename, "Wohnung Heizmodus: Automatik")
			WZ1_Heizung_Mode.sendCommand (0)
			WZ2_Heizung_Mode.sendCommand (0)
			KU1_Heizung_Mode.sendCommand (0)
			KU2_Heizung_Mode.sendCommand (0)
			SZ_Heizung_Mode.sendCommand (0)
			BD_Heizung_Mode.sendCommand (0)
			EZ_Heizung_Mode.sendCommand (0)
			BR_Heizung_Mode.sendCommand (0)
			Thread::sleep(30000)
			WZ1_Heizung_SetTemp.sendCommand(tempComfort)
			WZ2_Heizung_SetTemp.sendCommand(tempComfort)
			KU1_Heizung_SetTemp.sendCommand(tempComfort)
			KU2_Heizung_SetTemp.sendCommand(tempComfort)
			SZ_Heizung_SetTemp.sendCommand(tempComfort)
			BD_Heizung_SetTemp.sendCommand(tempComfort)
			EZ_Heizung_SetTemp.sendCommand(tempComfort)
			BR_Heizung_SetTemp.sendCommand(tempComfort)
		case "1" : {
			logInfo(filename, "Wohnung Heizmodus: Arbeit")
			WZ1_Heizung_Mode.sendCommand (1)
			WZ2_Heizung_Mode.sendCommand (1)
			KU1_Heizung_Mode.sendCommand (1)
			KU2_Heizung_Mode.sendCommand (1)
			SZ_Heizung_Mode.sendCommand (1)
			BD_Heizung_Mode.sendCommand (1)
			EZ_Heizung_Mode.sendCommand (1)
			BR_Heizung_Mode.sendCommand (1)
			WZ1_Heizung_SetTemp.sendCommand(WZ1_Heizung_PresetTemp.state as Number)
			WZ2_Heizung_SetTemp.sendCommand(WZ2_Heizung_PresetTemp.state as Number)
			KU1_Heizung_SetTemp.sendCommand(KU1_Heizung_PresetTemp.state as Number)
			KU2_Heizung_SetTemp.sendCommand(KU2_Heizung_PresetTemp.state as Number)
			SZ_Heizung_SetTemp.sendCommand(SZ_Heizung_PresetTemp.state as Number)
			BD_Heizung_SetTemp.sendCommand(BD_Heizung_PresetTemp.state as Number)
			EZ_Heizung_SetTemp.sendCommand(EZ_Heizung_PresetTemp.state as Number)
			BR_Heizung_SetTemp.sendCommand(BR_Heizung_PresetTemp.state as Number)
		case "2" : {
			logInfo(filename, "Wohnung Heizmodus: keiner Zuhause")
			WZ1_Heizung_SetTemp.sendCommand(tempAway)
			WZ2_Heizung_SetTemp.sendCommand(tempAway)
			KU1_Heizung_SetTemp.sendCommand(tempAway)
			KU2_Heizung_SetTemp.sendCommand(tempAway)
			SZ_Heizung_SetTemp.sendCommand(tempAway)
			BD_Heizung_SetTemp.sendCommand(tempAway)
			EZ_Heizung_SetTemp.sendCommand(tempAway)
			BR_Heizung_SetTemp.sendCommand(tempAway)
		case "3" : {
			logInfo(filename, "Wohnung Heizmodus: Urlaub (Zuhause)")
		case "4" : {
			logInfo(filename, "Wohnung Heizmodus: Aus (Sommer)")
			WZ1_Heizung_Mode.sendCommand (3)
			WZ2_Heizung_Mode.sendCommand (3)
			KU1_Heizung_Mode.sendCommand (3)
			KU2_Heizung_Mode.sendCommand (3)
			SZ_Heizung_Mode.sendCommand (3)
			BD_Heizung_Mode.sendCommand (3)
			EZ_Heizung_Mode.sendCommand (3)
			BR_Heizung_Mode.sendCommand (3)
			WZ1_Heizung_SetTemp.sendCommand(tempOff)
			WZ2_Heizung_SetTemp.sendCommand(tempOff)
			KU1_Heizung_SetTemp.sendCommand(tempOff)
			KU2_Heizung_SetTemp.sendCommand(tempOff)
			SZ_Heizung_SetTemp.sendCommand(tempOff)
			BD_Heizung_SetTemp.sendCommand(tempOff)
			EZ_Heizung_SetTemp.sendCommand(tempOff)
			BR_Heizung_SetTemp.sendCommand(tempOff)
		//case "CALENDAR" : { logInfo(filename, "Wohnung Heizmodus: CALENDAR (nicht implementiert)") }
