[Solved] Snapshot #930 not starting properly
I just upgraded to snapshot #930.
When I open the browser, it’s telling me “Please stand by while UIs are being installed. This can take several minutes.”.
However I tried now several times and let it run an hour but no change.
Service says it is running:
sudo systemctl status openhab2.service -l
● openhab2.service - openHAB 2 - empowering the smart home
   Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
   Active: active (running) since Mi 2017-05-31 19:59:44 CEST; 11min ago
     Docs: http://docs.openhab.org
           https://community.openhab.org
  Process: 2140 ExecStop=/usr/share/openhab2/runtime/bin/stop (code=exited, status=0/SUCCESS)
 Main PID: 2321 (karaf)
   CGroup: /system.slice/openhab2.service
           ├─2321 /bin/bash /usr/share/openhab2/runtime/bin/karaf server
           └─2474 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var/log/openhab2 -Dfelix.cm.dir=/var/lib/openhab2/config -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8443 -Djava.awt.headless=true -Djava.endorsed.dirs=/usr/lib/jvm/java-8-oracle/jre/jre/lib/endorsed:/usr/lib/jvm/java-8-oracle/jre/lib/endorsed:/usr/share/openhab2/runtime/lib/endorsed -Djava.ext.dirs=/usr/lib/jvm/java-8-oracle/jre/jre/lib/ext:/usr/lib/jvm/java-8-oracle/jre/lib/ext:/usr/share/openhab2/runtime/lib/ext -Dkaraf.instances=/usr/share/openhab2/runtime/instances -Dkaraf.home=/usr/share/openhab2/runtime -Dkaraf.base=/var/lib/openhab2 -Dkaraf.data=/var/lib/openhab2 -Dkaraf.etc=/var/lib/openhab2/etc -Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir=/var/lib/openhab2/tmp -Djava.util.logging.config.file=/var/lib/openhab2/etc/java.util.logging.properties -Dkaraf.startLocalConsole=false -Dkaraf.startRemoteShell=true -classpath /usr/share/openhab2/runtime/lib/boot/org.apache.karaf.diagnostic.boot-4.0.8.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.jaas.boot-4.0.8.jar:/usr/share/openhab2/runtime/lib/boot/org.apache.karaf.main-4.0.8.jar:/usr/share/openhab2/runtime/lib/boot/org.osgi.core-6.0.0.jar org.apache.karaf.main.Main
Mai 31 19:59:44 openhabpi2 systemd[1]: Started openHAB 2 - empowering the smart home.
Mai 31 19:59:44 openhabpi2 start.sh[2321]: Launching the openHAB runtime...
But in the log there is hundreds if not thousands of this:
2017-05-31 20:09:57.118 [ERROR] [xbase.resource.BatchLinkableResource] - resolution of uriFragment '|::0.2.1.2.0.1.2.2.2.0.6.6.6::0::/1' failed.
java.lang.IllegalStateException: ScriptServiceUtil not initialized yet!
        at org.eclipse.smarthome.model.script.ScriptServiceUtil.getInstance(ScriptServiceUtil.java:88)
        at org.eclipse.smarthome.model.script.ScriptServiceUtil.getActionServices(ScriptServiceUtil.java:114)
        at org.eclipse.smarthome.model.script.internal.engine.ServiceTrackerActionServiceProvider.get(ServiceTrackerActionServiceProvider.java:21)
        at org.eclipse.smarthome.model.script.internal.engine.ServiceTrackerActionServiceProvider.get(ServiceTrackerActionServiceProvider.java:1)
        at org.eclipse.smarthome.model.script.scoping.ScriptImplicitlyImportedTypes.getActionClasses(ScriptImplicitlyImportedTypes.java:100)
        at org.eclipse.smarthome.model.script.scoping.ScriptImplicitlyImportedTypes.getStaticImportClasses(ScriptImplicitlyImportedTypes.java:94)
        at org.eclipse.xtext.xbase.scoping.batch.ImplicitlyImportedFeatures.getStaticImportClasses(ImplicitlyImportedFeatures.java:66)
        at org.eclipse.xtext.xbase.scoping.batch.XbaseBatchScopeProvider.newSession(XbaseBatchScopeProvider.java:112)
        at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.resolve(DefaultReentrantTypeResolver.java:162)
        at org.eclipse.xtext.xbase.typesystem.internal.DefaultReentrantTypeResolver.reentrantResolve(DefaultReentrantTypeResolver.java:139)
        at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$LazyResolvedTypes.resolveTypes(CachingBatchTypeResolver.java:80)
        at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:57)
        at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$2.process(CachingBatchTypeResolver.java:1)
        at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:37)
        at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:129)
        at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver.doResolveTypes(CachingBatchTypeResolver.java:53)
        at org.eclipse.xtext.xbase.typesystem.internal.AbstractBatchTypeResolver.resolveTypes(AbstractBatchTypeResolver.java:69)
