Stehof
(Stéphane Hofman)
January 24, 2022, 9:28pm
23
Jan 24 16:51:30 openHABianPi systemd[1]: **openhab.service: Control process exited, code=exited status=127**
Jan 24 16:51:30 openHABianPi systemd[1]: **openhab.service: Unit entered failed state.**
Jan 24 16:51:30 openHABianPi systemd[1]: **openhab.service: Failed with result 'exit-code'.**
Jan 24 16:51:35 openHABianPi systemd[1]: openhab.service: Service hold-off time over, scheduling restart.
Jan 24 16:51:35 openHABianPi systemd[1]: Stopped openHAB - empowering the smart home.
Jan 24 16:51:35 openHABianPi systemd[1]: Started openHAB - empowering the smart home.
Jan 24 16:51:35 openHABianPi karaf[10579]: /usr/share/openhab/runtime/bin/karaf: 247: [: Illegal number:
Jan 24 16:51:35 openHABianPi karaf[10579]: /usr/share/openhab/runtime/bin/karaf: 97: [: Illegal number:
Jan 24 16:51:35 openHABianPi karaf[10579]: /usr/share/openhab/runtime/bin/karaf: 300: [: Illegal number:
Jan 24 16:51:35 openHABianPi systemd[1]: **openhab.service: Main process exited, code=exited, status=127/n/a**
Jan 24 16:51:35 openHABianPi karaf[10650]: /usr/share/openhab/runtime/bin/karaf: 247: [: Illegal number:
Jan 24 16:51:35 openHABianPi karaf[10650]: /usr/share/openhab/runtime/bin/karaf: 97: [: Illegal number:
Jan 24 16:51:35 openHABianPi karaf[10650]: /usr/share/openhab/runtime/bin/karaf: 300: [: Illegal number:
This is the output, over and over again…
Stehof
(Stéphane Hofman)
January 24, 2022, 9:30pm
24
Still nothing here, for me the quickest way was to restore a backup on another Pi.
The problem one is still running to see if we could fix it, just for learning purposes
Stehof
(Stéphane Hofman)
January 24, 2022, 9:39pm
25
I guess there is something wrong with the openhabian-config 02 update option, I just run another check for updates and run everything, same thing happened again:
Jan 24 22:34:35 openhabian systemd[1]: **openhab.service: Main process exited, code=exited, status=127/n/a**
Jan 24 22:34:35 openhabian systemd[1]: **openhab.service: Failed with result 'exit-code'.**
Jan 24 22:34:40 openhabian systemd[1]: openhab.service: Scheduled restart job, restart counter is at 3.
Jan 24 22:34:40 openhabian systemd[1]: Stopped openHAB instance, reachable at http://openhabian:8080.
Jan 24 22:34:40 openhabian systemd[1]: Started openHAB instance, reachable at http://openhabian:8080.
Jan 24 22:34:41 openhabian karaf[985]: /usr/share/openhab/runtime/bin/karaf: 247: [: Illegal number:
Jan 24 22:34:41 openhabian karaf[985]: /usr/share/openhab/runtime/bin/karaf: 97: [: Illegal number:
Jan 24 22:34:41 openhabian karaf[985]: /usr/share/openhab/runtime/bin/karaf: 300: [: Illegal number:
Jan 24 22:34:41 openhabian karaf[985]: /usr/bin/java: error while loading shared libraries: libjli.so: cannot open shared object file: No such file or directory
Boby
(Robert K.)
January 24, 2022, 9:42pm
26
@mstormi , please help us - it seems something happened with openHABian with regards of Java. Thank you!
davebuk
(Davebuk)
January 24, 2022, 10:12pm
27
I’m another person with the same problem. I have the same error as @Stehof . I have tried sudo apt-get reinstall zulu*
but that hasn’t helped and also sudo apt-get install openjdk-11-jdk
and restarted multiple times. Neither of those options worked.
Looks like an issue has been raised on GitHub:
opened 09:09PM - 24 Jan 22 UTC
## Issue information:
Corrupted openhabian (java error) just after a fresh in… stall ...
Seems to be a Java Zulu update issue, I had the same issue on my previous install when I upgraded my system from openhabian-config ("02 | Upgrade System" ) ... I just restart a fresh install after the error on my working openhabian (was buster). Then I got the exact same error with the fresh install ...
Steps :
1) Fresh install of openhabian 1.7.1 (32bit) on RPI 4 4Go (64 Gb Micro SD Card)
2) Wait full installation & restart (no visible error during install process)
3) run : sudo openhabian-config -> 02 - Upgrade System
`There was an error or interruption during the execution of: "02 | Upgrade System" `
4) run : sudo openhab-cli status
A systemd service configuration exists...
