Java Runtime Environment: Zulu (openjdk version “1.8.0_152”)
I guess this is a rather silly question and similar problems have been discussed here before. I’ve done a lot of reading but for some reason I don’t get it to work.
I have a rule that is supposed to combine the time of the last update with the state of a device into a string. So the desired output in the sitemap is something like
Water Meter: 19:17:23 - OK
So I have a string item
String sWaterMeterStatus "Water Meter: [%s]"
and a rule
rule "rule_waterMeter_status"
Item nWaterMeterReading received update
var String sWaterMeterStatus = sWaterMeterStatus.state
//var String sWaterMeterLastUpdate = new DateTimeType().toString("HH:mm:ss")
var String sWaterMeterLastUpdate = new DateTimeType().toString()
logInfo("rule_waterMeter_status", "sWaterMeterStatus = " + sWaterMeterStatus )
logInfo("rule_waterMeter_status", "sWaterMeterLastUpdate = " + sWaterMeterLastUpdate)
sWaterMeterStatus.postUpdate(sWaterMeterLastUpdate + sWaterMeterStatus )
I’ve tried a lot of different suggestions from the community but I always get errors when converting the dateTime to a string.
Just an example:
Rule ‘rule_waterMeter_status’: An error occurred during the script execution: Cannot resolve proxy: java:/Objects/org.joda.time.format.DateTimeFormatter#org.joda.time.format.DateTimeFormatter
Thanks, but I’ve read that information before only to be left with more confusion.
Originally I wanted to use the item.lastUpdate mechanism. But I didn’t get it to work. So instead I just use the current time when an item is updates.
After a lot of more trial and error I now came up with this which seems to work:
rule “rule_waterMeter_status”
Item sWaterMeterStatus received update
var String wmStatus = sWaterMeterStatus.state.toString
var String wmLastUpdate = new DateTimeType().format("%1$tH:%1$tM:%1$tS")
sWaterMeterLastUpdateStatus.postUpdate(wmLastUpdate + " - " + wmStatus)
Trying to get item.lastUpdate to work I found this exact hint that you’ve posted to someone else’s question.
The item is included in RRD4J persistence, but it still didn’t work. I assume the reason again was that the conversion to a string variable failed.
Because I have a working solution now there’s no need to go further into this except for ‘nice to know’ reasons.
