I have to try this..
The static IP outside DHCP range is important? Because i always assigned within DHCP range.
Like I said, try putting static entry in ARP cache, in /etc/ethers on your OH Linux, then reboot. That worked for me at least, on for Android 7 device.
I know about the tun ing but that worked for me to goes OFF. Never I got device ON by
I have read them all but maybe i am doing so.ething wrong but OH does not see my Android IP, how is possible the binding detects my phone if OH does not see the IP???
I know and i appreciate your time ;). I just want to get running the binding… :S
If you assigned it in DHCP config (in your router) then its fine, no need to do anything on Android. But if DHCP config is not in your control, you can assign static IP in Android, one that is outside DHCP range.
We could probably get something close enough to be useful using download statistics. OH is download x times and Network binding is downloaded y times. Add some fudge factors and there could be a reasonable guesstimate. Close enough to make decisions on anyway. We don’t need to measure with a micronometer only to cut with an ax.
I’m not sure even those stats are captured though.
Did you mean micrometer?
Yes I did. ![]()
I would like following stats (sorry Juan its going off topic)
Perhaps the work being done here (New Add-on bundle for Prometheus health Metrics) could be a start, or at least inspiration.
Guys, we are going a bit off topic here…
Forgot to mention one caveat
The arp db /etc/ethers is not loaded by rasbian init scripts. You need to either manually do sudo arp -f /etc/ethers or put a line arp -f /etc/ethers in /etc/rc.local script (before exit 0 command in that file)
I have a fixed version of 2.3.0 network binding jar and source code here
Uninstall old one from PaperUI and drop org.openhab.binding.network-2.3.0.jar in your addons folder.
Fixes
To see whats going on, enable logs for logger “org.openhab.binding.network”.
In Karaf console:
log:set debug "org.openhab.binding.network"
Need to sleep now. ![]()
Did you submit your changes to the main repo?
Right now in my google drive, link above. Its 2.3.0 version fixed. will check against 2.4.0-SNAPSHOT code tomo and then submit PR.
I think I can further improve the reliability of arping invocation. I noticed that concurrent invocations are causing some issue in native code “arping: libnet_write(): libnet_write_link(): only -1 bytes written (Invalid argument)”. Maybe I can introduce some randomness in arping invocations across things. Meanwhile users can try different unique refesh intervals for different things. But despite the native error, the fixed binding works because it relies on STDOUT instead of exit status of arping, but that can still give unreliable results if you got lot of androids/ios devices to watch.
Do I provide the mac option in addition to the IP, or in place of the IP?
For example:
network:servicedevice:cerberos [ hostname="cerberos", mac="00:11:22:33:44:55:66", port=22, retry=5, timeout=5000, refreshInterval=10000 ]
or
network:servicedevice:cerberos [ mac="00:11:22:33:44:55:66", port=22, retry=5, timeout=5000, refreshInterval=10000 ]
Thanks for the updates! They are greatly appreciated.
I know it’s a Rules DSL design pattern, but perhaps you can create a Design Pattern: Gate Keeper to keep calls to arping from occurring too close together in time.
Mac will be an addition to IP. If you don’t provide it, binding will invoke arping without -t mac hint. For reliable results I would suggest providing mac too.
When you update the docs for the binding make sure to make that clear. Thanks for the update!
I think we should have a library of such scripts / reusable Xtend/Kotlin code. Like Perl CPAN.
There really isn’t a good way to do it with Rules DSL. Certain architectural decisions were made very early on (no classes, global variables scoped to only a single .rules file) that makes creating a library of Rules very challenging. With the addition of Member of and triggeringItem it becomes a little more possible but still awkward at best.
This is one of the major driving forces towards the creation of the Experimental Rules Engine. Kai’s stated vision is that we will be able to deploy Rules libraries over the IoT Marketplace so rather than my just posting a bunch of Design Pattern postings that people must copy and paste from, people can download a library with the working code and just use it. So that is in work.