Use 'sudo /bin/systemctl status openhab.service' to find the status of an openHAB service
openHAB is not running.
5) run : sudo openhab-cli start
Use 'sudo /bin/systemctl start openhab.service' to start an openHAB service
Launching an instance in this terminal..
Launching the openHAB runtime...
## System information:
Raspberry Pi 4 4Go - 64 Gb SD card - Openhabian 1.7.1 (32 bit)
Stehof
(Stéphane Hofman)
January 24, 2022, 10:42pm
29
Yea I tried the same commands, didn’t fixed it for me either…
Stehof
(Stéphane Hofman)
January 24, 2022, 11:02pm
31
Yea I saw it and tried it, still nothing yet…
ndye
(Ethan Dye)
January 24, 2022, 11:29pm
32
Sorry for the broken fix, it is up and working now.
Stehof
(Stéphane Hofman)
January 25, 2022, 5:37am
33
Thanks again for this quick fix, just checked the logging and no problems whatsoever, everything is working great again!
I hope the issue won’t accure again with this software package.
Boby
(Robert K.)
January 25, 2022, 12:08pm
34
Thanks, works fine again.
chilobo
(Christian Koch)
January 2, 2023, 4:39pm
35
I upgraded to 4.0.0. too, but openhab is not starting.
I read that Java 17 should be installed.
I started with
sudo openhabian-config update, chose
02 Upgrade system
and afterwards 45 OpenJDK 17 Install and activate OpenJDK 17 as Java provider
This produced the errormessage
2023-01-02_17:26:19_CET [openHABian] Reconfiguring OpenJDK 11... OK
2023-01-02_17:26:51_CET [openHABian] Updating Linux package information... OK
2023-01-02_17:26:54_CET [openHABian] Fetching OpenJDK 17... FAILED
2023-01-02_17:26:56_CET [openHABian] Installing OpenJDK 17... FAILED
java -version shows
openjdk version “11.0.16” 2022-07-19
chilobo
(Christian Koch)
January 2, 2023, 4:52pm
36
[quote=“Wolfgang_S, post:18, topic:132175”]
what is the output of sudo systemctl status openhab
* openhab.service - openHAB - empowering the smart home
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/openhab.service.d
`-override.conf
Active: active (running) since Mon 2023-01-02 17:46:46 CET; 1min 27s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Main PID: 929 (java)
Tasks: 38 (limit: 4915)
CGroup: /system.slice/openhab.service
`-929 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runt
Jan 02 17:47:17 Raspi karaf[929]: ... 13 more
Jan 02 17:47:17 Raspi karaf[929]: Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve openhab-core-base/4.0.0.SNAPSHOT: missorg.openhab.core.automation; type=osgi.bundle; version="[4.0.0.202212302156,4.0.0.202212302156]"; resolution:=mandatory [caused by: Unable to resolve oJan 02 17:47:17 Raspi karaf[929]: at org.apache.felix.resolver.Candidates$MissingRequirementError.toException(Candidates.java:1341)
Jan 02 17:47:17 Raspi karaf[929]: ... 14 more
Jan 02 17:47:17 Raspi karaf[929]: Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.openhab.core.automation/4.0.0.2022Jan 02 17:47:17 Raspi karaf[929]: at org.apache.felix.resolver.Candidates$MissingRequirementError.toException(Candidates.java:1341)
Jan 02 17:47:17 Raspi karaf[929]: ... 15 more
Jan 02 17:47:17 Raspi karaf[929]: Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.openhab.core/4.0.0.202212302150: mJan 02 17:47:17 Raspi karaf[929]: at org.apache.felix.resolver.Candidates$MissingRequirementError.toException(Candidates.java:1341)
Jan 02 17:47:17 Raspi karaf[929]: ... 16 more
any error shown in /var/log/openhab/openhab.log ?
2023-01-02 17:47:17.155 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
org.apache.felix.resolver.reason.ReasonException: Unable to resolve root: missing requirement [root] osgi.identity; osgi.identity=openhab-runtime-base; type=karaf.feature; version="[4.0.0.SNAPSHOT,4.0.0.SNAPSHOT]"; filter:="(&(osgi.identity=openhab-runtime-base)(type=karaf.feature)(version>=4.0.0.SNAPSHOT)(version<=4.0.0.SNAPSHOT))" [caused by: Unable to resolve openhab-runtime-base/4.0.0.SNAPSHOT: missing requirement [openhab-runtime-base/4.0.0.SNAPSHOT] osgi.identity; osgi.identity=openhab-core-automation-rest; type=karaf.feature [caused by: Unable to resolve openhab-core-automation-rest/4.0.0.S
NAPSHOT: missing requirement [openhab-core-automation-rest/4.0.0.SNAPSHOT] osgi.identity; osgi.identity=openhab-core-base; type=karaf.feature [caused b
y: Unable to resolve openhab-core-base/4.0.0.SNAPSHOT: missing requirement [openhab-core-base/4.0.0.SNAPSHOT] osgi.identity; osgi.identity=org.openhab.
