- Platform information:
- Hardware: Bqeel Raspberry Pi 4 Model B 2GB
- OS: Linux? (OpenHabian)
- Java Runtime Environment: Not known … how do I find out?
- openHAB version: Tried three versions without success: v1.6-alpha (attached log relate to this version), but also tried v1.5 and 1.4.1 without success
- Issue of the topic: Instal cycles many times, showing lots of “Failed” and “skipped” errors each time. Never seems to finish instal. Cannot log in from a second machine either via a webpage GUI or Putty
New user rules won’t let me include the full log listing here
Note! Forum rules say that I can’t post links … hence have changed all offurences of ‘http’ to ‘h_t_t_p’ in the listing below
2020-05-27_08:24:53_BST [openHABian] Starting the openHABian initial setup.
2020-05-27_08:24:53_BST [openHABian] Storing configuration... OK
2020-05-27_08:24:53_BST [openHABian] Starting webserver with installation log... OK
2020-05-27_08:24:59_BST [openHABian] Changing default username and password... OK
2020-05-27_08:25:05_BST [openHABian] Setting up Ethernet connection... OK
2020-05-27_08:25:05_BST [openHABian] Ensuring network connectivity... OK
2020-09-04_17:11:21_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-04_17:11:40_BST [openHABian] Updating repositories and upgrading installed packages... Rebooting to reconfigure kernel ...
2020-09-04_17:12:03_BST [openHABian] Starting the openHABian initial setup.
2020-09-04_17:12:03_BST [openHABian] Storing configuration... OK
2020-09-04_17:12:03_BST [openHABian] Starting webserver with installation log... OK
2020-09-04_17:12:08_BST [openHABian] Changing default username and password... SKIPPED
2020-09-04_17:12:08_BST [openHABian] Setting up Ethernet connection... OK
2020-09-04_17:12:08_BST [openHABian] Ensuring network connectivity... OK
2020-09-04_17:12:51_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-04_17:13:10_BST [openHABian] Updating repositories and upgrading installed packages... 2020-09-04_17:13:13_BST [openHABian] Installing git package... FAILED
2020-09-04_17:14:15_BST [openHABian] Updating myself from h_t_t_ps://github.com/openhab/openhabian, stable branch... FAILED
2020-09-04_17:14:15_BST [openHABian] The git repository on the public internet is not reachable.
2020-09-04_17:14:15_BST [openHABian] We will continue trying to get your system installed, but this is not guaranteed to work.
2020-09-04_17:14:15_BST [openHABian] Starting execution of 'openhabian-config unattended'... OK
2020-09-04_17:14:15_BST [openHABian] Checking for root privileges... OK
2020-09-04_17:14:15_BST [openHABian] Updating Linux package information... OK
2020-09-04_17:14:34_BST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-09-04_17:14:35_BST [openHABian] Adjusting swap size to 3878 MB... OK (Reboot needed)
2020-09-04_17:14:35_BST [openHABian] Beginning setup of timezone based on IP geolocation... OK
2020-09-04_17:14:35_BST [openHABian] Installing Python for needed packages... FAILED
2020-09-04_17:20:24_BST [openHABian] Enabling time synchronization using NTP... OK
2020-09-04_17:20:24_BST [openHABian] Setting locale based on openhabian.conf... OK (Reboot needed)
2020-09-04_17:21:02_BST [openHABian] Setting hostname of the base system based on openhabian.conf... OK
2020-09-04_17:21:02_BST [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2020-09-04_17:21:03_BST [openHABian] Enabling Audio output... OK
2020-09-04_17:21:03_BST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... FAILED
2020-09-04_17:30:12_BST [openHABian] We tried to get your system installed, but without proper internet connectivity this may not have worked properly.
2020-09-04_17:30:12_BST [openHABian] Execution of 'openhabian-config unattended' completed.
2020-09-04_17:30:12_BST [openHABian] Waiting for openHAB to become ready on openhab... OK
2020-09-04_17:30:12_BST [openHABian] First time setup successfully finished. Rebooting your system!
