[SOLVED] Switch case error
what is here the error??
rule "set hue group2 scene"
        Item HTEST changed
        val String bridgeURL = "http://philips-hue.fritz.box/api/7hRzVEDbaoXMoVEPkHyAGSD1hudeIBy5pFq2zLjS/"
        var String scene_id = "lnb0VJ9Bf0wgwh4"
        val String scene_group = "2"
        switch(HTEST.state.toString) {
            case "1":
                scene_id = "lnb0VJ9Bf0wgwh4" //Sonnenuntergang Savanne
                sendHttpPutRequest(bridgeURL + "groups/" + scene_group + "/action", "application/json", '{"scene": "' + scene_id + '"}')
            case "2":
                scene_id = "bXMhkkAzPfgP9E0" //Tropendämmerung
            case "3":
                scene_id = "pdmTm9aVlo5c4KR" //Nordlichter
            case "4":
                scene_id = "9wYcn1skY602ZF0" //Entspannen
            case "5":
                scene_id = "DHdqsIokbYaW3KH" //Lesen
            case "6":
                scene_id = "xzUNyRhvl3-2L4F" //FrĂĽhlingsblĂĽten
            case "7":
                scene_id = "lqy8bsZ55T-45FR" //Konzentration
            case "8":
                scene_id = "oG4a2vBIL-Mf4gT" //Aktivieren
            case "9":
                scene_id = "aocu7QdLfPawkYj" //Hell
            case "10":
                scene_id = "f1UuvnOp5F8xzC2" //Gedimmt
            case "11":
                scene_id = "cb3IC7hAgW-URnm" //Nachtlicht
                sendHttpPutRequest(bridgeURL + "groups/" + scene_group + "/action", "application/json", '{"scene": "' + scene_id + '"}')*/
        logInfo("set hue group2 scene", HTEST.state.toString)
Error:
2019-01-06 09:54:39.834 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'hue.rules' has errors, therefore ignoring it: [14,35]: no viable alternative at input '('
[14,46]: mismatched input '+' expecting ')'
[14,48]: missing '}' at '"groups/"'
[14,83]: mismatched input ',' expecting 'end'
That is, it should be sendHttpPutRequest(bridgeURL)
I haven’t checked for other potential issues though, I’m not at a computer right now.
Oh and the */ at the end of the sendHttpPutRequest of case 11 probably won’t help either.
OK I deleted the “*/”
but this error is still there if I delete the “scene_id” in each case everything is fine. So somthing must be wrong with the variable decleration but i don’t know what???
Do you use VSCode?
Disregard my first comment on the opening/closing brackets, I clearly wasn’t awake yet… :slight_smile:
I now realized that we are dealing with Xtend syntax here, so you will need to use curly brackets if you want to have multiline case statements, like so:
            case "1": {
I have but always got this error
[Error - 11:12:21 AM] Server initialization failed.
  Message: Internal error.
  Code: -32603
java.util.concurrent.CompletionException: java.lang.IllegalArgumentException: URI has an authority component
	at java.util.concurrent.CompletableFuture.encodeThrowable(CompletableFuture.java:292)
	at java.util.concurrent.CompletableFuture.completeThrowable(CompletableFuture.java:308)
	at java.util.concurrent.CompletableFuture.uniApply(CompletableFuture.java:593)
	at java.util.concurrent.CompletableFuture$UniApply.tryFire(CompletableFuture.java:577)
	at java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:474)
	at java.util.concurrent.CompletableFuture.completeExceptionally(CompletableFuture.java:1977)
	at org.eclipse.xtext.ide.server.concurrent.WriteRequest.run(WriteRequest.java:44)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
	at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.IllegalArgumentException: URI has an authority component
	at sun.nio.fs.UnixUriUtils.fromUri(UnixUriUtils.java:53)
	at sun.nio.fs.UnixFileSystemProvider.getPath(UnixFileSystemProvider.java:98)
	at java.nio.file.Paths.get(Paths.java:138)