        at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:60)
        at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:41)
        at org.eclipse.xtext.xbase.resource.BatchLinkableResource.getEObject(BatchLinkableResource.java:117)
        at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:223)
        at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:203)
        at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:259)
        at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(BasicEObjectImpl.java:1477)
        at org.eclipse.xtext.xbase.impl.XAbstractFeatureCallImplCustom.getFeature(XAbstractFeatureCallImplCustom.java:48)
        at org.eclipse.xtext.xbase.validation.XbaseValidator.checkDelegateConstructorIsFirst(XbaseValidator.java:927)
        at sun.reflect.GeneratedMethodAccessor13.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_131]
        at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_131]
        at org.eclipse.xtext.validation.AbstractDeclarativeValidator$MethodWrapper.invoke(AbstractDeclarativeValidator.java:118)[142:org.eclipse.xtext:2.9.2]
        at org.eclipse.xtext.validation.AbstractDeclarativeValidator.internalValidate(AbstractDeclarativeValidator.java:312)[142:org.eclipse.xtext:2.9.2]
        at org.eclipse.xtext.validation.AbstractInjectableValidator.validate(AbstractInjectableValidator.java:71)[142:org.eclipse.xtext:2.9.2]
        at org.eclipse.xtext.validation.CompositeEValidator.validate(CompositeEValidator.java:151)[142:org.eclipse.xtext:2.9.2]
        at org.eclipse.emf.ecore.util.Diagnostician.doValidate(Diagnostician.java:171)[65:org.eclipse.emf.ecore:2.11.1.v20150805-0538]
        at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:158)[65:org.eclipse.emf.ecore:2.11.1.v20150805-0538]
        at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:137)[65:org.eclipse.emf.ecore:2.11.1.v20150805-0538]
        at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents(Diagnostician.java:181)[65:org.eclipse.emf.ecore:2.11.1.v20150805-0538]
        at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:161)[65:org.eclipse.emf.ecore:2.11.1.v20150805-0538]
        at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents(Diagnostician.java:185)[65:org.eclipse.emf.ecore:2.11.1.v20150805-0538]
        at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:108)[65:org.eclipse.emf.ecore:2.11.1.v20150805-0538]
        at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.validateModel(ModelRepositoryImpl.java:265)[123:org.eclipse.smarthome.model.core:0.9.0.201705301617]
        at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:90)[123:org.eclipse.smarthome.model.core:0.9.0.201705301617]
        at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:244)[123:org.eclipse.smarthome.model.core:0.9.0.201705301617]
        at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.notifyUpdateToModelRepo(FolderObserver.java:170)[123:org.eclipse.smarthome.model.core:0.9.0.201705301617]
        at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.updated(FolderObserver.java:148)[123:org.eclipse.smarthome.model.core:0.9.0.201705301617]
        at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[3:org.apache.felix.configadmin:1.8.12]
        at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[3:org.apache.felix.configadmin:1.8.12]
        at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[3:org.apache.felix.configadmin:1.8.12]
        at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1461)[3:org.apache.felix.configadmin:1.8.12]
        at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1417)[3:org.apache.felix.configadmin:1.8.12]
        at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141)[3:org.apache.felix.configadmin:1.8.12]
        at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109)[3:org.apache.felix.configadmin:1.8.12]
        at java.lang.Thread.run(Thread.java:748)[:1.8.0_131]
After a long time, the error messages stopped, however openhab did not start properly. Not reachable via karaf.
I reverted to #925 which seems to be stable for now.
Same trouble here with #932
In #925 the habpanel only shows ‘Disconnected from server… Trying to reconnect’
I noticed something similar so I did some digging around in the karaf console and noticed most bundles hadn’t started - still in the Resolved status (rather than Started) - maybe something has changed that is stopping them from starting.