2020-09-04_17:30:12_BST [openHABian] After rebooting the openHAB dashboard will be available at: h_t_t_p://openhab:8080
2020-09-04_17:30:12_BST [openHABian] After rebooting to gain access to a console, simply reconnect using ssh.
2020-09-04_17:30:44_BST [openHABian] Starting the openHABian initial setup.
2020-09-04_17:30:44_BST [openHABian] Storing configuration... OK
2020-09-04_17:30:44_BST [openHABian] Starting webserver with installation log... OK
2020-09-04_17:30:49_BST [openHABian] Changing default username and password... SKIPPED
2020-09-04_17:30:49_BST [openHABian] Setting up Ethernet connection... OK
2020-09-04_17:30:49_BST [openHABian] Ensuring network connectivity... OK
2020-09-04_17:31:31_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-04_17:31:54_BST [openHABian] Updating repositories and upgrading installed packages... Rebooting to reconfigure kernel ...
2020-09-04_17:32:20_BST [openHABian] Starting the openHABian initial setup.
2020-09-04_17:32:21_BST [openHABian] Storing configuration... OK
2020-09-04_17:32:21_BST [openHABian] Starting webserver with installation log... OK
2020-09-04_17:32:26_BST [openHABian] Changing default username and password... SKIPPED
2020-09-04_17:32:26_BST [openHABian] Setting up Ethernet connection... OK
2020-09-04_17:32:26_BST [openHABian] Ensuring network connectivity... OK
2020-09-04_17:33:08_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-04_17:33:31_BST [openHABian] Updating repositories and upgrading installed packages... 2020-09-04_17:33:37_BST [openHABian] Installing git package... FAILED
2020-09-04_17:34:40_BST [openHABian] Updating myself from h_t_t_ps://github.com/openhab/openhabian, stable branch... FAILED
2020-09-04_17:34:40_BST [openHABian] The git repository on the public internet is not reachable.
2020-09-04_17:34:40_BST [openHABian] We will continue trying to get your system installed, but this is not guaranteed to work.
2020-09-04_17:34:40_BST [openHABian] Starting execution of 'openhabian-config unattended'... OK
2020-09-04_17:34:40_BST [openHABian] Checking for root privileges... OK
2020-09-04_17:34:41_BST [openHABian] Updating Linux package information... OK
2020-09-04_17:35:04_BST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-09-04_17:35:04_BST [openHABian] Adjusting swap size to 3977 MB... OK (Reboot needed)
2020-09-04_17:35:04_BST [openHABian] Beginning setup of timezone based on IP geolocation... OK
2020-09-04_17:35:05_BST [openHABian] Installing Python for needed packages... FAILED
2020-09-04_17:40:54_BST [openHABian] Enabling time synchronization using NTP... OK
2020-09-04_17:40:55_BST [openHABian] Setting locale based on openhabian.conf... OK (Reboot needed)
2020-09-04_17:42:16_BST [openHABian] Setting hostname of the base system based on openhabian.conf... OK
2020-09-04_17:42:17_BST [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2020-09-04_17:42:17_BST [openHABian] Enabling Audio output... OK
2020-09-04_17:42:17_BST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... FAILED
2020-09-04_17:51:23_BST [openHABian] We tried to get your system installed, but without proper internet connectivity this may not have worked properly.
2020-09-04_17:51:23_BST [openHABian] Execution of 'openhabian-config unattended' completed.
2020-09-04_17:51:23_BST [openHABian] Waiting for openHAB to become ready on openhab... OK
2020-09-04_17:51:23_BST [openHABian] First time setup successfully finished. Rebooting your system!
2020-09-04_17:51:23_BST [openHABian] After rebooting the openHAB dashboard will be available at: h_t_t_p://openhab:8080
2020-09-04_17:51:23_BST [openHABian] After rebooting to gain access to a console, simply reconnect using ssh.
2020-09-04_17:51:58_BST [openHABian] Starting the openHABian initial setup.
