Items file
Number GF_Hallway_Heating “Home temperature [%.1f °C]” (GF_Hallway, gHeating) {mqtt=“<[mosquitto:house/temperature1:state:default]”}
Number GF_House_humidity “Home humidity [%.0f %%]” (GF_Hallway, gHumidity) {mqtt=“<[mosquitto:House/humidity1:state:default]”}
copied from mqttlens msg so looks like the reading is ok
16.6000003815
51
Time
3:44:11
Topic
house/humidity1
QoS
0
Message:
56.5
is there a simple mistake i have made that you can see ?
Your item looks a little strange though, there are no square brackets for the mqtt option if I recall correctly. Could you look up some other examples to verify?
And make sure you have mqtt1 installed and not mqtt1 actions or mqtt2.
openHAB will not log an error for something that is not configured or not installed. Make also sure you have defined a broker in a “mqtt.cfg”. If that is all too tedious for you (it is!) then use the new MQTT 2 binding instead. There is a blog post and extensive documentation on how to add necessary Things and Channels on paper UI or via text files.
brilliant thank you working now knew it would be something simple like me lol
next up is rules to turn heating on and off with a set point some more reading to do and its a steep learning curve but a lot of help from all users hear makes it fun