core.automation; type=osgi.bundle; version="[4.0.0.202212302156,4.0.0.202212302156]"; resolution:=mandatory [caused by: Unable to resolve org.openhab.c
ore.automation/4.0.0.202212302156: missing requirement [org.openhab.core.automation/4.0.0.202212302156] osgi.wiring.package; filter:="(&(osgi.wiring.pa
ckage=org.openhab.core)(version>=4.0.0)(!(version>=5.0.0)))" [caused by: Unable to resolve org.openhab.core/4.0.0.202212302150: missing requirement [or
g.openhab.core/4.0.0.202212302150] osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=17))"]]]]]
at org.apache.felix.resolver.Candidates$MissingRequirementError.toException(Candidates.java:1341) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.apache.felix.resolver.ResolverImpl.doResolve(ResolverImpl.java:433) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.apache.felix.resolver.ResolverImpl.resolve(ResolverImpl.java:420) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.apache.felix.resolver.ResolverImpl.resolve(ResolverImpl.java:374) ~[org.eclipse.osgi-3.17.200.jar:?]
at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:257) ~[?:?]
openhabian@Raspi:/var/log/openhab $ sudo netstat -tulpn | grep java
tcp6 0 0 127.0.0.1:32991 :::* LISTEN 929/java
I installed Java 17.0.5.fx-librca following
with success, but after rebooting the same error
> 2023-01-02 18:16:30.010 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
shows up, but
java -version yields
Wolfgang_S
(Wolfgang_S)
January 2, 2023, 6:47pm
37
Try:
sudo update-alternatives --config java
In case there are different versions of java installed you need to make sure that the version you would like to have in the ‘default’ PATH is made available using update-alternatives ( this tool creates links ).
See: man update-alternatives
chilobo
(Christian Koch)
January 3, 2023, 9:45am
38
sdk install java 17.0.5.fx-librca
yields
java 17.0.0f-librca is already installed.
shows: Es gibt nur eine Alternative … java-11-openjdk-armhf/bin/java
But
java -version
shows:
openJDK version “17.0.5” 2022-10-18 LTS
OpenJDK 32-bit Server VM ( …)
I am confused!
Do I have to edit /etc/bash.bashrc manually as described in
https://u-labs.de/portal/java-auf-dem-raspberry-pi-installieren-aktuelle-jre-laufzeitumgebung-jdk-z-b-java-17-kostenfrei-legal-2021/
If thats the case - how do I find the path of the java 17 version?
BTW: openhabian-config option 45 Install and activate OpenJDK as Java provider still not working
{Seems to be a typical Linux problem: Do an update && upgrade of a running system and get into a jungle of advices not able to leave in 2 days :)}
Wolfgang_S
(Wolfgang_S)
January 3, 2023, 10:39am
39
Try the following:
run java -version
in case it results in …17.0.5…
then run which java
the resulting output should show you the path where the binary is found
I do not know the way of how sdkman does installations … it could be that java is installed in a users directory. That would explain why update-alternatives does not find it
I am not aware of that this is a typical linux problem.
I rather would ask why changing that early to OH 4.0 ? OH 4.0 at this moment is in a very early phase which I woldn’t use in a production environment.
Wolfgang_S:
update-alternatives
I have the same problem at macos:
What ever I tried even upgrade to zulu jdk 17 the error message persists. openhab@macos never tried to load jdk17
Is the information of old installations somewhere openhab stored?
"Unable to find any JVMs matching version “11”.
but
java -version
openjdk version “17.0.8.1” 2023-08-24 LTS
OpenJDK Runtime Environment Zulu17.44+53-CA (build 17.0.8.1+1-LTS)
OpenJDK 64-Bit Server VM Zulu17.44+53-CA (build 17.0.8.1+1-LTS, mixed mode, sharing)
and
./start.sh
Launching the openHAB runtime…
Platform information: Macos
Hardware: McMini
OS: Catalina 10.15.7
Java Runtime Environment: ?
openHAB version: 4.1
2,3 GHz Quad-Core Intel Core i7
Issue of the topic: installation failed