2020-09-04_17:51:58_BST [openHABian] Storing configuration... OK
2020-09-04_17:51:58_BST [openHABian] Starting webserver with installation log... OK
2020-09-04_17:52:03_BST [openHABian] Changing default username and password... SKIPPED
2020-09-04_17:52:03_BST [openHABian] Setting up Ethernet connection... OK
2020-09-04_17:52:03_BST [openHABian] Ensuring network connectivity... OK
2020-09-04_17:52:46_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-04_17:53:09_BST [openHABian] Updating repositories and upgrading installed packages... Rebooting to reconfigure kernel ...
2020-09-04_17:53:35_BST [openHABian] Starting the openHABian initial setup.
2020-09-04_17:53:35_BST [openHABian] Storing configuration... OK
2020-09-04_17:53:35_BST [openHABian] Starting webserver with installation log... OK
2020-09-04_17:53:40_BST [openHABian] Changing default username and password... SKIPPED
2020-09-04_17:53:40_BST [openHABian] Setting up Ethernet connection... OK
2020-09-04_17:53:40_BST [openHABian] Ensuring network connectivity... OK
2020-09-04_17:54:23_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-04_17:54:46_BST [openHABian] Updating repositories and upgrading installed packages... 2020-09-04_17:54:52_BST [openHABian] Installing git package... FAILED
2020-09-04_17:55:55_BST [openHABian] Updating myself from h_t_t_ps://github.com/openhab/openhabian, stable branch... FAILED
2020-09-04_17:55:55_BST [openHABian] The git repository on the public internet is not reachable.
2020-09-04_17:55:55_BST [openHABian] We will continue trying to get your system installed, but this is not guaranteed to work.
2020-09-04_17:55:55_BST [openHABian] Starting execution of 'openhabian-config unattended'... OK
2020-09-04_17:55:55_BST [openHABian] Checking for root privileges... OK
2020-09-04_17:55:56_BST [openHABian] Updating Linux package information... OK
2020-09-04_17:56:19_BST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-09-04_17:56:19_BST [openHABian] Adjusting swap size to 3977 MB... OK (Reboot needed)
2020-09-04_17:56:19_BST [openHABian] Beginning setup of timezone based on IP geolocation... OK
2020-09-04_17:56:19_BST [openHABian] Installing Python for needed packages... FAILED
2020-09-04_18:02:09_BST [openHABian] Enabling time synchronization using NTP... OK
2020-09-04_18:02:10_BST [openHABian] Setting locale based on openhabian.conf... OK (Reboot needed)
2020-09-04_18:03:31_BST [openHABian] Setting hostname of the base system based on openhabian.conf... OK
2020-09-04_18:03:32_BST [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2020-09-04_18:03:32_BST [openHABian] Enabling Audio output... OK
2020-09-04_18:03:33_BST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... FAILED
2020-09-04_18:12:38_BST [openHABian] We tried to get your system installed, but without proper internet connectivity this may not have worked properly.
2020-09-04_18:12:38_BST [openHABian] Execution of 'openhabian-config unattended' completed.
2020-09-04_18:12:38_BST [openHABian] Waiting for openHAB to become ready on openhab... OK
2020-09-04_18:12:38_BST [openHABian] First time setup successfully finished. Rebooting your system!
2020-09-04_18:12:38_BST [openHABian] After rebooting the openHAB dashboard will be available at: h_t_t_p://openhab:8080
2020-09-04_18:12:38_BST [openHABian] After rebooting to gain access to a console, simply reconnect using ssh.
2020-09-04_18:13:11_BST [openHABian] Starting the openHABian initial setup.
2020-09-04_18:13:11_BST [openHABian] Storing configuration... OK
2020-09-04_18:13:11_BST [openHABian] Starting webserver with installation log... OK
2020-09-04_18:13:16_BST [openHABian] Changing default username and password... SKIPPED
2020-09-04_18:13:16_BST [openHABian] Setting up Ethernet connection... OK
2020-09-04_18:13:16_BST [openHABian] Ensuring network connectivity... OK
2020-09-04_18:13:58_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-04_18:14:21_BST [openHABian] Updating repositories and upgrading installed packages... Rebooting to reconfigure kernel ...
2020-09-04_18:14:48_BST [openHABian] Starting the openHABian initial setup.
