SOLVED: Sonoff 10A, MQTT and openHAB
Hi Guys,
i am a beginner in SmartHome.
i successfully flashed my Sonoff 10A with ESPEasy and want to control the device via openHAB.
this is my mqtt.cfg ( mqtt-binding is installed in openhab )
# Define your MQTT broker connections here for use in the MQTT Binding or MQTT
# Persistence bundles. Replace <broker> with an ID you choose.
# URL to the MQTT broker, e.g. tcp://localhost:1883 or ssl://localhost:8883
broker.url=tcp://192.168.1.100:1883
# Optional. Client id (max 23 chars) to use when connecting to the broker.
# If not provided a random default is generated.
#<broker>.clientId=<clientId>
# Optional. True or false. If set to true, allows the use of clientId values
# up to 65535 characters long. Defaults to false.
# NOTE: clientId values longer than 23 characters may not be supported by all
# MQTT servers. Check the server documentation.
#<broker>.allowLongerClientIds=false
# Optional. User id to authenticate with the broker.
#<broker>.user=<user>
# Optional. Password to authenticate with the broker.
#<broker>.pwd=<password>
# Optional. Set the quality of service level for sending messages to this broker.
# Possible values are 0 (Deliver at most once),1 (Deliver at least once) or 2
# (Deliver exactly once). Defaults to 0.
#<broker>.qos=<qos>
# Optional. True or false. Defines if the broker should retain the messages sent to
# it. Defaults to false.
#<broker>.retain=<retain>
# Optional. True or false. Defines if messages are published asynchronously or
# synchronously. Defaults to true.
#<broker>.async=<async>
# Optional. Defines the last will and testament that is sent when this client goes offline
# Format: topic:message:qos:retained <br/>
#<broker>.lwt=<last will definition>
With MQTT.fx i can subscribe to the “SystemInfo/Uptime” on the ESPeasy - so the broker/settings should work.
( /Sonoff_1/uptime/Minutes )
how do i manage this thing to work in openhab ? i want to turn it on/off
I tried this:
Switch Sonoff1 "Sonoff-Test" {mqtt=">[mosquitto:/Sonoff_1/gpio/12:command:ON:1],>[mosquitto:/Sonoff_1/gpio/12:command:OFF:0],<[mosquitto:/Sonoff_1/lightState/Switch:command:OFF:0],<[mosquitto:/Sonoff_1/lightState/Switch:command:ON:1]"}
Switch Sonoff2 "Sonoff-Test2" {mqtt=">[mymosquitto:/Sonoff_1/gpio/12:command:ON:1],>[mymosquitto:/Sonoff_1/gpio/12:command:OFF:0],<[mosquitto:/Sonoff_1/lightState/Switch:command:OFF:0],<[mosquitto:/Sonoff_1/lightState/Switch:command:ON:1]"}
Switch Sonoff3 {mqtt=">[mymosquitto:/Sonoff_1/gpio/12:command:ON:1],>[mymosquitto:/Sonoff_1/gpio/12:command:OFF:0]"}
none of those are workin - what am i missing here ?
Thank you!
The Controller on ESP Easy is set to OpenHAB MQTT
19
40
02
In case of the Sonoff it’s a good idea to go with the Tasmota firmware. There is a whole thread on the Sonoff+Tasmota here in the forum.
You’ll also find a detailed description of how to connect modules to openHAB, with item examples and everything. I’d advice to safe you the trouble and switch right now.
Regarding your problem: first there shouldn’t be a starting slash in an mqtt topic. Seems however to be consistent between your configs. Next issue I’m seeing is that your broker is called “broker” but you are trying to talk to “mosquitto”. One other problem I’m seeing is, that you didn’t provide the login credentials in your mqtt.conf. Is the binding even connected?
Did you read the binding Readme carefully?