		//case "AUTO_DEVICE" : { logInfo(filename, "Wohnung Heizmodus: AUTO_DEVICE (nicht implementiert)") }
		//case "MANU_DEVICE" : { logInfo(filename, "Wohnung Heizmodus: MANU_DEVICE (nicht implementiert)") }
		default            : { logError(filename, "Wohnung Heizmodus ungültig: " + Whg_Heating_Mode.state) }
// Nachfolgend generelles Zeitprogramm: Änderungen nur wenn unbedingt notwendig
rule "05:00 Uhr wochentags (Alle Heizungen)"
	Time cron "0 0 5 ? * MON-FRI *"
	if (Whg_Heating_Mode.state == "1") {
	//logInfo(filename, "Wohnung Heizmodus: Zeitprogramm: " + now.toString)
	WZ1_Heizung_PresetTemp.postUpdate(18.0)
	WZ2_Heizung_PresetTemp.postUpdate(18.0)
	KU1_Heizung_PresetTemp.postUpdate(21.0)
	KU2_Heizung_PresetTemp.postUpdate(21.0)
	SZ_Heizung_PresetTemp.postUpdate(18.0)
	BD_Heizung_PresetTemp.postUpdate(22.0)
	EZ_Heizung_PresetTemp.postUpdate(22.0)
	BR_Heizung_PresetTemp.postUpdate(19.0)
	Whg_Heating_UpdateHeater.sendCommand(ON)
	//logInfo(filename, "Einschalten Heizung")
rule "07:30 Uhr wochentags (Alle Heizungen)"
	Time cron "0 30 7 ? * MON-FRI *"
	if (gPresent.state == OFF) {
	logInfo(filename, "keiner daheim Heizung Standby " + now.toString)
	WZ1_Heizung_PresetTemp.postUpdate(19.0)
	WZ2_Heizung_PresetTemp.postUpdate(19.0)
	KU1_Heizung_PresetTemp.postUpdate(20.0)
	KU2_Heizung_PresetTemp.postUpdate(20.0)
	SZ_Heizung_PresetTemp.postUpdate(19.0)
	BD_Heizung_PresetTemp.postUpdate(20.0)
	EZ_Heizung_PresetTemp.postUpdate(20.0)
	else if (gPresent.state == ON) {
	logInfo(filename, "jemand daheim Heizung hochfahren " + now.toString)
	WZ1_Heizung_PresetTemp.postUpdate(21.0)
	WZ2_Heizung_PresetTemp.postUpdate(21.0)
	SZ_Heizung_PresetTemp.postUpdate(20.0)
	EZ_Heizung_PresetTemp.postUpdate(21.5)
	BR_Heizung_PresetTemp.postUpdate(20.0)
rule "10:00 Uhr"
	Time cron "0 0 10 ? * * *"
	if(gPresent.state == ON) {
	BD_Heizung_PresetTemp.postUpdate(21.0)
	EZ_Heizung_PresetTemp.postUpdate(21.0)
	logInfo(filename, "Update Heizung Temperaturen")
rule "15:10 Uhr"
	Time cron "0 10 15 ? * * *"
	WZ1_Heizung_PresetTemp.postUpdate(21.5)
	WZ2_Heizung_PresetTemp.postUpdate(21.5)
	//logInfo(filename, "Einschalten Heizung 15:10")
rule "21:15 Uhr (Mo - Do, Son)"
	Time cron "0 15 21 ? * MON-THU,SUN *"
	KU1_Heizung_PresetTemp.postUpdate(19.0)
	KU2_Heizung_PresetTemp.postUpdate(19.0)
	BD_Heizung_PresetTemp.postUpdate(19.0)
	EZ_Heizung_PresetTemp.postUpdate(19.0)
	BR_Heizung_PresetTemp.postUpdate(18.0)
// Wochenende
rule "6:30 Uhr (Wochenende)"
	Time cron "0 30 6 ? * SAT-SUN *"
rule "8:30 Uhr (Wochenende)"
	Time cron "0 30 8 ? * SAT-SUN *"
rule "22:00 Uhr (Fr - Sa)"
	Time cron "0 0 22 ? * FRI-SAT *"
Items:
Number SZ_Heizung_SetTemp           "SZ_Heizung Soll-Temperatur [%.1f %unit%]"                      <temperature>   (gSZHeat,gHeatSet)       { channel="homematic:HMIP-eTRV:574299e0:000393C98D23AB:1#SET_POINT_TEMPERATURE" }
Hi Martin,
in my case, the error occurs by changing an item manually that has a homematic binding connection.
