Hi chris,
now I’ve done the debug for this device. Hopefully you can see the problem.
Device:
Node 6: Vision ZD2102
Type/ID: 2001:0106
Firmware Version: 5.1
items:
Contact DoorSensor03 “Sensor 3 [MAP(de.map):%s]” {channel=“zwave:device:15a7a49f3a6:node6:sensor_door”}
Switch DoorSensor03_Sabotage “Sensor 3 Tamper [%s]” {channel=“zwave:device:15a7a49f3a6:node6:alarm_burglar”}
This device has a door/open contact, a tamper contact and a enternal switch (binary contact) if parameter 1 is set.
In the documentation of Vision ZD2102:
The ZD2102 sensor equipped with tamper switch. If the cover of sensor is removed, the door sensor will send an alarm report (type:01, level:11) to the Z-Wave
External Switch: If your window needs two sensors for fully monitoring. You could use an external switch to connect with the ZD2102 for extending detection. The ZD2102 has 2 normally closed contact terminals. These can be used for additional external switch wired contacts. The external switch will send an alarm report (type:01,level:11) by opening the window/door.
For me this means, the external switch acts as tamper switch in this case too. Which means, I can seperate door/open (sensor_door event) from external switch open (alarm_burglar event). But I cannot seperate tamper alarm from external switch open/close, because both will be alarm_burglar event.
My problem is, that the two events comes in parallel and not as expected. See my discovery.
What I’ve done:
Starting with:
door/window contact closed, tamper contact closed, binary contact closed
2017-05-28 10:59:11.826
door/window contact changed to open
event log:
DoorSensor03_Sabotage changed from OFF to ON
DoorSensor03 changed from CLOSED to OPEN
wrong, only DoorSensor03 should change status not DoorSensor03_Sabotage
2017-05-28 11:00:41.593
door/window contact open to closed
DoorSensor03_Sabotage changed from ON to OFF
DoorSensor03 changed from OPEN to CLOSED
2017-05-28 11:01:38.687
tamper changed from close to open
correct only DoorSensor03_Sabotage
2017-05-28 11:02:26.969
tamper changed from open to close
2017-05-28 11:03:46.739
binary contact changed from close to open
wrong, as written in the documentation, the external binary contact works similar to tamper contact. which means for me, if this contact goes to open the same event tamper was send from device, but this is not correct interpreted here, again both events are reported
2017-05-28 11:04:46.419
binary contact changed from open to close
wrong, as written in the documentation, the external binary contact works similar to tamper contact. which means for me, if this contact goes to close the same event tamper was send from device, but this is not correct interpreted here, again both events are reported
I attached the full openhab.log (renamed from .log to .xml because of upload restrictions), the commented log (renamed from .txt to .xml because of upload restrictions) and the device XML-file
Hopefully you can work on it and find the problem.
node6.xml (8.7 KB)
openhab.xml (55.2 KB)
commented log.xml (57.3 KB)
If I should test something, just send me a post here