2020-09-04_18:14:48_BST [openHABian] Storing configuration... OK
2020-09-04_18:14:48_BST [openHABian] Starting webserver with installation log... OK
2020-09-04_18:14:53_BST [openHABian] Changing default username and password... SKIPPED
2020-09-04_18:14:53_BST [openHABian] Setting up Ethernet connection... OK
2020-09-04_18:14:53_BST [openHABian] Ensuring network connectivity... OK
2020-09-04_18:15:35_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-04_18:15:58_BST [openHABian] Updating repositories and upgrading installed packages... 2020-09-04_18:16:04_BST [openHABian] Installing git package... FAILED
2020-09-04_18:17:08_BST [openHABian] Updating myself from h_t_t_ps://github.com/openhab/openhabian, stable branch... FAILED
2020-09-04_18:17:08_BST [openHABian] The git repository on the public internet is not reachable.
2020-09-04_18:17:08_BST [openHABian] We will continue trying to get your system installed, but this is not guaranteed to work.
2020-09-04_18:17:08_BST [openHABian] Starting execution of 'openhabian-config unattended'... OK
2020-09-04_18:17:08_BST [openHABian] Checking for root privileges... OK
2020-09-04_18:17:08_BST [openHABian] Updating Linux package information... OK
2020-09-04_18:17:31_BST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-09-04_18:17:31_BST [openHABian] Adjusting swap size to 3977 MB... OK (Reboot needed)
2020-09-04_18:17:32_BST [openHABian] Beginning setup of timezone based on IP geolocation... OK
2020-09-04_18:17:32_BST [openHABian] Installing Python for needed packages... FAILED
2020-09-04_18:23:23_BST [openHABian] Enabling time synchronization using NTP... OK
2020-09-04_18:23:24_BST [openHABian] Setting locale based on openhabian.conf... OK (Reboot needed)
2020-09-04_18:24:47_BST [openHABian] Setting hostname of the base system based on openhabian.conf... OK
2020-09-04_18:24:48_BST [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2020-09-04_18:24:48_BST [openHABian] Enabling Audio output... OK
2020-09-04_18:24:49_BST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... FAILED
2020-09-04_18:33:57_BST [openHABian] We tried to get your system installed, but without proper internet connectivity this may not have worked properly.
2020-09-04_18:33:57_BST [openHABian] Execution of 'openhabian-config unattended' completed.
2020-09-04_18:33:57_BST [openHABian] Waiting for openHAB to become ready on openhab... OK
2020-09-04_18:33:57_BST [openHABian] First time setup successfully finished. Rebooting your system!
2020-09-04_18:33:57_BST [openHABian] After rebooting the openHAB dashboard will be available at: h_t_t_p://openhab:8080
2020-09-04_18:33:57_BST [openHABian] After rebooting to gain access to a console, simply reconnect using ssh.
2020-09-04_18:34:29_BST [openHABian] Starting the openHABian initial setup.
2020-09-04_18:34:29_BST [openHABian] Storing configuration... OK
2020-09-04_18:34:29_BST [openHABian] Starting webserver with installation log... OK
2020-09-04_18:34:35_BST [openHABian] Changing default username and password... SKIPPED
2020-09-04_18:34:35_BST [openHABian] Setting up Ethernet connection... OK
2020-09-04_18:34:35_BST [openHABian] Ensuring network connectivity... OK
2020-09-04_18:35:17_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-04_18:35:40_BST [openHABian] Updating repositories and upgrading installed packages... Rebooting to reconfigure kernel ...
2020-09-04_18:36:06_BST [openHABian] Starting the openHABian initial setup.
2020-09-04_18:36:06_BST [openHABian] Storing configuration... OK
2020-09-04_18:36:06_BST [openHABian] Starting webserver with installation log... OK
2020-09-04_18:36:11_BST [openHABian] Changing default username and password... SKIPPED
2020-09-04_18:36:11_BST [openHABian] Setting up Ethernet connection... OK
2020-09-04_18:36:11_BST [openHABian] Ensuring network connectivity... OK
2020-09-04_18:36:53_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-04_18:37:16_BST [openHABian] Updating repositories and upgrading installed packages... Rebooting to reconfigure kernel ...
