So is just tested it on Armbian Bionic with the instructions to clone the GithHub repo and it works perfectly out of the box now! Thanks for implementing the fixes I found, now its just a matter of minutes to set up a openHAB instance
It works now also out of the box on freshly updated system. I will try to improve things further - harden install, add addons, β¦
OS wise there is nothing to do (ZRAM exists in Armbian since early days and was anyway implemented in openHABian on my suggestions) β¦ Any other 3rd party system application, add-on that should be added?
I sent a PR to the documentation https://github.com/openhab/openhab-docs/pull/1119 but donβt understand what is the problem or haw the docs must be prepared that its alright.
thanks @igorp !
I just installed openhab as described in your manual on the newest armbian buster image on my pine64.