Thanks for your Answer Thom! - its a lot to learn for me atm with openhab, i tried the whole day to get this thing to work :confused:
i dont know if the binding is connected - where can i check this ?
i also dont believe that i have read the same “readme” that you are speaking about - could you pls share a link to it ?
this one ? http://docs.openhab.org/addons/bindings/mqtt1/readme.html
i tried to understand this, but its sometimes hard to follow, when you have never done this before :confused:
so how do i connect/check the mqtt-binding ?
thank you
ESP Easy is connected to the broker
14
Okay getting started is sometimes hard but the steps are actually straight forward. Let’s see…
  1. Install and set up a broker. You’ve used the one provided through openHABian, perfect
  2. Connect with a desktop client to the broker to see what’s going on. Seems like you are already doing so, perfect. (mqtt-spy is a better choice but mqtt.fx is okay)
  3. Now get the openHAB binding connected (then tested)
  • Install the binding through Paper UI
  • Configure it via $OPENHAB_CONF/services/mqtt.conf (you’ve already done that but I believe you’ve missed the auth credentials? Should look similar to:
    broker.url=tcp://localhost:1883
    broker.user=openhabian
    broker.pwd=abcdefg
  • Check the log to see if the broker connects successfully: http://openhabdevice-ip:9001
    You should be seeing something like
    2017-07-22 17:15:24.084 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
    2017-07-22 17:15:24.089 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
Okay tell me when you are ready.
I am ready :slight_smile: - thanks!!!
44
really looking forward to the solution of this problem of yours as i am facing the same problem. let me know
Well congrats :tada:
Now define a very simple testing item:
Switch MQTT_Test "Testing..." { mqtt="<[broker:testing/mqtt/topic:state:default]" }
With this one in place you should be able to do a first tst. Use your mqtt.fx to publish the Message “ON” to Topic “testing/mqtt/topic”. Check the log once again!
How did we do this just now? See: http://docs.openhab.org/addons/bindings/mqtt1/readme.html#item-configuration-for-inbound-messages
If everything works as expected you can now start to define specific items for your Sonoff. Once again, don’t bother with Espeasy. Go Tasmota:
MQTT-Test works!
2017-09-05 21:44:11.170 [ItemStateChangedEvent     ] - MQTT_Test changed from OFF to ON
There you go :wink: That should be it. Let me know when further issues arise. Good luck!
i still cant control my sonoff :smiley: thats my big issue :wink:
thats my MQTT Setting on the SONOFF
58
Thats the CONTROLLER-PUBLISH Field:
/%sysname%/%tskname%/%valname%
EDIT
I published on MQTT.fx
PUBLISH: “/Sonoff_1/GPIO/12”
MESSAGE: “0”
20
i can see the change on the ESPEasy
06
thats a little success, am i right ?
how do i make a working home.item out of it ?
thanks THOM!! <3
Hey @RiotMode,
you were honestly not the first one to have starting trouble with the MQTT Binding in the beginning of their openHAB adventure. I’ve taken what I’ve written above over into a Tutorial. Could you please check if anything is missing or not clear to a newcomer?
for sure - i will do now :wink:
I just would add (e.g MQTT.fx or something similiar )
1. Connect with the standalone client to the broker. (e.g MQTT.fx or something similiar )
6. Use the standalone MQTT client from before (e.g MQTT.fx )
Hit Send/>Publish<
That’s something you should be able to find out easily by yourself, with the links I’ve posted above… :-/
Probably something like
Switch LivingRoom_Light "Living Room Light" <light> (LR,gLight)
    { mqtt=">[broker:/Sonoff_1/GPIO/12:command:*:default],
            <[broker:/Sonoff_1/GPIO/12:state:default]" }
The first line defines the Item with all it’s details, the second defined the outbound MQTT topic, the third the inbound. Because you didn’t show all needed details I’m not sure if the topic for the latter is correct.
Honest, I can’t stretch it enough :smiley:
Man, i love you <3 - thanks for your help! really appreciate it.
i changed it that way:
Switch Sonoff6 "MQTT-Test" <light> (LR,gLight)
    { mqtt=">[broker:/Sonoff_1/GPIO/12:command:ON:1],
            >[broker:/Sonoff_1/GPIO/12:command:OFF:0],
            <[broker:/Sonoff_1/GPIO/12:state:ON:1],
            <[broker:/Sonoff_1/GPIO/12:state:OFF:0]" }
03
seems to work <3
ITS WORKING :blush: :blush: :blush:
Wonderful! :wink:
got stuck here!! site says refuse to connect
Then your mqtt.cfg is wrong… Compare with the settings used in the standalone client.
broker.url=tcp://192.160.0.14:1883
#broker.clientId=openhabian
broker.pwd=password
#<broker>.qos=<qos>
what should i compare it with?
for me, the mqtt.cfg looks fine, but i am the noob in here :wink:
now:
can you send me a screenshot of the web page that you are looking at for this log. also tell me if i can see this log using ssh