Rule is not working as well.
Sebastian
I am currently using an older version of openHAB so I do not have any practical experience with units. But AFAIK you have to to add the unit within rules, see: Textual Rules | openHAB
Hi Sebastian,
if you have defined your items in Paper UI you could try to delete and recreate the item. Sometimes this helps (and is necessary) if an internal item definition was changed.
If the problem occurs if you change a value directly in PaperUI resp. Basic UI then I would assume that there is an error in the binding and I would recommend to create an issue.
Martin
Martin
Wow!!! Use a timer. See:
This is where your problem may lay:
		WZ1_Heizung_SetTemp.sendCommand((WZ1_Heizung_PresetTemp.state as QuantityType<Number>).doubleValue)
If WZ1_Heizung_SetTemp is a Number:Temperature then you need to convert it to a DecimalType
Converting it to a Number Type will not change anything as a QuantityType is a child of Number TYpe
The issue is probably related to the ESH #6512 and #6544 Homematic PRs.
There was actually also a fix in ESH (#6513) for improving backwards compatibility when dimensions get added to channels. It should not be necessary to remove/add Things when UoM is introduced in a binding.
Hi Martin,
sorry, this topic is still some days ago…
But I never created the items with PaperUI. I use Item files to create these.
Sebastian
Can you post your items and the rule that’s failing, please
HI,
actually I downgraded my openHAB system. So it is working again. But this item for example did the problem with M6. Also without working a rule, it was not possible to assign manually a new SV to Homematic device.
Number Wohnzimmer_FBH_SV "Soll Temperatur" <temperature> (gT_SV) {channel="homematic:HM-TC-IT-WM-W-EU:e7adadb7:MEQ1574558:2#SET_TEMPERATURE"}
You will need to change the item to:
Number:Temperature Wohnzimmer_FBH_SV "Soll Temperatur" <temperature> (gT_SV) {channel="homematic:HM-TC-IT-WM-W-EU:e7adadb7:MEQ1574558:2#SET_TEMPERATURE"}
Once that’s done then we can have a look at the rules
This is what I tried after reading the documentation.
But also didn´t work to me. Same error message.
Regarding the error created by the rule: Actually I faven´t this error anymore, due to my downgrade to M5. I cannot remeber in detail. Sorry for that.
Well, you are going to have to bite the bullet and upgrade again and work your way through the errors.
It’s likely to be the same error everywhere. So once we solved one, you’ll be able to do the rest.
BUT
Change you homematic items to add the unit, just as above
Then in the rules, whenever you are working with an item state do this:
(item.state as QuantityType<Number>).doubleValue
To convert the UoM value to a plain number
Also get rid of your Thread::sleep for 30s. BAD IDEA
Use a timer instead:
	        case "4" : {
			createTimer(now.plusSeconds(30), [ |
Yes, you are right. I need some time to do the upgrade and the investigation. Maybe end of this week.
The Thread::sleep came from another user, I know about these behaviours and try to use timers if necessairy.
Thanks for your support.
Sebastian
I was asking Wouter, how to downgrade the homematic binding back to M5.
For those who want to keep M6 within the older rules: follow the instructions below.
Yes you could try the M5 version again by:
  1. Uninstalling the Homematic binding via Paper UI
  2. Download the org.eclipse.smarthome.binding.homematic-0.10.0.oh240M5.jar
  3. Add the JAR to the /addons directory
Another way is to use that download URL for updating the bundle to the M5 version using the Console.
