Is there any possibility to read values from “power” state of DS1820? I think that’s not possible to configure direct from PaperUI. Iv’e build some flood sensor based on DS1820, whose logic is based on the active power status test (flood and shorting 2 pins on circuit disconnects via transistor the power supply of DS…).
I’ve tried adding to items file like:
Number TEST “TEST [%f %s]” {onewire=“deviceId=28.E6465D040000;propertyName=power;refreshinterval=60”}
and proper lines in sitemap file:
Text item=TEST
but there was no readings.
Any suggestions?
Infrastucture: OpenHAB 2.4, onewire (hosted from Ubuntu) configuration of it in PapuerUI (I don’t have bridge config in things file).
Not possible with the release version. The latest master has „direct access“ channels, you can use these to access owfs path directly. The item configuration you used above is for the onewire1 binding
Whitch version? Could you point it out (share link)? Is available for docker? Can I use onewire binding at the same time with “direct access” or maybe “da” is for example faster then ow?
PS I should add that I currently have several dozen components connected and configured in onewire.
Have a look here. Instructions are on that page. It‘s not faster than other access. You can add channels to the bridge in PaperUI and set the path to /sensorid/power (or whatever the correct path is).
No need to shutdown, just follow the instructions. You can restart after the installation, if you want. All I can say is: I never lost my configuration.
After yesterday JAR exchange (to new one and back to old one) my onewire in openhab stoped working. In logs there is multiple errors like:
2019-03-01 12:15:27.570 [TRACE] [internal.handler.OwBaseBridgeHandler] - refresh: getting handler for onewire:temperature:84eea56d:28_DC9663040000 (6 to go)
2019-03-01 12:15:27.571 [DEBUG] [internal.handler.OwBaseBridgeHandler] - onewire:temperature:84eea56d:28_DC9663040000 handler missing
2019-03-01 12:15:27.572 [TRACE] [internal.handler.OwBaseBridgeHandler] - refresh: getting handler for onewire:digitalio2:84eea56d:12_371581000000 (5 to go)
2019-03-01 12:15:27.573 [DEBUG] [internal.handler.OwBaseBridgeHandler] - onewire:digitalio2:84eea56d:12_371581000000 handler missing
I’ve deleted OW Serwer instance (bridge) and created new one with ID of previous bridge, but openhab seems to not discover my things anymore and could not read state of those defined earlier.
On old version of JAR (which worked just fine for yesterady) i have those errors, for new one there are no such errors, but non of my 1W components work (some of them (state) even flaps between on/off). Very strange.
Please help!
PS As I mantioned before my 1W items was in the first place defined via PaperUI, but in files I have things for other bindings. I found some info on Internet that when i define thing via PaperUI, then I cannot define other via files. Is it true?
You can’t use the old version after you installed the new version. This upgrade is not backwards compatible. We should fix the new version.
I just checked with one of my DS18B20 that the power status is correctly read and the channel is updated. Maybe %s is a problem, since the returned value is an integer (0 or 1). Try %d instead.
For now i have deleted all my things and I have to configure then from begining.
Ok, I will try, but could something mess up after my downgrade? I’m preety sure that after another version change to the new one (after that downgrade) nothing from 1W was working. Should I clear some cache or sometching?
Is there something to be sure that i’m starting from scratch (if I have to configute my thing from beginig)? Should I clear something? But please don’t tell me to start new clean docker with openhab, because i have there many, many other things configiured and running.
When I Was unlinking channels and then removing things, they did not want to disappear. State was removing. I have to force remove. Maybe this step has break something?
Ok, i’ve clean configuration, so I just added channel for “OW Server”:
and line in:
items: Number TEST_POWER “Test of POWER State N [%d]”
sitemap: Switch item=TEST_POWER label=“Test of POWER N State [%d]”
I wasn’t creating any things for DS1820. I’ve just linked to created channel item from items file.
