[SOLVED] SEVERE - OpenHAB 2.5M3 doesn't start after cache clearing
  • Platform information:
    • Hardware: Intelx86 4GBRAM 128GBSSD
    • OS: Ubuntu18.04LTS
    • Java Runtime Environment: Zulu uptodate
    • openHAB version: 2.5M3
  • Issue of the topic: After clearing the cache and a restart I have a [SEVERE] error and the log in going into a loop at startup
2019-10-03 10:00:17.011 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
java.lang.RuntimeException: Error initializing storage.
	at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:70)
	at org.eclipse.osgi.launch.Equinox.<init>(Equinox.java:31)
	at org.eclipse.osgi.launch.EquinoxFactory.newFramework(EquinoxFactory.java:24)
	at org.apache.karaf.main.Main.launch(Main.java:256)
	at org.apache.karaf.main.Main.main(Main.java:178)
Caused by: java.io.FileNotFoundException: /var/lib/openhab2/cache/org.eclipse.osgi/.manager/.fileTableLock (Permission denied)
	at java.io.RandomAccessFile.open0(Native Method)
	at java.io.RandomAccessFile.open(RandomAccessFile.java:316)
	at java.io.RandomAccessFile.<init>(RandomAccessFile.java:243)
	at org.eclipse.osgi.internal.location.Locker_JavaNio.lock(Locker_JavaNio.java:36)
	at org.eclipse.osgi.storagemanager.StorageManager.lock(StorageManager.java:388)
	at org.eclipse.osgi.storagemanager.StorageManager.open(StorageManager.java:701)
	at org.eclipse.osgi.storage.Storage.getChildStorageManager(Storage.java:1776)
	at org.eclipse.osgi.storage.Storage.getInfoInputStream(Storage.java:1793)
	at org.eclipse.osgi.storage.Storage.<init>(Storage.java:132)
	at org.eclipse.osgi.storage.Storage.createStorage(Storage.java:85)
	at org.eclipse.osgi.internal.framework.EquinoxContainer.<init>(EquinoxContainer.java:68)
	... 4 more
2019-10-03 10:00:23.910 [SEVERE] [org.apache.karaf.main.Main] - Could not launch framework
	... 4 more
approx every 7 seconds
Now I get java.io.FileNotFoundException: /var/lib/openhab2/cache/org.eclipse.osgi/.manager/.fileTableLock (Permission denied) that I have a permission error
Why now? Never happened before.
The rest of the system works, node-red, pi-hole…
I can ssh in the system
Frontail is running
And the samba shares are running
And I must admit I am not very good at the linux file permissions stuff…
sudo openhab-cli start in the terminal starts the system
There seems to be a problem with the service launcher permissions…
If you search for
there seem to be identical issues after clearing the cache, for example:
You also need to be sure you are running Java 8 and not a newer version. Saying uptodate is not a valid version number for Java.
Thanks that works
I saw that before and I didn’t think of it.
Cheers
