[SOLVED] Unhandled Exception w/o active rules
I’ve been trying to track this issue down the last couple of days and went through many similar topics but couldn’t find a solution.
Frankly speaking I don’t know when this problem began as I recently did quite a bunch of developments and the error appears in unspecific intervals. Sometimes its just 7 minutes in between, next time takes 30 minutes or more. Also I can’t identify any specific item that changes or any event that triggers just before the error appears.
Anyway I have now disabled all my rules (renamed all such files to “.rules_”, “.py_”) as I thought there must have been a bug (wrong type declaration?) in those, but the problem remains.
Through rest/items I made sure that no items are uninitialized (only some groups have state NULL).
My next guess was the thing config files, so I took the Astro config file out of my setup (as this is the only one that recently changed). Still no improvement.
There also is no client using any UI (e.g. ClassicUI, PaperUI, HABmin) and no active mobile phone app, so sitemaps should be ruled out.
So basically I’m out of ideas and may have missed a key hint towards solving the issue. Maybe someone could help me track it down. Thanks in advance!
  • Platform information:
    • Hardware: Raspberry Pi 3B
    • OS: openHABiann (Raspbian GNU/Linux 9 stretch)
    • Java Runtime Environment: OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8.0_152-b76)
    • openHAB version: 2.5M1
  • Bindings: astro, denonmarantz, exec, expire1, gpio1, km200, mqtt, network, ntp, openweathermap, samsungtv, systeminfo, zwave
  • Example of an error log:
2019-08-09 00:03:16.906 [ERROR] [org.quartz.core.JobRunShell         ] - Job DEFAULT.2019-08-08T21:48:16.659+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
  org.eclipse.xtext.xbase.impl.XIfExpressionImpl@e0324
} ] threw an unhandled Exception:
java.lang.NullPointerException: context
	at org.eclipse.xtext.common.types.util.TypeReferences.findDeclaredType(TypeReferences.java:248) ~[?:?]
	at org.eclipse.xtext.common.types.util.TypeReferences.findDeclaredType(TypeReferences.java:232) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.references.LightweightTypeReference.findType(LightweightTypeReference.java:643) ~[?:?]
	at org.eclipse.xtext.xbase.typesystem.references.LightweightTypeReference.isSubtypeOf(LightweightTypeReference.java:558) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.wrapOrUnwrapArray(XbaseInterpreter.java:680) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:503) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter._doEvaluate(ScriptInterpreter.java:243) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:234) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:226) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:204) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:1116) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:992) ~[?:?]
	at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:151) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:902) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:226) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:458) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:244) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:447) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:228) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:460) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:190) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.ClosureInvocationHandler.doInvoke(ClosureInvocationHandler.java:46) ~[?:?]
	at org.eclipse.xtext.xbase.interpreter.impl.AbstractClosureInvocationHandler.invoke(AbstractClosureInvocationHandler.java:29) ~[?:?]
	at com.sun.proxy.$Proxy158.apply(Unknown Source) ~[?:?]
	at org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob.execute(TimerExecutionJob.java:49) ~[?:?]
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202) [107:org.eclipse.smarthome.core.scheduler:0.11.0.oh250M1]
	at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:573) [107:org.eclipse.smarthome.core.scheduler:0.11.0.oh250M1]
2019-08-09 00:03:17.185 [ERROR] [org.quartz.core.ErrorLogger         ] - Job (DEFAULT.2019-08-08T21:48:16.659+02:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
} ] threw an exception.
org.quartz.SchedulerException: Job threw an unhandled exception.
	at org.quartz.core.JobRunShell.run(JobRunShell.java:213) [107:org.eclipse.smarthome.core.scheduler:0.11.0.oh250M1]
Caused by: java.lang.NullPointerException: context
	at org.quartz.core.JobRunShell.run(JobRunShell.java:202) ~[?:?]
	... 1 more
That looks like the sort of report you get from orphaned Timers - typically, a long running timer was spawned by a rule, and the rule file was later edited on other business.
When the rule file reloads, the context for the waiting timer is destroyed - but the quartz scheduled timer job is not. Maybe hours later, the now “orphaned” timer code executes and usually fails with a NullPointerException because some variable it references no longer exists.
Thank you so much for that input!
So a simple reboot should help for now. AAAAAARGH #facepalm
(Stupid me, didn’t follow IT advice #1…)
I just rebooted and after 30 minutes still all fine.
Is there a way to cancel all timers of a rule file to prevent this from happening again? Or will it have to be a reboot every time I changed one of the timer-relevant rule files?
There is no prevention.
You need not reboot if you can anticipate and ignore the error message, now that you know what it looks like. You know what your rules do.
Sure, still a pity as I really don’t like just ignoring errors.
They could distract from similar, relevant errors due to future rule modifications or add-on updates. So I guess I’ll go for the reboot just in case.
Anyway thank you so much for the hint. I’ve spent hours and hours hunting that ghost. It made me clean up my items and rules though.
