I can confirm the Show Advanced Settings issue with HABmin. I don’t use PaperUI for configuration of my Z-Wave devices, so have not encountered the edit mode with Z-Wave items issue you reported.
I also can confirm both errors with snapshot 1728. I have exactly the same issues. The only difference: Advanced settings of z-wave controller are shown. For all other z-wave devices, they are not displayed.
No - I’d not seen this. I’m not sure why the advanced settings would be gone. I don’t think that anything has changed in HABmin (I’ve certainly not changed anything).
Is PaperUI the same (I guess so)?
I could guess that this is may be due to a change in the core, or maybe a change in the binding, although I don’t think there have been any.
Can someone provide any logs if there are exceptions? I’ve very little time at the moment unfortunately.
Doesn’t look like it should cause an issue, but I just looked at the binding, and there have been no changes there at all since I fixed a database problem, and after that change everyone said it was working.
I’m not really sure then. I had multiple reports that the last database update fixed a previous issue and there have been no changes since.
Unfortunately I’ve got no time at the moment as I have other (non-openHAB) work to do. If someone can work out what’s going on, then I can try and look at it, but I really can’t spend a lot of time looking at this right now.
PaperUI error: 'Internal Server Error’ (500:SERVER_ERROR)
2019-10-19 14:18:04.067 [DEBUG] [ersey.server.ServerRuntime$Responder] - Starting mapping of the exception.
org.glassfish.jersey.server.internal.process.MappableException: java.lang.NullPointerException
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.mapTargetToRuntimeEx(AbstractJavaResourceMethodDispatcher.java:179) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.access$200(AbstractJavaResourceMethodDispatcher.java:72) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:149) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [127:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [128:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [125:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [23:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:873) [93:org.eclipse.jetty.servlet:9.4.18.v20190429]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:542) [93:org.eclipse.jetty.servlet:9.4.18.v20190429]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [197:org.ops4j.pax.web.pax-web-jetty:7.2.10]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [90:org.eclipse.jetty.security:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1700) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1345) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [197:org.ops4j.pax.web.pax-web-jetty:7.2.10]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:480) [93:org.eclipse.jetty.servlet:9.4.18.v20190429]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1667) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1247) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [197:org.ops4j.pax.web.pax-web-jetty:7.2.10]
at org.eclipse.jetty.server.Server.handle(Server.java:505) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:370) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:267) [92:org.eclipse.jetty.server:9.4.18.v20190429]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:305) [83:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [83:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [83:org.eclipse.jetty.io:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [95:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [95:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [95:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [95:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [95:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:698) [95:org.eclipse.jetty.util:9.4.18.v20190429]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:804) [95:org.eclipse.jetty.util:9.4.18.v20190429]
Caused by: java.lang.NullPointerException
at org.eclipse.smarthome.io.rest.core.config.EnrichedConfigDescriptionParameterDTO.<init>(EnrichedConfigDescriptionParameterDTO.java:52) ~[?:?]
at org.eclipse.smarthome.io.rest.core.config.EnrichedConfigDescriptionDTOMapper.mapEnrichedParameters(EnrichedConfigDescriptionDTOMapper.java:59) ~[?:?]
at org.eclipse.smarthome.io.rest.core.config.EnrichedConfigDescriptionDTOMapper.map(EnrichedConfigDescriptionDTOMapper.java:45) ~[?:?]
at org.eclipse.smarthome.io.rest.core.internal.config.ConfigDescriptionResource.getByURI(ConfigDescriptionResource.java:110) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[?:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[?:?]
... 54 more
2019-10-19 14:18:04.081 [DEBUG] [ersey.server.ServerRuntime$Responder] - Exception 'null' has been mapped by 'org.eclipse.smarthome.io.rest.JSONResponse$ExceptionMapper' to response 'Internal Server Error' (500:SERVER_ERROR).