2020-09-04_18:37:43_BST [openHABian] Starting the openHABian initial setup.
2020-09-04_18:37:43_BST [openHABian] Storing configuration... OK
2020-09-04_18:37:44_BST [openHABian] Starting webserver with installation log... OK
2020-09-04_18:37:49_BST [openHABian] Changing default username and password... SKIPPED
2020-09-04_18:37:49_BST [openHABian] Setting up Ethernet connection... OK
2020-09-04_18:37:49_BST [openHABian] Ensuring network connectivity... OK
2020-09-04_18:38:31_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-04_18:38:54_BST [openHABian] Updating repositories and upgrading installed packages... 2020-09-04_18:39:00_BST [openHABian] Installing git package... FAILED
2020-09-04_18:40:03_BST [openHABian] Updating myself from h_t_t_ps://github.com/openhab/openhabian, stable branch... FAILED
2020-09-04_18:40:03_BST [openHABian] The git repository on the public internet is not reachable.
2020-09-04_18:40:03_BST [openHABian] We will continue trying to get your system installed, but this is not guaranteed to work.
2020-09-04_18:40:03_BST [openHABian] Starting execution of 'openhabian-config unattended'... OK
2020-09-04_18:40:03_BST [openHABian] Checking for root privileges... OK
2020-09-04_18:40:04_BST [openHABian] Updating Linux package information... OK
2020-09-04_18:40:27_BST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-09-04_18:40:27_BST [openHABian] Adjusting swap size to 3977 MB... OK (Reboot needed)
2020-09-04_18:40:27_BST [openHABian] Beginning setup of timezone based on IP geolocation... OK
2020-09-04_18:40:27_BST [openHABian] Installing Python for needed packages... FAILED
2020-09-04_18:46:18_BST [openHABian] Enabling time synchronization using NTP... OK
2020-09-04_18:46:18_BST [openHABian] Setting locale based on openhabian.conf... OK (Reboot needed)
2020-09-04_18:47:42_BST [openHABian] Setting hostname of the base system based on openhabian.conf... OK
2020-09-04_18:47:43_BST [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2020-09-04_18:47:43_BST [openHABian] Enabling Audio output... OK
2020-09-04_18:47:43_BST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... FAILED
2020-09-04_18:56:49_BST [openHABian] We tried to get your system installed, but without proper internet connectivity this may not have worked properly.
2020-09-04_18:56:49_BST [openHABian] Execution of 'openhabian-config unattended' completed.
2020-09-04_18:56:49_BST [openHABian] Waiting for openHAB to become ready on openhab... OK
2020-09-04_18:56:49_BST [openHABian] First time setup successfully finished. Rebooting your system!
2020-09-04_18:56:49_BST [openHABian] After rebooting the openHAB dashboard will be available at: h_t_t_p://openhab:8080
2020-09-04_18:56:49_BST [openHABian] After rebooting to gain access to a console, simply reconnect using ssh.
2020-09-04_18:57:22_BST [openHABian] Starting the openHABian initial setup.
2020-09-04_18:57:22_BST [openHABian] Storing configuration... OK
2020-09-04_18:57:22_BST [openHABian] Starting webserver with installation log... OK
2020-09-04_18:57:28_BST [openHABian] Changing default username and password... SKIPPED
2020-09-04_18:57:28_BST [openHABian] Setting up Ethernet connection... OK
2020-09-04_18:57:28_BST [openHABian] Ensuring network connectivity... OK
2020-09-04_18:58:10_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-04_18:58:33_BST [openHABian] Updating repositories and upgrading installed packages... Rebooting to reconfigure kernel ...
2020-09-04_18:58:59_BST [openHABian] Starting the openHABian initial setup.
