I have a problem getting my Pine A64 to run openHAB using the openHABian config tool.
Platform information:
- Hardware: ARM64 (Allwinner SOC)/2GB DDR3/32 GB SD-Card
- OS: Armbian Buster (2019-11-19)
- Java Runtime Environment: Zulu-8
- openHAB version: 2.5
Issue of the topic: Using the openHABian Config Tool it seems to not install Zulu-8 correctly or an incompatible Version. openHAB can’t be started after installation. Has anyone got luck with his Pine A64 running the current openHABian installer? Or is there a modified way I should go (installing another Java Version?)?
If logs where generated please post these here using code fences:
running
sudo systemctl status openhab2
gets me:
openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: signal) since Thu 2019-12-26 14:01:10 UTC; 2s ago
Docs: Introduction | openHAB
https://community.openhab.org
Process: 24404 ExecStart=/usr/share/openhab2/runtime/bin/karaf ${OPENHAB_STARTMODE} (code=killed, signal=ILL)
Main PID: 24404 (code=killed, signal=ILL)
running
java -version
gets me:
Illegal instruction
running
journalctl -u openhab2.service -b
gets me:
– Logs begin at Thu 2019-12-26 13:40:21 UTC, end at Thu 2019-12-26 14:07:10 UTC. –
Dec 26 13:53:47 pine64 systemd[1]: Started openHAB 2 - empowering the smart home.
Dec 26 13:53:47 pine64 karaf[10548]: Illegal instruction
Dec 26 13:53:47 pine64 karaf[10548]: /usr/share/openhab2/runtime/bin/karaf: 247: [: Illegal number:
Dec 26 13:53:47 pine64 karaf[10548]: /usr/share/openhab2/runtime/bin/karaf: 95: [: Illegal number:
Dec 26 13:53:47 pine64 karaf[10548]: /usr/share/openhab2/runtime/bin/karaf: 296: [: Illegal number:
Dec 26 13:53:47 pine64 systemd[1]: openhab2.service: Main process exited, code=killed, status=4/ILL
Dec 26 13:53:47 pine64 systemd[1]: openhab2.service: Failed with result ‘signal’.
Dec 26 13:53:52 pine64 systemd[1]: openhab2.service: Service RestartSec=5s expired, scheduling restart.
Dec 26 13:53:52 pine64 systemd[1]: openhab2.service: Scheduled restart job, restart counter is at 1.
Dec 26 13:53:52 pine64 systemd[1]: Stopped openHAB 2 - empowering the smart home.
Dec 26 13:53:52 pine64 systemd[1]: Started openHAB 2 - empowering the smart home.
Dec 26 13:53:53 pine64 karaf[10664]: Illegal instruction
Dec 26 13:53:53 pine64 karaf[10664]: /usr/share/openhab2/runtime/bin/karaf: 247: [: Illegal number:
Dec 26 13:53:53 pine64 karaf[10664]: /usr/share/openhab2/runtime/bin/karaf: 95: [: Illegal number:
Dec 26 13:53:53 pine64 karaf[10664]: /usr/share/openhab2/runtime/bin/karaf: 296: [: Illegal number:
Dec 26 13:53:53 pine64 systemd[1]: openhab2.service: Main process exited, code=killed, status=4/ILL
Dec 26 13:53:53 pine64 systemd[1]: openhab2.service: Failed with result ‘signal’.
Dec 26 13:53:58 pine64 systemd[1]: openhab2.service: Service RestartSec=5s expired, scheduling restart.
Dec 26 13:53:58 pine64 systemd[1]: openhab2.service: Scheduled restart job, restart counter is at 2.
Dec 26 13:53:58 pine64 systemd[1]: Stopped openHAB 2 - empowering the smart home.
Dec 26 13:53:58 pine64 systemd[1]: Started openHAB 2 - empowering the smart home.
Dec 26 13:53:58 pine64 karaf[10749]: Illegal instruction
Dec 26 13:53:58 pine64 karaf[10749]: /usr/share/openhab2/runtime/bin/karaf: 247: [: Illegal number:
Dec 26 13:53:58 pine64 karaf[10749]: /usr/share/openhab2/runtime/bin/karaf: 95: [: Illegal number:
Dec 26 13:53:58 pine64 karaf[10749]: /usr/share/openhab2/runtime/bin/karaf: 296: [: Illegal number:
Dec 26 13:53:58 pine64 systemd[1]: openhab2.service: Main process exited, code=killed, status=4/ILL
Dec 26 13:53:58 pine64 systemd[1]: openhab2.service: Failed with result ‘signal’.
Dec 26 13:54:03 pine64 systemd[1]: openhab2.service: Service RestartSec=5s expired, scheduling restart.
Dec 26 13:54:03 pine64 systemd[1]: openhab2.service: Scheduled restart job, restart counter is at 3.
Dec 26 13:54:03 pine64 systemd[1]: Stopped openHAB 2 - empowering the smart home.
Dec 26 13:54:03 pine64 systemd[1]: Started openHAB 2 - empowering the smart home.
Dec 26 13:54:03 pine64 karaf[10823]: Illegal instruction
Dec 26 13:54:03 pine64 karaf[10823]: /usr/share/openhab2/runtime/bin/karaf: 247: [: Illegal number:
Dec 26 13:54:03 pine64 karaf[10823]: /usr/share/openhab2/runtime/bin/karaf: 95: [: Illegal number:
Dec 26 13:54:03 pine64 karaf[10823]: /usr/share/openhab2/runtime/bin/karaf: 296: [: Illegal number:
Dec 26 13:54:03 pine64 systemd[1]: openhab2.service: Main process exited, code=killed, status=4/ILL
Dec 26 13:54:03 pine64 systemd[1]: openhab2.service: Failed with result ‘signal’.
Dec 26 13:54:08 pine64 systemd[1]: openhab2.service: Service RestartSec=5s expired, scheduling restart.
Dec 26 13:54:08 pine64 systemd[1]: openhab2.service: Scheduled restart job, restart counter is at 4.
Dec 26 13:54:08 pine64 systemd[1]: Stopped openHAB 2 - empowering the smart home.
Dec 26 13:54:08 pine64 systemd[1]: Started openHAB 2 - empowering the smart home.
Dec 26 13:54:09 pine64 karaf[10896]: Illegal instruction
Dec 26 13:54:09 pine64 karaf[10896]: /usr/share/openhab2/runtime/bin/karaf: 247: [: Illegal number:
Dec 26 13:54:09 pine64 karaf[10896]: /usr/share/openhab2/runtime/bin/karaf: 95: [: Illegal number:
Dec 26 13:54:09 pine64 karaf[10896]: /usr/share/openhab2/runtime/bin/karaf: 296: [: Illegal number:
Dec 26 13:54:09 pine64 systemd[1]: openhab2.service: Main process exited, code=killed, status=4/ILL
Dec 26 13:54:09 pine64 systemd[1]: openhab2.service: Failed with result ‘signal’.
Dec 26 13:54:14 pine64 systemd[1]: openhab2.service: Service RestartSec=5s expired, scheduling restart.
Dec 26 13:54:14 pine64 systemd[1]: openhab2.service: Scheduled restart job, restart counter is at 5.
Dec 26 13:54:14 pine64 systemd[1]: Stopped openHAB 2 - empowering the smart home.
Dec 26 13:54:14 pine64 systemd[1]: Started openHAB 2 - empowering the smart home.
Dec 26 13:54:14 pine64 karaf[10969]: Illegal instruction
Dec 26 13:54:14 pine64 karaf[10969]: /usr/share/openhab2/runtime/bin/karaf: 247: [: Illegal number:
