Progress!!! My door open/close now works! Thank you.
Yes, I had to redo my items file a bit after the change. Here is what I have now:
Contact SF_Emma_Entry_Sensor "Emma Entry [%s]" <door> (Test, SF_Emma, Door) {channel="zwave:device:cab10335:node29:sensor_door"}
Switch SF_Emma_Entry_Tamper "Emma Entry Tamper" <siren> (Test, Tamper) {channel="zwave:device:cab10335:node29:alarm_tamper"}
Switch SF_Emma_Entry_Alarm "Emma Entry Alarm [%s]" <switch> (Test, Alarm) {channel="zwave:device:cab10335:node29:alarm_entry"}
Number SF_Emma_Entry_Battery "Emma Entry Battery [%d %%]" <batterylevel> (Battery, Test) {channel="zwave:device:cab10335:node29:battery-level"}
While much less important, the switch alarm_entry does not send an update channel message.
When I remove the magnet I get:
2018-03-11 15:34:40.009 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 1D 03 20 01 FF 32
2018-03-11 15:34:40.013 [vent.ItemStateChangedEvent] - zwave_serial_zstick_cab10335_serial_sof changed from 2324 to 2325
2018-03-11 15:34:40.021 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-03-11 15:34:40.025 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 1D 03 20 01 FF 32
2018-03-11 15:34:40.028 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 1D 03 20 01 FF 32
2018-03-11 15:34:40.031 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 1D 03 20 01 FF
2018-03-11 15:34:40.039 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Application Command Request (ALIVE:DETAILS)
2018-03-11 15:34:40.042 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Incoming command class BASIC
2018-03-11 15:34:40.045 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 29: Received Basic Request
2018-03-11 15:34:40.048 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 29: Basic Set sent to the controller will be processed as Basic Report
2018-03-11 15:34:40.050 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 29: Basic report, value = 0xFF
2018-03-11 15:34:40.052 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
2018-03-11 15:34:40.054 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 29: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-03-11 15:34:40.055 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 29: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
2018-03-11 15:34:40.058 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 29: Updating channel state zwave:device:cab10335:node29:sensor_door to OPEN [OpenClosedType]
2018-03-11 15:34:40.065 [vent.ItemStateChangedEvent] - SF_Emma_Entry_Sensor changed from CLOSED to OPEN
2018-03-11 15:34:40.061 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 27: Transaction not completed: node address inconsistent. lastSent=27, incoming=255
2018-03-11 15:34:40.080 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 1D 0A 71 05 07 FF 00 FF 07 02 00 00 8A
2018-03-11 15:34:40.083 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-03-11 15:34:40.082 [vent.ItemStateChangedEvent] - zwave_serial_zstick_cab10335_serial_sof changed from 2325 to 2326
2018-03-11 15:34:40.085 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 1D 0A 71 05 07 FF 00 FF 07 02 00 00 8A
2018-03-11 15:34:40.087 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 1D 0A 71 05 07 FF 00 FF 07 02 00 00 8A
2018-03-11 15:34:40.090 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 1D 0A 71 05 07 FF 00 FF 07 02 00 00
2018-03-11 15:34:40.091 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Application Command Request (ALIVE:DETAILS)
2018-03-11 15:34:40.093 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 29: Incoming command class ALARM
2018-03-11 15:34:40.094 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 29: Received ALARM command V2
2018-03-11 15:34:40.095 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 29: Process NOTIFICATION_REPORT V2
2018-03-11 15:34:40.097 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 29: NOTIFICATION report - 7 = 255, event=2, status=255
2018-03-11 15:34:40.098 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 29: Alarm Type = BURGLAR (7)
2018-03-11 15:34:40.100 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveAlarmValueEvent
2018-03-11 15:34:40.102 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 29: Got an event from Z-Wave network: ZWaveAlarmValueEvent
2018-03-11 15:34:40.104 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 29: Got a value event from Z-Wave network, endpoint = 0, command class = ALARM, value = 255
2018-03-11 15:34:40.106 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2018-03-11 15:34:40.107 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter NOTIFICATION event is 2, type OnOffType
2018-03-11 15:34:40.109 [DEBUG] [ternal.converter.ZWaveAlarmConverter] - Alarm converter processing NOTIFICATION
2018-03-11 15:34:40.110 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 27: Transaction not completed: node address inconsistent. lastSent=27, incoming=255
I see the Alarm Type BURGLAR but no update channel state afterwards.
Thank you,
B34N