This is what it looks like when reverting a SNAPSHOT version of the binding to the M5 version again:
openhab> bundle:list|grep Homematic
209 │ Active   │  80 │ 0.10.0.201811171951    │ Eclipse SmartHome Homematic Binding
openhab> bundle:update 209 https://openhab.jfrog.io/openhab/libs-milestone-local/org/eclipse/smarthome/binding/org.eclipse.smarthome.binding.homematic/0.10.0.oh240M5/org.eclipse.smarthome.binding.homematic-0.10.0.oh240M5.jar
209 │ Active   │  80 │ 0.10.0.oh240M5         │ Eclipse SmartHome Homematic Binding
In the mean time there have been some fixes for the binding, e.g. [homematic] Prevent NPE in QuantityTypeConverter for unitless datapoints by FStolte · Pull Request #6565 · eclipse-archived/smarthome · GitHub , but I am not sure whether they will solve this problem. But you can try install the latest version of the Homematic binding manually.
M7 still has the described problem. I did some further testing, here are the results:
M7, M6, M5 fail with the following setup:
Item definition:
Number:Temperature HM_Wohnzimmer_RTherm_SetTemp "Set Temperature"    (gTemperatureSet)  {channel="homematic:HM-CC-RT-DN:ccu:OEQ2084718:4#SET_TEMPERATURE"}
Rule:
rule "TestSwitch"
    Item TestSwitch changed to ON
    TestSwitch.sendCommand(OFF)
    var test = 20.5|°C
    logInfo("Test", "set " + test.toString + " " + test.class.toString)
    logInfo("Test", "get " + HM_Wohnzimmer_RTherm_SetTemp.state.toString + " " + HM_Wohnzimmer_RTherm_SetTemp.state.class.toString)
    HM_Wohnzimmer_RTherm_SetTemp.sendCommand(test);
Log output:
2018-12-01 21:08:53.026 [INFO ] [.eclipse.smarthome.model.script.Test] - set 20.5 °C class org.eclipse.smarthome.core.library.types.QuantityType
2018-12-01 21:08:53.035 [INFO ] [.eclipse.smarthome.model.script.Test] - get 20.5 °C class org.eclipse.smarthome.core.library.types.QuantityType
2018-12-01 21:08:53.055 [WARN ] [ematic.handler.HomematicThingHandler] - Can't convert type QuantityType with value '20.5 °C' to FLOAT value with DecimalTypeConverter for 'OEQ2084718:4#SET_TEMPERATURE', please check the item type and the commands in your scripts
M5 works with the following setup:
Item definition:
Number HM_Wohnzimmer_RTherm_SetTemp "Set Temperature"    (gTemperatureSet)  {channel="homematic:HM-CC-RT-DN:ccu:OEQ2084718:4#SET_TEMPERATURE"}
Rule:
rule "TestSwitch"
    var test = 20.5
Log output (no error):
2018-12-01 21:13:11.626 [INFO ] [.eclipse.smarthome.model.script.Test] - set 20.5 class java.lang.Double
2018-12-01 21:13:11.641 [INFO ] [.eclipse.smarthome.model.script.Test] - get 21.5 class org.eclipse.smarthome.core.library.types.DecimalType
I installed the homematic binding included in the M5 build of Openhab into an M7 Openhab installation as mentioned by @alkaline above. So the issue is definitely in the binding and not in other components of Openhab. If I should test anything else, just let me know.
Link to the homematic binding included in the M5 build: https://openhab.jfrog.io/openhab/libs-milestone-local/org/eclipse/smarthome/binding/org.eclipse.smarthome.binding.homematic/0.10.0.oh240M5/org.eclipse.smarthome.binding.homematic-0.10.0.oh240M5.jar
just a note: Since M5, there have been several PRs on the [homematic] binding, so maybe one of them broke this HomematicThingHandler for your case. You can check which recent ones were included in the M7 here.
I didn’t find a similar Issue open on GitHub · Where software is built
Maybe this is worth posting an Issue there. You have all the info for a developer to reproduce this.