2020-09-04_18:58:59_BST [openHABian] Storing configuration... OK
2020-09-04_18:58:59_BST [openHABian] Starting webserver with installation log... OK
2020-09-04_18:59:05_BST [openHABian] Changing default username and password... SKIPPED
2020-09-04_18:59:05_BST [openHABian] Setting up Ethernet connection... OK
2020-09-04_18:59:05_BST [openHABian] Ensuring network connectivity... OK
2020-09-04_18:59:47_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-04_19:00:10_BST [openHABian] Updating repositories and upgrading installed packages... 2020-09-04_19:00:16_BST [openHABian] Installing git package... FAILED
2020-09-04_19:01:19_BST [openHABian] Updating myself from h_t_t_ps://github.com/openhab/openhabian, stable branch... FAILED
2020-09-04_19:01:19_BST [openHABian] The git repository on the public internet is not reachable.
2020-09-04_19:01:19_BST [openHABian] We will continue trying to get your system installed, but this is not guaranteed to work.
2020-09-04_19:01:19_BST [openHABian] Starting execution of 'openhabian-config unattended'... OK
2020-09-04_19:01:19_BST [openHABian] Checking for root privileges... OK
2020-09-04_19:01:19_BST [openHABian] Updating Linux package information... OK
2020-09-04_19:01:42_BST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-09-04_19:01:42_BST [openHABian] Adjusting swap size to 3977 MB... OK (Reboot needed)
2020-09-04_19:01:43_BST [openHABian] Beginning setup of timezone based on IP geolocation... OK
2020-09-04_19:01:43_BST [openHABian] Installing Python for needed packages... FAILED
2020-09-04_19:07:33_BST [openHABian] Enabling time synchronization using NTP... OK
2020-09-04_19:07:33_BST [openHABian] Setting locale based on openhabian.conf... OK (Reboot needed)
2020-09-04_19:08:58_BST [openHABian] Setting hostname of the base system based on openhabian.conf... OK
2020-09-04_19:08:58_BST [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2020-09-04_19:08:58_BST [openHABian] Enabling Audio output... OK
2020-09-04_19:08:59_BST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)...
2020-09-04_19:08:02_BST [openHABian] Starting the openHABian initial setup.
2020-09-04_19:08:02_BST [openHABian] Storing configuration... OK
2020-09-04_19:08:02_BST [openHABian] Starting webserver with installation log... OK
2020-09-04_19:08:07_BST [openHABian] Changing default username and password... SKIPPED
2020-09-04_19:08:07_BST [openHABian] Setting up Ethernet connection... OK
2020-09-04_19:08:07_BST [openHABian] Ensuring network connectivity... OK
2020-09-05_17:32:36_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-05_17:32:59_BST [openHABian] Updating repositories and upgrading installed packages... Rebooting to reconfigure kernel ...
2020-09-05_17:33:25_BST [openHABian] Starting the openHABian initial setup.
2020-09-05_17:33:25_BST [openHABian] Storing configuration... OK
2020-09-05_17:33:25_BST [openHABian] Starting webserver with installation log... OK
2020-09-05_17:33:30_BST [openHABian] Changing default username and password... SKIPPED
2020-09-05_17:33:30_BST [openHABian] Setting up Ethernet connection... OK
2020-09-05_17:33:30_BST [openHABian] Ensuring network connectivity... OK
2020-09-05_17:34:11_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-05_17:34:34_BST [openHABian] Updating repositories and upgrading installed packages... 2020-09-05_17:34:39_BST [openHABian] Installing git package... FAILED
2020-09-05_17:35:42_BST [openHABian] Updating myself from h_t_t_ps://github.com/openhab/openhabian, stable branch... FAILED
2020-09-05_17:35:42_BST [openHABian] The git repository on the public internet is not reachable.
2020-09-05_17:35:42_BST [openHABian] We will continue trying to get your system installed, but this is not guaranteed to work.
2020-09-05_17:35:42_BST [openHABian] Starting execution of 'openhabian-config unattended'... OK
2020-09-05_17:35:42_BST [openHABian] Checking for root privileges... OK
2020-09-05_17:35:42_BST [openHABian] Updating Linux package information... OK
2020-09-05_17:36:05_BST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-09-05_17:36:06_BST [openHABian] Adjusting swap size to 3977 MB... OK (Reboot needed)
2020-09-05_17:36:06_BST [openHABian] Beginning setup of timezone based on IP geolocation... OK
2020-09-05_17:36:06_BST [openHABian] Installing Python for needed packages... FAILED
2020-09-05_17:41:56_BST [openHABian] Enabling time synchronization using NTP... OK
2020-09-05_17:41:56_BST [openHABian] Setting locale based on openhabian.conf... OK (Reboot needed)
2020-09-05_17:43:14_BST [openHABian] Setting hostname of the base system based on openhabian.conf... OK
2020-09-05_17:43:15_BST [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2020-09-05_17:43:15_BST [openHABian] Enabling Audio output... OK
2020-09-05_17:43:15_BST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)...