So I set about starting them manually using:
bundle:list
to find the bundle ids
bundle:start <id>
to start the bundles.
I can indeed confirm this bug. I created https://github.com/eclipse/smarthome/issues/3562 to track it and will fix immediately.
Hm how can I revert to 925 on an apt-get install ?
To go back to #925:
sudo apt-get install openhab2=2.1.0~20170523215039
I will disable the deletion of old builds until the problem is fixed.
Thank you!
If anybody else has an issue with it, I had to add a “-1” after the version number to get it working, like this:
sudo apt-get install openhab2=2.1.0~20170523215039-1
Good news: no need to downgrade anymore!
The brand-new distro #934 contains the fix.
Excellent, thanks @sjka!
Whoops, forgot about the release number.
For future reference, you can find which versions are available to switch to using the instructions in the docs. The time-stamp is usually the same as the date and hour found on the build history.
Confirm it’s fixed! How do I put this thread to solved?
By setting one of its posts to “solution” - this is done by clicking the “…”, after which you will see the “tick” button.
i just installed #934 via Openhabian, but he keeps saying “Please stand by while UIs are being installed” for more than 3 hours now. What can i do?
Does a restart do any difference or is that fully reproducible?
I have updated to the latest available build on a pine64.
openhab2 is already the newest version (2.1.0~20170603004943-1).
I still have the same exception as reported and no ui active, all respond with 404.
2017-06-03 17:09:37.451 [ERROR] [xbase.resource.BatchLinkableResource] - resolution of uriFragment '|::0.2.0.2.0.1.0::0::/1' failed.
        at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:199)
        at org.eclipse.xtext.xbase.validation.XbaseValidator.checkReferInvalidTypes(XbaseValidator.java:1904)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_111]
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)[:1.8.0_111]
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)[:1.8.0_111]
        at java.lang.reflect.Method.invoke(Method.java:498)[:1.8.0_111]
        at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.processIgnoredFiles(FolderObserver.java:97)
        at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.addModelParser(FolderObserver.java:82)
        at org.apache.felix.scr.impl.inject.BaseMethod.invokeMethod(BaseMethod.java:224)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.inject.BaseMethod.access$500(BaseMethod.java:39)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.inject.BaseMethod$Resolved.invoke(BaseMethod.java:617)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.inject.BaseMethod.invoke(BaseMethod.java:501)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.inject.BindMethod.invoke(BindMethod.java:655)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1722)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1699)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:371)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:320)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:291)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1215)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1136)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:945)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:881)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1167)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:127)[34:org.apache.felix.scr:2.0.6]
        at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:914)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:464)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:886)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:873)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:132)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:940)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:740)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1012)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:968)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:674)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:429)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:403)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.Activator.access$200(Activator.java:54)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:278)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.utils.extender.AbstractExtender.createExtension(AbstractExtender.java:259)[34:org.apache.felix.scr:2.0.6]
        at org.apache.felix.utils.extender.AbstractExtender.modifiedBundle(AbstractExtender.java:232)[34:org.apache.felix.scr:2.0.6]
        at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482)[org.osgi.core-6.0.0.jar:]
        at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415)[org.osgi.core-6.0.0.jar:]
        at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232)[org.osgi.core-6.0.0.jar:]
        at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444)[org.osgi.core-6.0.0.jar:]
        at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:902)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:165)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:75)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:67)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:102)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.container.Module.publishEvent(Module.java:466)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.container.Module.start(Module.java:457)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
        at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
When i restart openhab2 i see the exception at least once, other times more often.
Update:
I tried to fallback to 2.0 stable, that resulted in a mixed installation of core 2.0 and bindings 2.1.
I finally did a complete uninstall (purge) and reinstall.
Now i’m back to build #938.
no difference. Again need i do a reinstall?
Yeah, my issues still persist and match the others.
something isn’t working right.
If done 5 installs right now and never made it to a fully configuration with Openhab 2.1 #934.
Sometimes the UI configuration keeps hanging endlessly, sometimes the dashboard doesn’t even start from IP:8080 or hostname:8080.
with openhab 2.0 I have no problems.
Hi all,
I had the same problem yesterday, even after reinstalling older builds. The only thing that helped was an uninstall and consequent new install of openhab2. I am now on build #937 without further problems.
Chris
