A fresh extension install, from .vsix file directly.
My guess would be, that this is one extremly rare cases where something with vscode ot the extension download is wrong and corrupts the extension or its files.
Hello community,
I am new here and newcomers to OpenHAB.
I put my system on a Raspi 4.
Openhabian installed as an image and currently use the homematic binding. That works perfect!
Now I wanted to set up the VS code. I have mounted the folder openHAB-conf as a network drive
and can see the folders in VS code.
If I want to synchronize the things now, I get the following error:
command ‘openhab.command.refreshEntry’ not found
I’ve already tried to uninstall the VS code and reinstalled, but to no avail.
Since I am absolutely new to the field, I hope someone can help me.
Thank you so much!
violine
Hello Jerome,
I only used the installation from the marketplace. Since the error occurred. Then I did the installation with vsix from GitHub. Unfortunately the mistake is here as well.
I have uninstalled and reinstalled Visual Studio code from my machine. Then set up the OpenHAB extension using the vsix file.
Unfortunately that did not bring the success. The error still exists: command 'openhab.command.refreshEntry' not found
Can someone help me with the problem?
The machine on which Visual Studio Code is installed runs on Windows 7 Professional 64-bit.
The OpenHAB is installed on a Raspberry 4 with the Openhabian system.
unfortunately, i went through all the steps as violine did (uninstall, install latest extension from vsix) and I am still at the same point with openhab.command.refreshEntry while trying to sync things or items. As an Output on openhab Server I receive: [Error - 22:20:27] Connection to server is erroring. Shutting down server.
I use raspi3 with Raspian and Win 10 64bit.
Appriciate any support on that.
Thx JD
Hi Jerome,
many thanks for fast reply. I checked the recommended beta and have general problem after installing and rebooting VSC. See the screenshots…
Update: removing extensions with rmdir %USERPROFILE%\.vscode\extensions /s did not helped .
Basically this looks good.
The two shown notifications are known (and already solved) issues that have no connection to the command not found issue.
Please read the beta thread. We have talked about the notifications over there.
Hi Jerome,
I do not think it is a problem of the VSC an its plugins. I have two PCs and one openhabian 2.4.0-1 on RP3.
Yesterday I I made an update of the opehabian with sudo openhabian-config. Than I installed VSC from scratch on new PC, when all problems occurred. Today morning I launched my old pc with previously working VSC and OpenHab 0.5.1 plugin and discovered the same problems.
It is not the problem of the plugin but something went wrong after updating openHabian.
Usually an openhabian update shouldn’t affect the extension in the way the problems are occuring here.
We are communicating with the openhab environment only through lsp server and rest api.
A “command” (especially when it is not found) is far beyond starting a connection from vscode to openhab.
The problem occurred with a newly installed Raspi 4. Since the error could not be fixed, I reinstalled the Raspi. After that the error did not occur anymore. I have also uninstalled VS code and deleted all files that generate VS code.
After that, the error did not occur again.
Guys,
I’ve updated Openhab to 2.5 hoping to solve the problem with VSC connection.I really like this plugin and do not want to give up without solution Unfortunately openhab updates and VCS updates did not solve my issues. I am just wondering if i could get some logs captured to investigate the issue.
@violine,
I do not want to re-install the system. It is linux so we can fix it more efficiently than win for example
Uninstalling VSC did not resolve my problem.
Jerome,
I will come back with results on this what you proposed. I did the steps you refer to. I uninstalled beta VS I removed extension manually as well. I did the same on two pcs. on both I have the same problem.
But honestly I will check this again and then come back…