	at org.eclipse.smarthome.model.lsp.internal.MappingUriExtensions.toPathAsInXtext212(MappingUriExtensions.java:209)
	at org.eclipse.smarthome.model.lsp.internal.MappingUriExtensions.mapToClientPath(MappingUriExtensions.java:119)
	at org.eclipse.smarthome.model.lsp.internal.MappingUriExtensions.toUriString(MappingUriExtensions.java:110)
	at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$publishDiagnostics$26(LanguageServerImpl.java:447)
	at org.eclipse.xtext.xbase.lib.ObjectExtensions.operator_doubleArrow(ObjectExtensions.java:139)
	at org.eclipse.xtext.ide.server.LanguageServerImpl.publishDiagnostics(LanguageServerImpl.java:457)
	at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$null$9(LanguageServerImpl.java:293)
	at org.eclipse.xtext.ide.server.ProjectManager.lambda$null$3(ProjectManager.java:135)
	at org.eclipse.xtext.build.IncrementalBuilder$InternalStatefulIncrementalBuilder.validate(IncrementalBuilder.java:267)
	at org.eclipse.xtext.build.IncrementalBuilder$InternalStatefulIncrementalBuilder.lambda$launch$6(IncrementalBuilder.java:244)
	at org.eclipse.xtext.build.ClusteringStorageAwareResourceLoader.lambda$executeClustered$1(ClusteringStorageAwareResourceLoader.java:77)
	at org.eclipse.xtext.xbase.lib.internal.FunctionDelegate.apply(FunctionDelegate.java:42)
	at com.google.common.collect.Lists$TransformingRandomAccessList$1.transform(Lists.java:617)
	at com.google.common.collect.TransformedIterator.next(TransformedIterator.java:48)
	at java.util.AbstractCollection.toArray(AbstractCollection.java:141)
	at java.util.ArrayList.addAll(ArrayList.java:581)
	at com.google.common.collect.Iterables.addAll(Iterables.java:352)
	at org.eclipse.xtext.build.ClusteringStorageAwareResourceLoader.executeClustered(ClusteringStorageAwareResourceLoader.java:80)
	at org.eclipse.xtext.build.BuildContext.executeClustered(BuildContext.java:55)
	at org.eclipse.xtext.build.IncrementalBuilder$InternalStatefulIncrementalBuilder.launch(IncrementalBuilder.java:251)
	at org.eclipse.xtext.build.IncrementalBuilder.build(IncrementalBuilder.java:399)
	at org.eclipse.xtext.build.IncrementalBuilder.build(IncrementalBuilder.java:384)
	at org.eclipse.xtext.ide.server.ProjectManager.doBuild(ProjectManager.java:115)
	at org.eclipse.xtext.ide.server.ProjectManager.doInitialBuild(ProjectManager.java:107)
	at org.eclipse.xtext.ide.server.BuildManager.doInitialBuild(BuildManager.java:148)
	at org.eclipse.xtext.ide.server.WorkspaceManager.refreshWorkspaceConfig(WorkspaceManager.java:148)
	at org.eclipse.xtext.ide.server.WorkspaceManager.initialize(WorkspaceManager.java:117)
	at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$initialize$10(LanguageServerImpl.java:295)
	at org.eclipse.xtext.ide.server.concurrent.WriteRequest.run(WriteRequest.java:38)
	... 5 more
but my server is correctly set
That sounds like your URL is wrong, which is hard to debug from our end.
As the Request is always the same, the rule can be much simpler.
rule "hue group2 scene"
    Item HTEST changed
        case "1"  : scene_id = "lnb0VJ9Bf0wgwh4" //Sonnenuntergang Savanne
        case "2"  : scene_id = "bXMhkkAzPfgP9E0" //Tropendämmerung
        case "3"  : scene_id = "pdmTm9aVlo5c4KR" //Nordlichter
        case "4"  : scene_id = "9wYcn1skY602ZF0" //Entspannen
        case "5"  : scene_id = "DHdqsIokbYaW3KH" //Lesen
        case "6"  : scene_id = "xzUNyRhvl3-2L4F" //FrĂĽhlingsblĂĽten
        case "7"  : scene_id = "lqy8bsZ55T-45FR" //Konzentration
        case "8"  : scene_id = "oG4a2vBIL-Mf4gT" //Aktivieren
        case "9"  : scene_id = "aocu7QdLfPawkYj" //Hell
        case "10" : scene_id = "f1UuvnOp5F8xzC2" //Gedimmt
        case "11" : scene_id = "cb3IC7hAgW-URnm" //Nachtlicht
In fact, this doesn’t solve the problem with the URL.