2020-09-05_17:50:58_BST [openHABian] Starting the openHABian initial setup.
2020-09-05_17:50:58_BST [openHABian] Storing configuration... OK
2020-09-05_17:50:58_BST [openHABian] Starting webserver with installation log... OK
2020-09-05_17:51:04_BST [openHABian] Changing default username and password... SKIPPED
2020-09-05_17:51:04_BST [openHABian] Setting up Ethernet connection... OK
2020-09-05_17:51:04_BST [openHABian] Ensuring network connectivity... OK
2020-09-05_17:53:34_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-05_17:53:57_BST [openHABian] Updating repositories and upgrading installed packages... Rebooting to reconfigure kernel ...
2020-09-05_17:54:24_BST [openHABian] Starting the openHABian initial setup.
2020-09-05_17:54:24_BST [openHABian] Storing configuration... OK
2020-09-05_17:54:24_BST [openHABian] Starting webserver with installation log... OK
2020-09-05_17:54:30_BST [openHABian] Changing default username and password... SKIPPED
2020-09-05_17:54:30_BST [openHABian] Setting up Ethernet connection... OK
2020-09-05_17:54:30_BST [openHABian] Ensuring network connectivity... OK
2020-09-05_17:55:12_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-09-05_17:55:35_BST [openHABian] Updating repositories and upgrading installed packages... 2020-09-05_17:55:41_BST [openHABian] Installing git package... FAILED
2020-09-05_17:56:44_BST [openHABian] Updating myself from h_t_t_ps://github.com/openhab/openhabian, stable branch... FAILED
2020-09-05_17:56:44_BST [openHABian] The git repository on the public internet is not reachable.
2020-09-05_17:56:44_BST [openHABian] We will continue trying to get your system installed, but this is not guaranteed to work.
2020-09-05_17:56:44_BST [openHABian] Starting execution of 'openhabian-config unattended'... OK
2020-09-05_17:56:44_BST [openHABian] Checking for root privileges... OK
2020-09-05_17:56:44_BST [openHABian] Updating Linux package information... OK
2020-09-05_17:57:07_BST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-09-05_17:57:08_BST [openHABian] Adjusting swap size to 3977 MB... OK (Reboot needed)
2020-09-05_17:57:08_BST [openHABian] Beginning setup of timezone based on IP geolocation... OK
2020-09-05_17:57:08_BST [openHABian] Installing Python for needed packages... FAILED
2020-09-05_18:02:58_BST [openHABian] Enabling time synchronization using NTP... OK
2020-09-05_18:02:58_BST [openHABian] Setting locale based on openhabian.conf... OK (Reboot needed)
2020-09-05_18:04:20_BST [openHABian] Setting hostname of the base system based on openhabian.conf... OK
2020-09-05_18:04:20_BST [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2020-09-05_18:04:20_BST [openHABian] Enabling Audio output... OK
2020-09-05_18:04:21_BST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... FAILED
2020-09-05_18:13:27_BST [openHABian] We tried to get your system installed, but without proper internet connectivity this may not have worked properly.
2020-09-05_18:13:27_BST [openHABian] Execution of 'openhabian-config unattended' completed.
2020-09-05_18:13:27_BST [openHABian] Waiting for openHAB to become ready on openhab... OK
2020-09-05_18:13:27_BST [openHABian] First time setup successfully finished. Rebooting your system!
2020-09-05_18:13:27_BST [openHABian] After rebooting the openHAB dashboard will be available at: h_t_t_p://openhab:8080
2020-09-05_18:13:27_BST [openHABian] After rebooting to gain access to a console, simply reconnect using ssh.
